Question about Sony KP-57WS510 57" Rear Projection HDTV
Sony KP-57WS510 57 in. Rear Projection HDTV
Picture rolls from bottom to top.It just started happening and doesn't happen often but,I am concerned it will get worse.Also the volume will turn down by itself and then come back on and so on.And no,I am not sitting on the remote.
  • 71 Answers
Hi. if the rolling is slow that mean you have a fault in the vertical and sync seperate part of the tv and need a technical support to slove but if it is fast yo can set it up with the vertical hold knub in the back or you have to open the back cover carefully that if you know how to do that but be carefull tv is a dangerous set hazard , look for the vertical hols variable resistor and fix it to stup rollinf for the sound fault , if you hit the side of the tv does it comes normal ?/ if yes then some part need to be resolders dried up soldering pin
Posted on May 05, 2007
SOURCE:
KP-46WT500 46 in. Rear Projection HDTV-Ready Television: I'm losing the top and bottom of my picture. The ...
Make sure you try two different sources to the tv, such as a cable box, dvd player and/or gaming system. If you have issues with all sources then it is for sure the tv and there should be a format option. However if it is only one source that the issue is with the issue is of course the source.
May 07, 2010 | Sony KP-46WT500 46" Rear Projection...
Clear picture, but rolling lines
it might be due to bad signal strength. check for it. good luck!
Oct 14, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Top and bottom mis aligment and color ribbon
If the picture is curved on the top / bottom and looks like a "rainbow", the convergence amps need to be replaced.
Jun 13, 2009 | Sony KP-51WS510 51" Rear Projection...
Half moon shaped lines
your convergance board is about to go out. thats what happened to mine. it will cost about 300 dollars to get it fixed
Aug 09, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony KP-51WS520 Stand by flashes 5 times
When a Sony TV flashes five times, that means that there is an AKB circuit fault.
This means that there is something wrong with the video.
When you get this error, several IC and components concerning the video signal must be tested and eventually replaced.
Mar 13, 2008 | Sony KP-51WS520 51" Rear Projection...
Power surge may have blown tv- Sony KP-46WT500- worth fixing?
Take a look at my post on Convergence IC replacement..Thank you GURU JAY
Feb 18, 2008 | Sony KP-46WT500 46" Rear Projection...
Play station and tv problem
most of them have the button on the back
Dec 05, 2007 | Sony KP-57WS510 57" Rear Projection HDTV
Sony kp-48v75 picture arcs at top and bottom
Convergenc IC proble look for and replace all Stk392-XXX
Dec 03, 2007 | Sony KP-48V75 48" Rear Projection...
PROBLEMS WITH VERTICAL ROLL
That is not a vertical roll from side to side, this is a horizontal rolling. if the vertical had a roll it would be going from top to bottom. This is most likely a coupling between the horizontal sync circuit and the sync separator circuit. Good Luck
Jun 28, 2007 | Sony KP-53S65 53" Rear Projection...
Sony KP-57WS510 57" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
