Just changed the rear pads on above car. in need of bleeding but dont know which order i should bleed the wheels in. can you help please? happy new year!!!!
Generally you can bleed any system by following this method: Start at r/r wheel, then l/r, r/f l/f. Break each bleeder loose, attach a twelve inch piece of clear plastic tubing to it (I use fish tank air supply hose) If hose diameter is too small, generally putting it in a pot of hot water will allow you to strech it over bleeder end.Put the other end in a small jar with about an inch or two of clean fluid in it Keep the hose end submerged at all times while doing this procedure.. When you open the bleeder, fluid should begin to run through tube. (if not, sometimes GENTLY putting some pressure on pedal will start it flowing. Keep the jar below the item you are bleeding...gravity will do the rest. When no further air comes through the line, close bleeder and repeat on each wheel.
While doing this, keep master cylinder full with cap open. When finished, make sure fluid level is full and close it up.
If you have further problems, you may need to inspect all hydraulic components. Generally, since your brake system is essentially "sealed" just changing pads does not require bleeding to make system functional. Changing fluid and bleeding is a good maintenence procedure because brake fluid is hygroscopic (it tends to draw moisture from the air) which causes internal rusting of calipers, wheel cylinders etc.
Good luck
Right rear, left rear, right front, left front. (left hand drivers side)
