Question about Samsung HCN436W 43" Rear Projection Television
Samsung hdtv1080i saying check factory data self focus nt wkg
My samsung hdtv 1080i is not coming out with a perfect colour the self focus is not working also it is saying i should check factort data
Hope this link helps mate,
Posted on Jan 05, 2009
I have a samsung hdtv 1080i that has sound but no picture
It means you covergence setting not ok.use remote press (mute183) set covergence lines remember before you save these setting press self focus botton in remote and exit by smode
Jul 24, 2009 | Televison & Video
Projection is off and blurry
change theconvergence amplifiers STK 392-040 also check all resistors in the convergence circut if you want to test it first press MUTE 183 on the remote "DO NOT PRESS ANY ADJUSTMENTS AS YOU WLL TOTALLY SCREW UP THE PICTURE THIS IS ONLY SO YOU CAN SEE WHAT THECONVERGENCE IS LIKE"
Jun 10, 2009 | Samsung HCP4252W 42" Rear Projection...
PS3 display problem for multiple TVs
try to do a simple reset it will reset your video settings just turn it off then hold the power button then KEEP HOLDING until it beeps 2 times then it should come up note: it will not delete any of your data
Mar 04, 2009 | Mitsubishi WD62627 62" HDTV
Self focus not working on samsung 5065w 50 inch asking to check factory data
As ima_rm2000 noted, the HLN is manual focus.  There is a focus ring at the base of the lens assembly.  Here is PDF of the focus assembly.  You have to remove the back of the set to access this, and tape/tie the lamp door switch closed so the TV will power up so you can focus it.
Jan 12, 2009 | Samsung HLN5065W 50" Rear Projection...
Perfect focus reads "no sensor data"
hope this helps check out this above links
please check out this links
for convergence board ics reparing it your self
and for convergence settings
Oct 09, 2008 | Samsung HCM5525W 55" Rear Projection...
Check Factory Data after fixing convergence and resistors
Plugs on the chassis coming from keyboard and side video input are switched (they have same plug)
redoo convergence save and auto focus in factory mode after switching plugs
May 02, 2008 | Samsung HC-P4752W 47" Rear Projection...
Now What???
I want to get this straight are you saying that you cant align them
and this is your focus problem or you have two problems that you cant get the convergence and the focus?
it might have been easier just to have the board replaced...
Samsung parts for convergance problem
Jan 28, 2008 | Samsung HC-P4752W 47" Rear Projection...
Wierd problem
HD projection televisions have seperate convergence alignment for 480i-1080i thus your problem when you use your XBOX360. The "No sensor data" that shows up is due to the fact that the sensors need to be initilized after doing the convergence in 1080i mode. You will probably need a technician to do the alignment because if it is out that much then a template needs to be used to get it corrected. For now you can put your XBOX in a lower display mode until repairs are done.
Jan 30, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN436W 43" Rear Projection Television Logo
587 people viewed this question
Jerry Greenberg
Jerry Greenberg
