Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
Adding detergent/softener/bleach I do not see anything in the operator's manual for my Nexxt 500 plus Bosch washer that says you can fill the detergent, softener, and bleach compartments up to a certain level. I am adding the detergent, etc. each load. I see there is a maximum marker on the softener and bleach compartments, but not on the detergent compartment. Can I add more than one load worth of product at a time?
  • Bosch Master
  • 3,463 Answers
U cud, but not recommended as it cud lead to oversuddsing, causing all sorts of prob's.
Stick to recommended doses.
Plz rate my solution.
Thanks.
Posted on Dec 31, 2008
Error code E:13 on my 500 plus series washer
The E13 error code on your Bosch washer refer to a drainage problem or the pump time might have been exceeded
Either it might be due to a clogged pump, improper detergent being used, ( must use "HE" detergent ) hence suds not allowing a proper drain cycle. You should clean water drainage pipe and/or drain hose. Turn selector to off and restart 'drain, program or, on 500 plus machines, the 'refresh' program. It also says this is caused by using too much detergent. Bosch recommends using half of what the manufacturer recommends when using HE detergents. They don't recommend regular detergents. First run the short wash or refresh cycle without detergent and hopefully your lines will clear.
Thank you !!
May 25, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
The Softener is not going through.
you need to take the soapbox out and clean thoroughly. Pull the soapbox out to the point where you get resistance and the you will see a tab you press to release it fully. Do not force the soapbox out. Take it to the sink and clean with hot water. Softener can be like jello when it drys and will block the release.
May 24, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Is there any detergent I should avoid using in my Bosch Nexxt 500 Series washer?
Any clothes-washer HE (low suds) soap will do. Just be aware that you only need a tablespoon of the soap, not the 3/4 cup that comes in the box!
Oct 17, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch nexxt washer fabric softener not draining
is there a drain on the bottom left corner if so drain the contents its usually under a small panel
Sep 14, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Nexxt 500 washer - fabric softener tray fills with water and doesn't drain. I have not used liquid fabric softener in this machine. It is 16mo old. What do I do to stop this?
There is suppose to be an outlet that opens up at the same time water enters ( to flush out softener). That outlet is either stuck shut or the wire fell off (I believe this is a little solenoid plunger with a wire attached). It is common for wires to come loose from the vibrations of the machine
Aug 20, 2009 | Bosch Nexxt 500 Plus WFMC5301UC
Bosch 3.81 cu ft Nexxt 500 Plus bleach not dispensing
We had the same problem with the bleach dispenser. It was under warranty so Lowe's sent a repairman that replaced some part in the control panel that he said was faulty on this model. He also said to only use 1-2 Tablespoons of HE detergent and leave the door open. Also dilute any softeners before adding them.
Sep 13, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My front loader Bosch washing machine is not draining in the fabric softener section.
Make sure it is the fabric softener that is not being added. Try running w/o fabric softener and see if the tray is still full. The reason I am asking is that after I run my washer the fabric softener tray is full, with water, not softener. The factory tells me it is because the water fill nozzles have realigned and overspray into the softener tray. Not a big problem, since my system is under warranty I am having them fix the nozzles and then I will know how to redirect.
If it is the softener that is not being added then check to make sure the line is not clogged. You can lift out the bleach / softener try and check for cloggs.
Aug 18, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosh washer won't dispense softener. cleaned the tray and tested it by filling with water and it drained completly out, so i know its not clogged. washed another load and softener still there at end of...
I had the same problem. the only thing that works for me is fulling the fabric softener compartment all the way to the top with water then it will syphon down! it adds it to the load at the start instead on the rinse cycle but its better then nothing!
Jul 28, 2008 | Bosch Washing Machines
Detergent dispenser
As far as I am aware, there IS NO dispenser for bleach, you have to put bleach in drum before adding clothes and starting cycle. The far right compartment is only for "pre-wash" cycles, and if no pre-wash is selected, water will run through ALL compartments at the rinse stage..... Oshie
Feb 28, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
325 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
