PDAs
Problem for PDAs
Generic problem for all PDAs
I was trying to move
By roberts_hase on Dec 31, 2008
I was trying to move an address list from the computer to my hand held and suddenly it has Please Wait on the screen of the hand held and it will not turn off or do anything
Comments:
Dec 31, 2008
- Have disconnected it and it still says Please Wait with a cylindrical object underneath which is half black and half white and then the bottom half of the screen has the alphabet on it as usual
Same Problem
Jan 07, 2009
-   hey guys,, I have a Blackberry 8300 but i am unable to access the media card to store stuff on it. It is put in properly.. also tried another card in the phone and same thing happens.. can anyone tell me what to do please..thanks
-   fantascyjm
Solution #1
posted on Dec 31, 2008
Somewhat Helpful)
marked
Rank: Guru
Rating: 86%, 929 votes
If the unit is stuck, try to manually power it off or remove the battery to power it off completely........
Comments:
Dec 31, 2008
- You can also try to reset it and after the reset still not working you may need to flash the software of this unit....
Was this helpful?
Yes
No
Solution #2
Very Helpful)
machadojr_fe
Rank: Guru
Rating: 85%, 267 votes
Turn it over so that the screen faces down.
Locate the reset hole, which is just large enough for you to insert theend of an unwound paper clip, and press gently for a "soft" reset. Don't use anything sharp like a safety pin.
If the soft reset doesn't help
Hold down the Page Up buttonon the front of your PDA while pressing the reset button on the back.
The next thing is a hard reset the bad part about this is that you'lllose all the data and preferences in your PDA.
Before proceeding with the hard reset, replace the batteries in yourPDA to make sure the old ones were not bad.
Hold down the powerbutton while you reset from the back of the PDA. This should return your PDA to the way it camefrom the manufacturer.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
Very Helpful)
Dipu007
Rank: Wiz
Rating: 80%, 917 votes
try to hard reset
It is some time very important to Hard reset a PDA for example if you want your PDA to be factory default or or operating system corruption etc the following are the information, how to do a hard reset on every PDA as different PDA manufacturer have different methods.
To hard reset, press and hold the power button and press in on the reset button (reset hole) on the back of the unit for about 2-5 seconds. Release both buttons and you will see a confirmation screen asking you if you would like
Was this helpful?
Yes
No
Solution #4
Not Rated)
gymowner
Rank: Wiz
Rating: 85%, 233 votes
It locked up, either hit a reset button, or remove the power to it and it should restart when you reconnect the battery, it may have been running down and the process just locked it up
Was this helpful?
Yes
No
Popular Solutions for PDAs
Questions and Unsolved Problems for PDAs
Answer
I want a product similar to Palm m505 to store data only.
Answer
Ok, so my iPhone won't turn on. I try to turn it on and the Apple logo comes up as per usual. Then... (More)
Answer
its really slow and laggy. how to i speed it up?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PDAs:
Top PDA Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
