Question about Solis Crema SL-70 Espresso Machine
Need a new water container
Dropped the water container and of course busted a chunk out of the bottom corner. Not sure super glue will fix this one! Does anyone know where I can purchase a new one?
I bought a Solis replacement water reservoir from Green Beanery in Canada a few years ago. They sell replacement Solis parts, but I'm not sure if they still carry the water reservoir. I had a hard time finding online merchants who sold Solis reservoirs.
Posted on Aug 02, 2009
Windshield washer not working
Antifreeze washer fluid? Pump not working? Switch not working? power to pump? Ground connection rusted, therefore incomplete circiut? Fuse to pump?
Mar 04, 2015 | 1997 Cadillac DeVille
How do i remove super glue from hand or skin
Super Glue is a cyanoacrylate adhesive. It's impervious to water, but can be dissolved with an organic solvent, such as acetone. Some nail polish removers contain acetone, but be sure to check the label, since many acetone-free products are available and will not work against Super Glue. It's also possible to find pure acetone in stores that sell home supplies or art supplies, because acetone is a useful solvent.
Sep 10, 2014 | 3M SCOTCH SUPER GLUE GEL - AD119
My beanie boo has super glue on its eye and I need help removing the glue
Since the eye must be made out of resin, try putting the beanie boo in the freezer. the super glue will start to come off and you can just put the toy in hot water afterwards. It might work, but i'm not so sure. hope this helps.
Feb 18, 2014 | Ty Beanie Boos - Cleo and Bubblegum - Uk...
I spilled some super glue on a urn and melal name plate
super glue will be removed by nail polish remover or acetone Be careful if there is paint work involved as it may affect the paint.
Jan 17, 2014 | Pets - Others
Bottom left side of computer is coming off
If you cannot use a screw to fix the base then use super glue. Just place a small dab of glue in several places along the case. The amount of glue will not affect the will not affect you computer, don't place the glue near any of the connectors.
Apr 29, 2012 | Computers & Internet
DRIPS DURING STEAM PROCESS
Be sure no hairline cracks or pinhole in the steamer water container.
Put enough water level on it and not overfill it.
Repair hairline cracks or pinhole by applying epoxy or super glue in the surface.
Good luck.
Jun 28, 2011 | Rowenta Irons
Slow leak drips from bottom of 4 year old model
Hi
Please try and remove the cap by turning it clockwise and counter clock wise to remove it. If it doesn't come off then empty the water dispenser and use glue to fix the leak. See this link to see which type of glue should be used--- Glue Usage
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Apr 07, 2009 | RTO Waste King AH-780-UL Quick&Hot Instant...
Ice maker water leaking
Is the fill tube in the cup? also is the ice maker the correct ice maker for the unit.
Mar 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
Dishwasher not draining
I had water at the bottom of my 4 year old plus dishwasher and of course I thought the worst. Did the pump go out, bad impeller, or what else could it be! I started with the easy stuff first and disconnected the drain lines. The drain line runs from the dishwasher to an air gap mounted to my sink, which keeps the drain line from getting an airlock. From the air gap device another larger line runs to the garbage disposal. I used an 8MM wrench to loosen the clamps enough to pull the drain lines off and drained them into a bucket. There really wasn't any resistance to water flow and no real chunks, I was disappointed.
I then took the actual air gap out of the sink by removing a large plastic nut and pulling the devise out from underneath the sink. When I inspected the air gap I saw a wad of hairy, feathery plastic stuff blocking the flow of water. I took the chunk out, reassembled everything and it works like new again.
It is a very easy fix and now even the area under the sink is clean to boot.
Jerry
Sep 03, 2007 | Frigidaire 24 in. PLD2850 Built-in...
Solis Crema SL-70 Espresso Machine Logo
175 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
