Question about Maytag 24 in. DWC7602 Free-standing Dishwasher
Maytag dwc7400abw My dishwasher does not drain. I think I have removed as much as I can from inside the washer. It is a freestanding washer. The water does drain but it takes about three seperate times of running the washer during the drain cycle to completey drain.
    President:
  • 1,462 Answers
You have a blockage somewhere probably. if the drain hose plumbed in under the sink, check there is no blockage in this area. also check the drain hose for blockages. if all clear, the fault is probably the drain pump itself
Posted on May 06, 2007
Haier dishwasher HDW9WHT beeps 5 times and won't wash what is wrong with it can I fix it or should I get someone in
7 results (0.54 seconds) Search Results
    Haier HDW100WH / HDW100SS - ProductReview.com.au
    www.productreview.com.au > ... > Dishwashers > Freestanding > Haier
    Rating: 1.7 - ‎30 votes
    Haier HDW100WH / HDW100SS: 30 customer reviews on Australia's largest ... 1.7 out of 5 stars for Haier HDW100WH / HDW100SS in Freestanding Dishwashers. ... I putthis review in to do my part for what I think is a great consumer service you ... it it keeps beeping 10 times telling me doors open??and won't begin cycle.
    Haier Dishwasher Error Fault Codes - Lights Flashing ...
    removeandreplace.com/.../haier-dishwasher-error-fault-codes-lights-flash...
    Dec 21, 2015 - Haier dishwasher error codes - flashing lights - beeping ...Dishwasher keep filling water and draining at the same time ... Fix Washing Machine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note 5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The Refrigerator ...
    Dishwasher Has Beeping Sounds Blinking Lights - How To ...
    removeandreplace.com/.../dishwasher-has-beeping-sounds-blinking-light...
    Dec 21, 2015 - At times your dishwasher may need to be reset. ... Haier DishwasherError Fault Codes - Lights Flashing Beeping Sounds My Haier ... Fix WashingMachine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The ...
    How to Troubleshoot & Repair a Dishwasher ' HomeTips
    www.hometips.com/repair-fix/dishwasher.html
Jan 19, 2016 | Haier Dishwashers
Water does not drain out
Hello. I have had this happen to ours fullsize Maytag 2 or 3 times over the past few years, but maybe this could help. In all my cases it was one of two things:
1. The drain is clogged. Food, broken glass, etc. can clog the drain. You'll see the grated cover or similar inside on bottom of washer. There's usually only a screw or 2 you need to remove to take of grate and get to insides. Remove all debris you find.
2. If it goes into the drain cycle but you hear nothing, or almost nothing, likely the drain pump has gone out. Only had to replace one of these. This means $ and a repair dude/dudette will try to charge you a fortune but its a super easy install. The hardest part is you have to slide the washed enough out of the counter enclosure so you can lean it over enough so you can get to the water pump underneath (however looks like yours is a portable so may be easy to get at)You can find a replacement drain pump online (including on ebay) for like $25 bucks. Just disconnect the hoses and power wire, replace the old one (again just a few screws), reconnect everything and you are done.
There's lots of vids on YouTube showing both how to clean drain and how to replace a drain pump. Hopefully for your specific model even. Try these things and hopefully you will be back in business.
Cursory Google search turned up part link below, there's also a service manual online (2nd link). Good luck!
https://www.amazon.com/Maytag-WHI-21001906-Washer-Drain/dp/B001BA1HH8
http://www.manualslib.com/manual/952333/Maytag-Mdc4650aw-Series.html?page=32
Dec 27, 2015 | Maytag MDC4809AW Portable Dishwasher
My maytag dishwasher won't drain. It is not clogged. It just won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Jan 31, 2011 | Maytag 24 in. DWU9202 Built-in Dishwasher
Dirty dishes on Maytag 24 inch dishwasher, model no MDBH940AWS, Dishes have caked on gunk on the glasses after washing. The gunk is usually at the bottom of a glass (which is in the dishwasher upside...
This dishwasher has a circular filter path under the bottom plate - 6 screws - that can become filled inside with debris - you can remove it and wash it out with a garden hose.. Paul
Nov 20, 2010 | Maytag 24 in. MDBH940AWS Built-in...
My Maytag diswasher leaks from what appears to be just above the bracket that holds the motor
hello mam please check the drain line if the line is having cracks please change the drain line and if the water is leaking from the bottom of the washer then change the 'o'ring which will be inside the dishwasher to fix this ring you should remove the drain line.
Oct 24, 2009 | Dishwashers
Maytag dishwasher that won't drain when finished
HI, usually, if the dishwasher dose not drain properly, it will be the fault of a defective or, malfunctioning pump. i will list several problem areas to check. Inspect each area properly and, replace any component that is faulty or fouled.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Jun 22, 2009 | Maytag MDB6000 Dishwasher
Won't drain
In most cases the blockage is at the end of the drainhose, where it connects th the "peatrap", simply removing the hose clamp, then hose and inspecting. If no blockage found there you will need assistance. If you want, you can funnel your hand over the end of the hose, blowing down hard through this funnel can sometimes dislodge blockage. ALWAYS rinse dishes before loading any dishwasher.
May 23, 2009 | Maytag DWU9962 Dishwasher
Water will not drain on neptune MAH3000AWW washer tried different cycles. It started working for a while after we took back off and took things apart but now it won't drain at all.
There are many things could make a dishwasher not drain, here's a list of the most common reasons.
  • a clog or air gap in the drain line, often the problem is where the drain line attaches to the household drain line, if you remove this line you can clear any debris from the hose or hose connection.
  • a defective pump, your dishwasher pump ejects the water.
  • many dishwashers use a drain valve or solenoid, the solenoid can sometimes become stuck or defective solenoid.
  • a defective motor, if the motor is'nt turinig or working the dishwasher won't drain.
Mar 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Dishwasher won't drain
on all dishwasher think of them as a simple gutter system. the water only has one drain. At the bottom, if the pump can't pump out the water, its simply a bad pump or a clogged drain hose. Food particle can clog the "drain screen", use a good quality shop vac, clean 'drain screen', remove drain hose and clean thoroughly. If the hose goes into your drain pipe, remove that and clean that really good with snake it its metal or a strong 1/2 zip tie if its plastic.
Nov 30, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Dishwasher does not cycle
Yes, you'll need to replace the motor. Though you may not need to remove the machine from under the counter.
Feb 09, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
Dishwashers Logo
205 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
