Question about HP Pavilion dv6000z Notebook
HP Pavillion dv6121tx 15.4" notebook problem with DVD Drive
Configuration: WinXP SP3 & IE7
Recently re-formatted HD and reinstalled WinXP from scratch. All working alright apart from the DVD player. I can still play DVD movies and audio CD songs without any problem like before. However, I have problem running software CDs and some audio CDs. I cannot run installation CDs anymore. Is this the indication of the DVD Drive problem or registry problem. This is the internal DVD drive. Please help.
ptiew
  • ptiew Jan 01, 2009
    To Smithbrother
    The DVD Drive/Player is seen on the screen because I can still play most DVDs but not all CDs.
    No error messages. The drive tried to
    read the CD (by making the crackling noises) and after a while it just
    stops. On the Window Explorer right hand screen - nothing appeared,
    just blank. I tried to run one installation CD for a number of times
    and out of 10 times, the drive managed to read 1-2 times. It reads some
    CDs but not all but so much all DVDs are readable.
    However,
    when I "unchecked" the following and click the drive (i.e. E Drive or
    the DVD drive) in window explorer, immediately the error message "E:\
    is not accessible the request could not be performed because of an I/O
    device error"
    Right click DVD drive i.e. E Drive -> properties -> recording -> Enable CD recording on this drive
    I
    tried to "clean" the laser len/eye using the CD cleaning disc which I
    purchased from the PC store but not successful because basically the
    drive cannot read the cleaning CD unless I can find a cleaning disc in
    DVD format.
    If replacement of the drive the only solution?
    Thanks.
    ptiew
  • Thomas F. Schneider May 11, 2010
    Have you gone into your setup screen and make sure that the DVD player is seen ?
    President:
  • 2,692 Answers
I am stumpted. I am not sure. normally if a drive cannot read a disk and all of the software and drivers are correct then I would say that the drive head is out of alignment . Pasify me if you will and restore you computer to the time before you stared havign the problem just to insure that it is not software.If it reads DVD's it shoud also read cd's.?
Posted on Jan 01, 2009
I have a HP 6735s laptop with AMD Turion X2 processor. During the installation new operating system WinXP with SP3, it stop on installing devices with darkness on the screen. After a few try it stop always...
this is a very common problem... there is a lot of literature out there... thankfully your hard drive and memory aren't shot... its a glitch... here is the link to the work around http://msinfluentials.com/blogs/jesper/archive/2008/05/08/does-your-amd-based-computer-boot-after-installing-xp-sp3.aspx
Jan 03, 2010 | Computers & Internet
Tip
How to change your winxp sp2 to sp3
there is some games you can't play in winxp sp2, like gta IV online.
you have to reinstall or format your computer just to turn your operating system in winxp sp3, just to play this game. do'nt waste your time to format or reinstall your hard drive just follow this quick step
Step 1: Run Regedit by Clicking on Start -> Run , type in regedit and press enter
Step 2: Make a backup of your registry (just in case)
Step 3: Browse to "HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlWindows"
Step 4: Modify the value of "CSDVersion" from "0x00000200" (SP2) to the Windows XP SP3 value of "0x00000300"
Step 5: Close registry editor
Step 6: Reboot
Step 7: Start GTA and freakin enjoy it already!
on Jan 16, 2010 | Microsoft Windows XP Professional SP2
My HP pavillion dv9000 just died 2 days ago and it's out of warranty. It appears I have the same issue with the motherboard as everybody else, key booard lights come for 2 seconds then it goes dark. I...
You can get a drive enclosure for the SATA drive that is in the PC, and copy your files to the new PC via USB. You can get them for about $15, and it will take no more than a half hour to install. Then, after you get your files off the old drive, you can format the drive, and use it as a portable external drive that would come in handy for doing backups. Everyone should keep at least two copies of their precious files.
Dec 17, 2009 | HP Pavilion dv9000z Notebook
HP pavillion DV6500 CD/DVD RW not responding, unit will try to boot up many times when system is starting but when I put in a CD or DVD no response and doesn't show a drive in My Computer. I've opened up...
Turn off the Notebook remve all the peripherials, Remove battery and disconnect AC Adapter and then press and hold down power button for thirty seconds.
After 30 Seconds connect Battery and Power supply as soon as you tun on the Notebook keep on hitting F10 Notebook will show BIOS then F9 Notebook will show Load Set-up Default than Hit yes and Hit F10 again it will show save Exit and chnages now that show Fix the Problem
If not than use Philip Screw Driver take out optical drive and put it back in Reinstall CD/DVD Drive drivers using Device Manager .
Thanks and Regards
Neeraj Sharma
HP and Compaq Notebooks Expert
Oct 08, 2009 | HP Pavilion dv6000z Notebook
MX6426* - WINXP ME w/sp3 - F11 loop
hi, ipresume u have hooked it up to another PC using a external S-ATA-USB- case, so that the PC recognizes your drive as one of his, but u are unable to boot from it,as it is handled like a thumbdrive.
can u access the data on the disk?
if yes, make a safecopy of everything personal,
you may even try to make a back-up using the
win-back-up function, just to have a complete copy of the harddisk...,
then format drive(blank it) and put back into laptop.Now setup a new clean copy of WINXP
and yes, you may have to reinstall all the drivers+progs+private data as well...
I hope this option works for you.
Jul 20, 2009 | Computers & Internet
Hp pavillion dv9000- cd/dvd rw drive not working
you have to send it back to hp to get it fixed, this is the second time mine had the same problem
May 10, 2009 | HP Pavillion DV9060US Notebook
Hi
It sounds like a hardware fault on the drive itself. The laser and focussing mechanisms are different for CDs and DVDs. The fact that the drive can read DVDs fine suggests that the laser and lenses can no longer focus correctly to deal with CDs.
Replacement of the drive would be the only fix, although you might find it a lot easier to buy an external USB DVD drive.
Dec 31, 2008 | HP Pavilion dv6000z Notebook
HP Compac NX5000 wont load XP Home on new hard drive
This situation leads me to believe that the CD or DVD drive is faulty,,or the install disc you are using is scratched or dirty.
Try cleaning the disc and begin again.
Another option is to take the hard drive out and using a 2.5 to 3.5 inch HD adapter ,,plug into a desktop PC as a slave.
And copy your WinXp cd onto a partition on your laptop HD.
Then using a Win98Se floppy boot disc you can access the winXP and install from there.
Nov 12, 2008 | HP Compaq nx5000 Notebook
HP Pavilion dv6000z Notebook Logo
150 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
