Question about Roland Spd-S Sampling Percussion Pad System
Convert ".SPD" to ".WAV"-files ??
Hallo,
does anybody know if there is some sort of converter-programm available so I can convert the ".SPD" files from my CF-card to .WAVs, so I can listen to them on my PC without having to "EXPORT" them to WAV on the SPD-S?
Thanx
  • Roland Master
  • 5,259 Answers
There is a lot of software on-line (some free) that can convert the most common files to whatever format you want.
However WAV files are rather large, also it's difficult to put extra information on them, such as album images. It would be much easier to convert the files to MP3.
Posted on Jan 02, 2018
4 Suggested Answers
SOURCE: problem importing files to Tascam DP02-cf
They don't mention in the manual that in addition to being 44.4khz, 16bit, mono, the wav file also has to be at a bit rate of 705kbps. Using Audacity (freeware) you can convert most any audio file into the necessary wav format for the DP-02cf to use.
Posted on Jan 25, 2009
SOURCE: removing files
Hold down the "Wave" and "Setup" buttons at the same time while powering on the SPD-S. This will turn off the protection; you should now be able to remove the file.
To turn the protection back on, perform the same procedure again.
Posted on Jun 19, 2009
  • 189 Answers
SOURCE: 16 bit 44.1khz monaural wav format files
I'll assume first that you have wav files on your PC that you'd like to import into your 2488 to use as percussion tracks.
You'll have to convert those files on the PC first into mono wav files. The 2488 can handle 16 or 24 bit so the bitrate shouldn't really be a problem. (It will also automatically truncate a larger bitrate down, but you should really dither the files rather than let them truncate... another topic).
You can use Audacity (free) to convert stereo wav files to mono wav (audacity will also dither for you).
Once your files are converted and saved on the PC, on the 2488 open the USB connection from the DISK menu. (This assumes you already have a usb cable connected between your PC and your 2488.) You will see a device appear on your filelist called HD_2488 or something like that with a drive letter. Copy your mono wav files into the WAV directory on the 2488 USB device.
Then on the 2488 press 'exit' to close the USB and from the WAV IN/OUT menu choose 'USB import'. You should see the WAV files listed. If those files are not mono waves you won't even see them listed. Select the file(s) and press enter to import. You'll be prompted to choose which track to import them to.
That's pretty much it.
bd.
Posted on Feb 27, 2009
How to Online Convert MP3 file to WAV (Audio) file format?
The immigration attorneys Convert your audio like music to the WAV format with this free online WAV converter. Upload your audio file and the conversion will start immediately. You can also extract the audio track of a file to WAV if you upload a video. We are constantly improving our service. Right now we support over 20 input formats to convert to WAV. For example: MP3 to WAV, WMA to WAV, OGG to WAV, FLV to WAV, WMV to WAV and more. If you have a file that we can't convert to WAV please contact us so we can add another WAV converter.
Oct 09, 2012 | Audio Players & Recorders
Tip
How to Convert MP3 to WAV
Want to find a good software to convert MP3 to WAV? Or have trouble to convert MP3 to WAV Why not to use a better converter to help you to convert MP3 to WAV and save more time to do other things
Maybe MP3 format is more familiar to us.
WAV is a short name for Waveform Audio File Format which is a Microsoft and IBM audio file format standard for storing an audio bitstream on PC. It is the main format used on Windows systems for raw and typically uncompressed audio.
Aimersoft Music Converter is a best helper to teach you how to convert MP3 to WAV. With this DRM music converter can convert protected regular music, so all of your worry about converting MP3 to WAV would disappear in a short time. Aimersoft Music Converter is an all-in-one DRM media converter with performs as a combination of DRM removal and DRM converter which doubles the value but half of the price.
Some steps as follows will guide you on how to convert MP3 to WAV:
Step 1: Free download Aimersoft Music Converter. Install and run it.
Step 2: Clicking "Add". Choose the files which you want to convert.
Step 3: In the "Setting" button, choose WAV format (*.wav).
TIPS: Also you can custom the music to other formats following the guides in the left box of this page.
