Question about Zanussi IZ161S Front Load Washer
Zanussi Jetsystem I have a Zanussi jetsystem washing machine that will not take softener from the tray - I have tried cleaning it as best as I can and the jet holes above seem clear??
  • 1 more comment
  • James Reed Jun 04, 2007
    Thanks for this, I have tried cleaning and seems to have help as it now takes a small amount of softener. What do you mean by u/S?
  • mandnheating Jan 24, 2009
    Does not dispense conditioner from tray althought all jet holes are clear
  • Anonymous Mar 27, 2014
    power light only light working
    Sergeant:
  • 236 Answers
Scrub above the soap tray to make sure the holes are clear if they are you may have a system where the fab condit water valve is u/s.
Posted on Jun 02, 2007
What does fault code e30 on a zanussi jetsystem 1400
Activated anti-flooding device. Try to find leaks in the bottom of washing machine.
Dado
Aug 08, 2014 | Zanussi Washing Machines
Hi, ive got a zanussi jetsystem excel 1250 FJS-1397W model washing machine. it wont empty the water after a wash. could you tell me what to try or whats wrong? thank you, fiona
Locate and clean filter, which should be at bottom front right of washer, behind drop down or push down flap.
Unscrew anti-clockwise to remove and clean.
Jan 31, 2010 | Washing Machines
Zanussi jetsystem 1000 will not do anything
zanussi jetsystem 1000 has stopped spinning the wash ! its missing out the spinning program help ?
Oct 09, 2009 | Zanussi FJS1225W Front Load Washer
How to clean a Zanussi Jetsystem 1400
on my mums zanussi,, after opening door, machine had not drained and spined, closed door again could not get machine to go,, this time could not get door opened..there is power to machine.
May 19, 2009 | Zanussi Washing Machines
Jetsystem blocked.
I had the same problem, if you undo the self adjusting clip that holds the drum seal in - then pull back the top of the seal near the nozzle thats blocked, this will reveal the pipework attached to the nozzle. Then use a pipe cleaner and push up through nozzle - the attached pipe is clear so you will see any gunge and be able to loosen the debris. After cleaning reassemble seal then run a empty cycle which will clear the loosened debris. Regards, Grant
Jan 14, 2009 | Zanussi FJS1225W Front Load Washer
ZANUSSI WASHING MACHINE
I have taken out the filter and washed it thoroughly! Also flushed the out pipe to make sure the whole system was clean. This resolved the problem
Dec 19, 2008 | Zanussi FJD1666W Front Load Washer
I have a zanussi jetsystem iz16s and it keeps pausing just after its filled up with water and coming up e20 (I think thats the error code) any ideas what the problem might be.
Sep 11, 2008 | Zanussi FJS1225W Front Load Washer
Heating element
hi yes they are different the fc1200w element is 1600 watts (£31 part 150867200-1)the jetsystem zwf1658 1900 watts its always better to use the correct part.
May 03, 2008 | Zanussi FC1200W Front Load Washer
Jetsystem not working
It sound like an clogged inlet water line issue. Check for clean filters and inleat water valve.
Jun 29, 2006 | Zanussi FJS1225W Front Load Washer
Zanussi IZ161S Front Load Washer Logo
497 people viewed this question
Top Zanussi Washing Machines Experts
jimorris77
shaun taylor
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
