Question about Lenovo 3000 C200 CM 520 1.6G 512MB SYST80GB 15-XGA DVDRW BG WHB PC Notebook
LENOVO 3000 C200 POWER ON BUT NO DISPLAY ON MONITOR
The power is on and the led indicates it is but the monitor does not come on. If you remove the panel/cover on the key pad and touch the cable that connects the monitor to the main board the monitor comes on. There is a loose cable connection. Everytime you have to open the cover and touch the cable. sometimes it works sometimes it does not. How to solve this problem permanently
- Gopi
  • gopi516 Jan 02, 2009
    Sorry, you have not included problems faced on lenovo laptops like 3000 c200.
    Thanks anyways,
    Regards,
My pc c200 3000 is too slow in operating and also in internt
The reason may be one or more problems acting together. The problem nowadays is that it is very difficult and time consuming to monitor and take care of your Lenovo PC. Even experienced users find it hard to perform such tasks on regular basis because you might need to prepare a huge amount of time and energy to deal with each issue separately.
If you want to fix the problems more efficiently, try the Lenovo speed up program, available here: http://www.speeduplenovo.com/
best wishes!
Jul 16, 2011 | Lenovo 3000 C200 Notebook
Dear,I have Lenovo 3000 C200 and I have no sound.I tryed to install a drivers but no help.Please help me how to solve my problem.OS is win XP SP3. Rgds!
Whatever software you installed before , remove it then restart your computer and install this
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles/63ar14ww.exe
Apr 13, 2011 | Lenovo 3000 C200 Notebook
Laptop screen is not showing anything after power is on
if the power is on and the screen does not show up , try to hook an external monitor using the VGA cable. If the screen does show up, it means that the problem is in the laptop LCD monitor itself. Otherwise if the external monitor does not show up, that means your laptop does not boot anymore to the operating system. Try to turn off the power and remove the power cable and battery on the laptop. Then press and hold the power button for 8 secs. Then reinsert the battery and power cables on the laptop then turn on the laptop. If there is still no screen displayed then call Lenovo for repair of your laptop.
Oct 22, 2010 | Lenovo 3000 C200 Notebook
Problem with Lenovo 3000 C200 audio
You may want to check for malware. You can download a free malware remover from here: malwarebytes.org Run a full scan and it will remove all malware, causing the computer to run much faster.
Apr 02, 2010 | Lenovo 3000 C200 Notebook
Lenovo 3000 c200 wont power on
try to perform battery drain. you need to take out the battery and unplugged the power adapter. press and hold the power button and count 1-10. release the power buttong after 10. do it for 3 times. after that, plug in the adapter and power adapter and observe.
Mar 25, 2010 | Lenovo 3000 C200 Notebook
Failure to boot Lenovo J3000.
check 1st a ATX power supply if this a good 2nd remove the memory then make a clean using a paper eraser clean all the pin connectors of memory....
May 23, 2009 | Lenovo 3000 J Series 1.80G VBE PC Desktop
LCD screen displays everything in inverted colours
Do Rick's 1st solution of trying the external monitor.
If thats messed up too then it's software. (Windows, drivers, settings, etc)
If the monitors fine then you've got problems send it to an expert at that point.
Mar 21, 2008 | Lenovo 3000 C200 Notebook
Lenovo 3000 C200 CM 520 1.6G 512MB SYST80GB 15-XGA DVDRW BG WHB PC Notebook Logo
929 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