Step 4: Click the "Start" button to start converting M4P to MP3.
After successful converting MP3 to wav, the result shall be stored on the "Output path" folder.
OK, now you can easily convert MP3 to wav with the help of Aimersoft Music Converter. If you like, just free download and enjoy it!
Connected information : media converter dvd to ipod touch dvd to iphone video iphone to computer
on Jun 10, 2010 | Computers & Internet
How do I convert the .voc to an mp3 file? I can not even open the .voc file.
you must copy the files into PC and after that you must use an audio files convertor. ( http://www.fileinfo.com/extension/voc) or use winamp Media player 5.6, videolan VLC media player to open the .voc files
Mar 29, 2011 | RCA VR5230 Voice Recorder
Im trying to convert a QCP file to an MP3 file. I have a conversion program but it seems to be damaging the file, not full play time of the song/file and bad quality. how can I make this work?
Rename the file to .WAV (change the .QCP extension to .WAV) then you can either play the WAV file itself OR convert the WAV file (for free) with CDex.
Mar 02, 2011 | Computers & Internet
Is it possible to splice 2 msv files (one after the other) so they become one file? These files have already been transferred to my PC.
OK well in that case you could convert them to WAV and join that and play it that way? Download and install the Switch Audio Converter. Switch can convert between numerous audio file types and has the capability of reading MSV files.
Add the MSV file you would like to convert to the Switch converter. Click on "Add File(s)" and browse for the file in the search window that comes up. When you locate the file, click "Open" to import it to the converter.
Select WAV as your output file type. The .wav extension is one of the options in the "Output Format" drop-down menu at the bottom-left corner of the Switch screen. Choose an output folder for your WAV file. To find a folder, click "Browse" next to the "Output folder" box. Locate the folder where you would like to save the WAV file on your hard drive and click "OK."
Click "Convert" to begin the conversion process. The "Convert" button is in the bottom-right corner of the screen. When you click "Convert," a small window with a progress bar will pop up to monitor the status, and a pop-up message will inform you when the conversion is complete. The WAV file will now be available in your chosen output folder. http://www.softplatz.com/freeware/wav-joiner/
http://download.cnet.com/Switch-Audio-Converter/3000-2140_4-10703967.html
Feb 16, 2010 | Sony ICD-MX20 Digital Voice Recorder
How convert WAV (CELP-type)to MP3? jrstat
download audio converter program. They are free an all over the internet for download
Aug 04, 2009 | Olympus VN-4100PC Digital Voice Recorder
SPD-S.....Internal Memory Full
if you have the samples in .WAV then you will have to IMPORT them, because SPD-S can only play .SPD files (import will convert from WAV to SPD).If you have produced your samples with your SPD-S (via mic or line-in or PhraseMaker) then they are already in .SPD-format and can be assigned without importing.
In this case you just have to assign a sample to a pad, by pressing CARD ("card"=lit) you can assign samples from your CF-card to a pad.
Dec 31, 2008 | Roland Spd-S Sampling Percussion Pad...
Converting wma files to wav files on olympus DDS player version 7
When using the DSS Player v7 software the program is unable to convert WMA to WAV. The option you see there only works when it is a .dss file that needs to be converted to .wav. In order to convert WMA to WAV you will need to locate a third party software program that does this type of conversion.
Go to google and search on WMA to WAV conversion editors.
Oct 07, 2008 | Olympus DS-30 Digital Voice Recorder
Audio converter for dss audio files
You can convert DSS file into wav format with DSS Player 2000 or the latest version. it can only convert it into wav format. after convert into wav format then u can use any other converter to change it into any other audio format. u can use total video converter or Sonic record now multilanguage software.....
best of luck.....
Feb 08, 2008 | Olympus WS-100 Digital Voice Recorder
Roland Spd-S Sampling Percussion Pad System Logo
2,955 people viewed this question
Top Roland Audio Players & Recorders Experts
Electric Dime
Electric Dime
Greg Cann
Greg Cann
Vito Vacirca Jr.
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
