Question about Microsoft Xbox 360 Console
Very noisey It makes a lot of noise when running . Is this normal?
  • mikbaincwu Jan 26, 2009
    My 360 is very noisy on start up and even worse when playing a game or watching a movie. This problem has just started and has become very annoying as you have to turn the volume of the tv high to try and drown the constant noise. In some cases there is a fault screen pops up telling me "to play this game please insert disc". If anyone can help it would be greatly appreciated.
    Problem Solver:
  • 6 Answers
It depends, is it noisy when you play a game from DVD or just when it is running ? From Xbox, you can expect that it is just as noisy as computer without a silent fan.
If it is noisy when playing a game, it is normal since it's loading everything from the disk and Microsoft made the disk to spin fast so you won't have to spend a lot of time waiting before the game loads.
Then, if it is only when you play a game - i recommed for you to install it to your hard-drive, that way the console won't have to use the disk to load everything.
Posted on Dec 31, 2008
Unit makes a lot of noise when cooking.
The exhaust fan may be loose, {check mounts} also, the turnable motor that rotates the plate often gets noisey before seizing, {remove plate to see if noise goes away} and finally the magnetron gets very loud near end of life.
May 16, 2012 | Magic Chef MCD1311ST Microwave Oven
Is the S40 Suzuki engine normally a noisy running engine?
all motorcycles run noisey, this question is a little vague, have you just aquired the bike and feel it is noisey? has a noise occurred that wasnt there before? what sort of noise is it ? a rattle? a knocking? a pinging? is the noise there all the time or does it go when the clutch is pulled in? is it there when in neutral? you will need to investigate a little and isolate when this noise is more prevalent, failng this take it to a repair shop.
Jul 13, 2011 | 2005 Suzuki Boulevard S40
When i start my car uo its makes this noise from the rear that sounds like the suspension its a humming noise
sounds like the air pump for the auto ride height is what your hearing.if it stops it could be normal
& pump is getting noisey, if it continues running you may have a leak in system.
Jun 19, 2011 | 1997 Cadillac Eldorado
Whirlpool dehumidifier makes a lot of noise when running and vibrating, dehumidifier is only 4 years old it does take out the water but very noisey any way to quiet it down?
When the compressors start to go bad they often start to get very loud also...the cost to replace the compressor will probably be more then a new unit...
Also check out this tip about dehumidifier problems...
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
May 02, 2010 | Whirlpool AD50USS Dehumidifier
Fan noise after a few minutes running.
Fans are typically a little noisey. If it's exceptionally loud or continues for a long time it may indicate the fan is no providing the proper cooling. Purchase a laptop cooling pad to place under the laptop while your useing it and make sure nothing is interfering with the airflow around the unit.
Jan 27, 2010 | HP Pavilion dv1000 Notebook
Dryer makes loud sound while running sounds like a bearing
a lot fo things cause noisey dryer . ( look for wire clothing stays in drum/ pins in the felts back and front. or dad may have left a sheet rock screw in his pocket . or a key / these things we take out of dryers every day . look hard . i think you will find some thing .. slow sounding noises are related to the drum . fast and hi pitched noise repate to motor and drive componet's .. mm
Dec 12, 2009 | Whirlpool ET8CHEXSQ Dryer
05 sportster 1200 custom making a noise from
Sportsters are noisey beasts, are you new to Harleys if so it is most likely normal. I know when I first got mine it sounded to me like it was coming apart. I changed to Mobile 1 synthetic oil and it quited up.
Jul 10, 2009 | 2005 Harley Davidson XL 1200 C Sportster...
Noisey compressor
Does it make the noise all of the time or just periodically? Does the outdoor fan run when it is making the noise. If the fan isn't running and the compressor is noisy at that time likely it is in defrost mode which is normal.
Jan 17, 2009 | Goodman CLQ36AR49 Air Conditioner
64194 Daily LOUD running noise
Unplug, and take cardboard cover at bottom off using 1/4 nut diver. Look at the fan; is there anything touching it? Spin it with your finger. Wait a few minutes then plug back in. Is it comming from the roundish black thing the size of a basketball? If so its not worth fixing?GOODLUCK>>>
Dec 17, 2007 | Kenmore 64192 / 64194 Top Freezer...
NOISEY
All washing machines need to be balanced before using , the
feet at the bottom of washer can be screwed in or screwed out to balance machine . it may take a few tries .
Also .. overloading washer will unbalance machine
Dec 14, 2007 | Washing Machines
Microsoft Xbox 360 Console Logo
51 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
