Question about One For All URC-3021 Remote Control
You just dropped me without answering my question or really even trying
  • 827 Answers
I can see you are frustrated so I'll see if I can help. Here are the Akai TV codes:
10812, 10702, 10030, 10672, 10060
As you can see, they are 5-digits for the direct remote, not 4.
This should help!
Program TV Code
1. Turn on the TV.
2. Locate the 5-digit code for your TV.
3. Slide the MODE switch to the TV position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
Program DVD, VCR, Stereo Receiver, and Stereo Amplifier Code
The AV1 and AV2 switch positions can be setup to control a VCR, DVD, STEREO, second DIRECTV Receiver or second
1. Turn on the component you wish to control (e.g. your DVD Player).
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the AV1 (or AV2) position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under AV1 (or AV2) flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of component being set up. If performed correctly, the green light under the selected position flashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Repeat steps 1 through 6 to set up a new component under AV2 (or AV1).
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
Verifying the Codes
Once you have set up the DIRECTV Universal Remote Control using the above steps, use the following instructions to find out the 5-digit code to which your component responded:
1. Slide the MODE switch to the appropriate position.
2. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
3. Enter 9-9-0. (The green light under the selected switch position flashes twice.)
4. To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down.
5. Repeat step 4 four more times for the remaining digits; i.e., press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.\
Depending on how you set up your remote, the VOL and MUTE may control the volume only on your TV, regardless of the position of the MODE switch. This remote can be set up so that the VOL and MUTE keys work only with the component selected by the MODE switch. To enable this feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
2. Using the number keys, enter 9-9-3. (The green light will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light flashes 4 times.)
Now the VOL and MUTE keys will work only for the component selected by the MODE switch position.
To Lock Volume to AV1, AV2 or TV
1. Slide the MODE switch to the AV1, AV2 or TV position to lock the volume.
2. Press and hold the MUTE and SELECT keys until the green light under the selected switch flashes twice and release both keys.
3. Using the number keys, enter 9-9-3. (The green light flashes twice.)
4. Press and release the SELECT key. (The green light flashes twice.)
Hope this helps
Happy New Year!
Chris (ziraffa)
Posted on Jan 01, 2009
Galaxy mega was dropped, screen cracked, now it won't come on or charge. What could it be?
Anything really, you did say you dropped it. Check the battery if possible - to be sure it is making contact with the phone itself. It is difficult to open these devices without causing more damage and even if you could - there's really very little you could.
Feb 05, 2016 | Cell Phones
How Many day does it take the mail to get a letter from one county to the next
You have to make sure that you only count days since the letter actually enters the postal system. Even if you drop it off at the post office, you can't count day one until the mail slot you dropped it into is picked up for delivery (the days and times it is emptied should be posted on the mail slot). Once it is really in the system, it should only take 1-2 days to travel 1 county over.
If you meant country instead of county, the answer would be significantly different.
Dec 24, 2014 | Computers & Internet
Air condintiner compressor clutch fuse
It is impossible to answer your statement (it is not really even a question) without knowing the YEAR, MAKE, and MODEL of your vehicle.
Doesn't this seem obvious to you?
Sep 06, 2014 | Cars & Trucks
How to reset Blomberg DWT23100W computer?
Remove lower dish basket and inspect where water drains looking for clogged inlet
Jun 02, 2014 | Dishwashers
Should I upgrade my iphone from 4 to 5
Are you happy with the 4s? I'm answering this in mine right now. Do you really NEED a 5, or the hassle of learning how to use it? Why not wait a bit and try a few friends phones and when the prices drop from the introduction if the iPhone 6, you can get a 5 at a normal person price, IF you really feel you even need or want one then.
Nov 21, 2013 | Apple iPhone Cell Phones
HOW HARD IS TO REPLACE OIL PUMP WITHOUT REMOVING ENGINR
you really cant do it properly you have to drop the pan and without th motor being pulled it really just isnt worth the trouble trying . with the motor out you can do it easily plus check or replace rear seals and check for anything else that might not be visible with the motor in the car
Sep 16, 2010 | 1987 Ford Mustang
Dropped my iphone and screen went white
Take it to the apple store. Even if it is not under warranty the guys at the genius bar should be able to fix it.
Aug 03, 2009 | Apple iPhone Smartphone
Phone does not allways make the ringing tone
i presume the phone you are having problems with is cordless... take it and drop it into the main phones base for a couple seconds and try it then... also make sure the ringer is not off
Robert
Jan 26, 2009 | Lands Phones
Treo 600 dropped calls
Try hard reset your phone
Dec 15, 2007 | Palm Treo 600 Handheld
One For All URC-3021 Remote Control Logo
164 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
