Question about Kenmore 96212 / 96214 / 96219 Electric Kitchen Range
After using my electric range self cleaning oven an f90err appeared and the door will not open. I would really like to cook my new years dinner .Can you help please ?
  • 15,935 Answers
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%^
Posted on Oct 01, 2010
Has anybody had the problem of the oven door staying locked and won't open after cooking and has cooled down for several hours?
The oven door lock should only lock during self clean only. SHould never lock during normal oven functions. While in self clean because of high temps, the door lock will remain locked for safety reason until the temps drop to about 350 or so then release. Thats how the lock system works. If you select the normal bake mode and your door locks you may need to have the latch adjusted or the unit checked for problems. Good Luck
Apr 01, 2016 | KitchenAid Kitchen Aid - KERS505XSS...
I'm in the middle of cooking dinner and I got a f3 e2 error and the oven locked...how do I get my dinner out? My husband is an elevator mechanic so he's handy...we turned off the breaker to quit...
That code refers to the oven temperature sensor sensing a too hot oven. I suspect what you did to quite the cleaning cycle should help once the temperature cools down the door should open. I am a little confused, did you set the oven to clean while your cooking, or did it do this on its own, or was it preset and yopu forgot it was set to clean? Your temp sensor may be going bad if it just detected a too hot oven while your cooking. If it started cleaning then it may have gotten too hot and this is the safety device to prevent it from overheating. it sounds like it is trying to self clean, its essential that you find the error code sheet, stuck in the stove or oven cabinet somewhere, also check your range settings so that it is not set to auto clean.
Jun 28, 2011 | Ovens
At the end of the self-cleaning cycle, the Locked Door message is still flashing; thus, we cannot turn on the oven for use. Help - we are hosting Thanksgiving dinner!
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 25, 2010 | GE Spectra JBP78 Electric Kitchen Range
When I was cooking dinner and went.. when I was
did the clean lock get pushed to lock it ,let the oven cool down and it well unlock. it should open at about 100 degrees
Jul 21, 2010 | Crosley CE35111AA Electric Kitchen Range
Whirlpool oven door won't open.
You can try unplugging the over for a while and seeing if that helps. But if that doesn't help you will have to let the oven complete the cleaning cycle in order to regain use.
Jun 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I accidently pressed self clean instead of boil on my oven
Hi
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
*On -some- Frigidaire built ranges, the switch is located behind the right hand side panel and activated by the right hand door hinge. On this model, the side panel may need to be removed to access a malfunctioning door switch.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 27, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Manual lever to lock self clean oven wil not lock
After sliding latch to its locking position did you press the self clean button on the control panel?
Mar 31, 2009 | GE Hotpoint 30" Self-Cleaning Freestanding...
Oven door staying open about 1 inch
your going to have to replace both the door hinges, since they have been over extended past ninety degrees they are not able to close to ninety degrees. that is the only repair, i would also look closely at the inner door panel and make sure that is not "crowned" or bent from the force that might also need replacing
Nov 19, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Self cleaning caused interior glass to crack
hi there,
this is called thermal breakage. basically, when the mfg. makes the glass, they either don't cook it long enough or let it harden long enough during manufacturing. remember, the glass is supposed to withstand over 1200 degrees, which is temperature during self cleaning. have a technician replace the door glass, as warranty should cover this.
thanks
Sep 26, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Kenmore 96212 / 96214 / 96219 Electric Kitchen Range Logo
204 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
