Question about Simplex Kaba Ilco Unican 1000 keyless lock
Want to reprogam keyless lock unican push button lock please advise ------thankk you...
    President:
  • 2,692 Answers
Turn knob once. Put in present combination. Open screw on the top, Use a small rod or drillbit  that will fit into the hole. Press straight down on a lever that is inside of the hole,until it clicks. Turn knob completely(once) to clear old combination. Put new combination in, making sure that a click is heard upon pressing each button.  Try knob with both the old and the new combination. Each digit may be used only one time in the combination.
Posted on Mar 05, 2009
  • Kirungi Patricia
    Kirungi Patricia Feb 09, 2014
    no it didi it, i turned the knob lock jet it has no battery in it
  • Kirungi Patricia
    i have managed to open,used the key n kept rotating the nob
Unican LL1011 lock - the code opens the lock correctly. If a wrong button(s) is pressed the lock does not open as I would expect but when the correct code is entered it then fails to open
I recommend that you contact Kaba Ilco with this problem--there may be nothing wrong with it at all, but you need an answer.
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Jan 28, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
I would like to see a schematic/drawing of the interior mechanical (non-electronic) push-button lock. is there one available?
I have the entire schematic and parts list saved, and it is 10 pages long. Send e-mail to Allaccesslocksmith@yahoo.com and I will send the entire file to you.
Jan 09, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Simplex unican L1000 lock, occasionally the top two buttons do not 'connect' when pressed. Can this be remedied easily?
Nov 11, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
How to reset codes in Kaba ilco Unican 4000 access control
I have a Unican 4000 series door lock and need to find code for it
Dec 20, 2009 | Locks & Locksmithing
Lost code for keyless unican lock
I just performed this on my lock and it's quite simple. The instructions are in the attached manual.
http://www.kaba-ilco.com/access_control/access_download.aspx?File=simplex_1000_installation_instructions_d8_pkg_2280.pdf&Attachment=True
Cheers.
May 16, 2009 | Simplex Kaba Ilco Unican 1000 keyless...
I need to change the code on my unican ll1011
Copy this address into the address bar on your web browser http://www.tharstonconsultancy.co.uk/html/body_code_change.html You will find detailed instructions for the change. Please rate this answer,thanks.
Apr 11, 2009 | Simplex Kaba Ilco Unican 1011 keyless...
Unican keycard door locks at hotel
unican card machine its keep giving a invalid card error read on main card but bellman card works though
Jan 14, 2009 | DG Gold / Brass 98 Biometric Keyless...
Simplex Kaba Ilco Unican  1000 keyless lock  Logo
823 people viewed this question
Top Simplex Locks & Locksmithing Experts
Frank Mangiapane
Level 1 Expert
Michelle Balcom
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
