Question about E-Machines eMachines Desktop PC
Adding new memory
Can I install neww memory(both sticks) and still not loose anything that is already on my computer
    Problem Solver:
  • 15 Answers
The memory sticks have nothing to do with whats on your computer. All the stuff on your computer is on the hard drives. The memory sticks/RAM is it ability to process and think. So yes you can remove all the memory sticks and replace them with larger ones without any problems.
Posted on Dec 31, 2008
My compaq laptop just beeps at me and won't boot after I tried adding more memory
The memory stick is either defective or not compatible with your computer ( motherboard)
Try to install same brand and type of memory as the one you had already installed.
Jun 23, 2014 | Computers & Internet
CPU will not recognize the last memory slot in my FX4710
RAM, or random access memory, is the physical memory on the computer but only holds data while the computer is on.
The benefit of adding more RAM is that it generally makes your computer faster.
Almost all new computers recognize your RAM after you install it and restart the computer, but if yours doesn't there are a few simple things to do to get the memory recognized.
Check the type of memory you have.
Computer motherboards will work only with the type of memory they are designed for regardless if the memory fits or not.
There will be either a sticker on the memory or a listing on the packaging giving the memory type and speed.
Check the computer's or motherboard's manual for the type of memory that is compatible.
Install the memory and make sure it is tight, otherwise it may not get recognized.
The memory fits into slots on the computer's motherboard.
There are tabs on the side of the memory slots to release it.
Release the memory if it is installed and put it back in by pushing it down straight into the slot until it clicks.
Restart the computer and hit the appropriate key to enter the BIOS.
The key will be listed on the screen.
Go through the menu choices by using the arrow keys.
Look for the memory listing under hardware.
Make sure all memory listings are not listed as disabled.
If so, change them to enabled.
Choose anything listed similar to "Auto detect."
Exit the BIOS and restart the computer.
Jul 26, 2013 | Gateway FX4710-UB003A Core 2 Quad Q9300...
Memory upgrade didn't work
You may have to go into your BIOS to get the new memory recognized. However, according to the service manual for your computer (found at this link http://h10032.www1.hp.com/ctg/Manual/c00311113.pdf) you should not have to do this. It says your memory is installed incorrectly or it is the wrong type. Since you've verified the type with the original memory, that should not be the problem. Try removing the modules, use some compressed air and blow out the memory sockets, and re-insert them. It is also possible that static electricity could have claimed one or both. Reinstall the original memory to see if the computer will start back up if all of the above does not work. If the original memory works, return the new memory for an exchange.
Feb 14, 2010 | HP Compaq Presario SR2030NX PC Desktop
Trying to put new hard drive.when it starts up it beeps 3 times and no picture on the monitor.is the power supply bad? originaly the hard drive crashed and the trying to reinstall it kept coming up error...
3 short beeps is a base 64K RAM failure
Remove added memory
If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
  • Additional information about determining the type of memory to use in a memory upgrade can be found on document CH000910.
Open computer and reseat memory
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
Swap memory location
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
Try another computers memory
If you have access to another computer that uses the same type of memory try using its known good memory in your computer.
If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard and/or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced.
Replace memory
If you've determined or believe that the memory in y our computer is bad we suggest that you replace it.
  • Information about installing and adding new hardware including memory can be found on document CHADD.
Jan 31, 2010 | Gateway Computers & Internet
Adding memory, new total not recognized: IBM Thinkpad R51e-1844
Ram should always be paired. Same type, speed and size in each slot. You may have 1 SIMM/DIMM/DDR that has 2 sides of chips and the other with 1 which will do exactly what you state. RAM reads across the chips simultaneously. So if you have a different one in each slot it can go bonkers and do goofy stuff on you.
Jun 14, 2009 | IBM ThinkPad R51 Notebook
Memory card i have installed it
If the computer turns on and boots up, thats a good sign. You must know what you already have in the machine before the install, and what youre installing (Example: you have 256 megs of memory in the machine, youre adding a 512 stick=total should be 768 in Windows as well as BIOS less memory dedicated to video). Make sure that the memory is designed for your machine and matches in frequency what you already have. Best website to help you with this:
www.crucial.com. Use the SCAN MY PC tool to tell you what you have type, and the maximum amount your machine can take. You can even order what you need from them.
Mar 01, 2009 | HP Pavilion a810n (PP164AA) PC Desktop
Adding memory 1 OR 2
Adding or removing memory will have no effect on any data stored on your computer's hard drive (where your music is).
Jan 01, 2009 | Computers & Internet
Acer Aspire 3690-2970 Memory Upgrade
Your laptop may just not recognize and not even boot up if you exceed the memory limit. It will not harm the laptop if you give it a try with the 4gb. However, sometimes caution is a good thing. It all depends on what you are trying to do on your acer. If you haven't already, remove the old memory sticks and replace it with the 1 2gb memory stick. Work with it for a little while (this should not give you a problem). If you feel the laptop is still too slow....let me know...I will look up the compatibility with the memory and your laptop.
Nov 16, 2008 | Acer Aspire 3690-2196 Notebook
Installing motherboard in gateway profile 4
you need to replace the motherboard if the pc is auto shutting off, maybe even the processor!
May 19, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
