Question about Apple iPod touch
Charging i got my mp4 on christmas and the battery had a single bar so i went to charge it for hours still only 1 bar. it said full bar when charger was on but when i took it off it head 1 bar
  • David Johnson
    David Johnson May 11, 2010
    First guess would be a bad charger, or usb cable
    I will help you solve this till your happy, just don't vote on me till we have the problem solved ok?
  • 31 Answers
You should charge the battery (on the first charge) for 18-24 hours. They 'initializes' the ions in the battery.
A way to fix this if you didn't do this the first time is to drain the battery entirely and charge the battery on the WALL SOCKET for 24-48 hours.
Otherwise try a new charger or cable, if its none of these. Its the battery. If you are still in Warranty (1 year) or AppleCare (3 years), take it to any Genius Bar in any Apple Store
Posted on Jan 01, 2009
Is it normal for charger to read half charged after plugging it back in from a full charge I unplugged it and then plug it back in it went half way and down to three lines before before charge
Hi yes that's normal it's called monotonic curve the charger will drop down the current as the battery becomes fully charged ..cheers
Dec 05, 2017 | Health & Beauty
Nikon Coolpix L110 camera was bought for me for Christmas 2010. Worked fine at first, but now seems to be having problems. Batteries don't last. I just bought new batteries in Feb/March this year...
You have to charge the batteries for nearly 8-10 hours. Brand new batteries also require a full recharge of 8-10 hours.Not only making sure the batteries are charged, have you changed the battery in the menu under type of batteries.
Download this manual :
http://www.nikonusa.com/pdf/manuals/noprint/L110_ENnoprint.pdf and go to page #114
Buy EN-MH2-B4/MH-73 Kit (4 Rechargeable Batteries + Charger)
Jun 14, 2011 | Nikon Coolpix L110 Digital Camera
Controller has single flashing red light. how to correct fault ?
The batteries are low and need charging If after you charge and you still have the single red light then you need to replace the batteries
Dec 07, 2010 | Health & Beauty
We got our grandson one of these last christmas and we lost the charger and I have found the charger now but, need directions how to charge it and where to plug it into? Please help with any...
Open the hood, and look for the battery. The battery has a blue connector that is connected to the Gator. You need to squeeze the plastic tabs on each side of the connector to separate them. The charger has a similar connector as the battery. Once you have the battery connector separated from the toy, plug the charger in to the wall and connect the charger to the battery by pushing the connectors together. Allow the battery to charge for about 18 hours for a full charge then remove the battery from the charger. The battery should be charged once a month to mantain the battery. People often forget to keep the battery charged once a month, otherwise the battery won't charge when the kiddies come to play. Hope this helps.
Jul 09, 2010 | Peg Perego John Deere Gator HPX Ride on...
My suns Quickie P320 (dual battery) requires very
Rapid discharge usually is a sign of weak batteries, and they should be replaced if the charge indicates that they are full after charging for several hours, and then dissipate rapidly.
If your not getting a full charge indication after several hours, then you need to check the charger to make sure it is putting out about 28 Volts DC. If it is, then it is for sure the batt's.
The sweeping lights should not occur when the chair is off the charger. They sweep while on charge to tell you that it is charging and you can't move the chair. If they sweep while off the charger, turn off and restart and it should go. If not, call a tech. rep. for Quickie.
Sep 29, 2009 | Quickie Wheelchairs Health & Beauty
Not holding a charge
This is not a battery problem. Some IC on the board must have blown somehow or it is a factory defect.
See a mobile repairer or retailer for necessary checks.
Wont cost much.
rate this please
May 29, 2009 | LG VX5200 Cellular Phone
Phone wont turn on or charge
first suspect the battery, next the faulty charger
return it to your vendor and ask for the warranty
Nov 16, 2008 | Samsung Ultra Smart F700
Battery not holding a charge
Hi try this I had a new Blackberry which required charging every single day, take out battery and press and hold the on button on the phone for a min, then put battery back in and try charging again! mine is perfect now again.
Somebody told me that it's to do with static or something that builds up and flattens the batt.
Mar 07, 2008 | Samsung SCH-u340 Cellular Phone
Charger will not fit anymore
If you got a USB cable with the unit, you can connect to your PC and recharge the battery that way. Just be sure to have the power switch turned ON. The screen on the player will indicate its connected and you should see the battery indicator in the lower right corner showing a charging condition (bar moving)
Feb 12, 2008 | Audio Players & Recorders
Unable to charge battery on Audiophase MP3, model KZ111
Try using the AC charger for the mp3 player, If It does the same thing, Ur MP3 is defective and u can return it with out the receitp sayin that it was a christmas gift since most eleftronics have a 1 year warranty
Feb 07, 2008 | Audio Players & Recorders
Apple iPod touch Logo
59 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
