FRONT DISPLAY DOES NOT LIGHT UP
SOURCE: Kenwood VR-605 display fading out
There is a cold solder connection on the display device, on the display driver board, or on or in the power supply that supplys the display voltage to the driver board. The only way you can repair it is if you have some soldering experience and or some electronic troubleshooting skills. If you go in and start poking around, and you poke at the wrong thing, It will smoke on you, as solid state electronics are very unforgiving when it comes to shorting out something, even if its for a blink of an eye!!! If you really like the unit, take it into a repair shop, as it should'nt cost to much to repair. If the units 3 to 6 years old, Maybe its time to think about upgrading to a newer unit??. Good Luck
SOURCE: Kenwood VR-207 Receiver
You will first need to check the remote control for the unit. Point the remote at a video camera and see if you see the remote light up. If it does try first to UNPLUG the unit for at least a couple of hours. If that as well does not work, you will need to have the unit serviced, as it may have a bad remote sensor on the front board or the microprocessor is No good. Depending on how old this unit is, it may not be worth repairing. Good Luck
SOURCE: Kenwood VR-715 reset?
Hello llarosa,
Yes, there is. Unplug the power cord from the wall outlet, then
plug it back in while holding down the POWER ON/STANDBY key.
That will clear the contents of the memory, reset the microcomputer and take the unit back to factory settings. Hope this helps. Let me know.
cancerags
SOURCE: i was trying to find the remote code for a kenwood
Kenwood radio tuners normally use one of the following remote codes:
025,066,068,071,and 075.
Sorry I don't know which is specific to vr-616.
SOURCE: my kenwood vr-616 keeps cutting
The unit may be overheating and shutting down to protect itself.
Please check the fan grills and make sure they are not clogged up with dust as can often happen to amps and receivers. If that is the case then a vacuum cleaner can be used to remove the dust.
If the unit is inside a cabinet try running it outside the cabinet. If it runs for longer before shutting down then this would indicate that it is overheating.
I had the same problem with my Sony home theater amp/dvd and cleaning out the dust cured the problem.
Please rate my answer if this helps.
Many thanks,
Chris
