Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
The light bulb on our Admiral HMG 62186 needes to be replaced
How do I get to the bulb to replace?
Richie_asg1
  • 1036 Answers
SOURCE: montgomery ward refrigerator freezer side by side model hmg 2164
Hi there!
Was the bulb blown that you removed?
If not, it may be the contact switch on the door. These usually are just a press fit, sometimes needing a screwdriver in a slot to release it.
Hope this helps you. If it does, Please take a moment to rate your problem fixed with Fixya! Thanks.
Posted on Jun 17, 2008
SOURCE: ice maker on Admiral HMG 62165 side by side
check the lever in the ice bin. if it is stuck in the up position it thinks the ice bin is full and will not make ice. Just wiggle it to the down position.
Posted on Apr 23, 2009
AndreaBl
  • 218 Answers
SOURCE: i have admiral refrigerator HMG 21164 and it is
this is a problem that can only be solved by a professional so please get your local repairman on the line and have him come and take a look.
Posted on Jun 11, 2010
vetteman3002
  • 2299 Answers
SOURCE: I have a admiral model
There are many people that have this problem and are searching for answers as to what to do and what could be causing this problem. It seems to be weird that the freezer is working fine and the fridge side is not. Why would the coldest side be good and the warmer side not?
The answer to these questions lies in the way the freezer/fridge combo works. The freezer is where the cooling coils are located. Then air is moved over the coils and circulated through the fridge side by a small blower or fan. The problem arises when the air is not circulated for some reason.
The reasons the air is not moving is usually two reasons
  1. The fan or blower has failed.
  2. The coil is covered over with ice and blocks the air flow.
The first reason is pretty simple to fix, you simply replace the air circulator and things are good again.
The second reason can be more difficult.
1. The timing device that runs the defrost cycle of the refrigerator is defective.
2. The heater coil that melts the water is shorted or not working
Usually the first thing to check is the heater coil. If there is resistance through the coil then most likely it is still good.
The timing device can be an advanced defrost control board or a mechanical timing device.
If the heater coil checks out to be good then the problem should be the timer.
For most situations, unplugging the refrigerator and allowing it to defrost on it's own will get you going temporarily, till parts can be shipped to you. That will melt the ice and give you a few days or a couple of weeks till it ices up to the point where it will not work again.
So you can see here, the problem can usually be traced to one of three things.
  2. The timer device
  3. The electric heater coil
By methodically checking these parts you can isolate your problem and fix it.
Posted on Sep 21, 2010
SOURCE: Admiral Ice maker water filter, which one?
I have an admiral HMG19149 refrgerator with an ice maker. my problem is that the ice tast horable and cant be used. I looked for a filter to change but can't find it. Please help
Posted on Dec 06, 2010
My freezer has ice and fridge does not cool. Admiral signature model HMG 19802. Any ideas
Sounds like you have a defrost problem. First thing check if you fan motor in the freezer is running. You can open the freezer door and press in the door switch and listen to the fan motor. if fan motor is running, you have a problem in the defrost system. if not, you have a bad door switch or fan motor. (not very common)
to test defrost system: Locate defrost timer (under front kick plate) and rotate slowly until you hear a click.After a few minutes you will start hearing crackling sound and see water flowing down the drain line.
if defrost is working, replace the defrost timer. if not, you either have a bad defrost heater or def. thermostat. best think is to replace both.
for more accurate instructions, we need more detailed description of problem
Feb 02, 2015 | Admiral Refrigerators
I have a admiral fridge designer series # HMG 62186 that I purchased in 1997. It has always had popping sounds and sparks behind the drawer in the freezer. A repairman told me this was normal, so I...
Hello WIntersno,
I understand that your refrigerator is sparking behind the freezer drawer and you would like to know if this is a fire hazard. In my opinion it would be a fire hazard as plastic and rubber is flammable and the repairman is not true in saying that this is normal. A refrigerator should never spark as this is also an electrical hazard. I would suggest having another repaid man come out and fix the problem or purchase a new box.
Thank you for choosing FixYa.com
Justin
May 08, 2011 | Admiral Refrigerators
Freezer portion doesn't freeze.
check settings. if good check if compresor is running. a relay on compresor could fail
Feb 10, 2010 | Maytag Admiral Top-Freezer Refrigerator
Ice/Water dispenser not working correctly
hi,,
it is a thermostat problem,,because of it heating is not done properly ..u should replace or fix it,,it is not a big amount....
thank u,,,
Jul 01, 2009 | Admiral 26 cu. ft. Side-By-Side...
Admiral HMG 62163 water leaking internally & freezing in lower basket
good attempt, its actually a clogged drain thats backing up and your drain water is not able to leave refrig so it falls to bottom of freezer floor and eventually out the door. romve the items from the freezer and take the lower back wall off form inside, directly under the evaporator under all that ice there is a drain hole, youll need to clear that hole of iec( pouring boiling water down until you get a free flow of water then you can reassemble uint problem solved
Oct 25, 2008 | Admiral 26 cu. ft. Side-By-Side...
Not cooling
Replace the defrost timer about $20-30.00. One plug 2 screws. Mine was located on the bottom front behind the grill. (model HMG 24922) . Follow startup directions.
Sep 14, 2008 | Admiral 26 cu. ft. Side-By-Side...
Ice maker on Admiral HMG 62165 side by side
Apr 12, 2008 | Refrigerators
Jan 14, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
147 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
