Question about Hotpoint WMA50 Front Load Washer
Noise when draining
Hotpoint Aquarius WMA50. Makes an awful loud noise only when draining as if something is blocking the water getting out! Water is also coming back into drum when I leave clothes in that have recently been washed as if its not emptying either - although not all loads. Where is the filter for the thing??
  • Anonymous Feb 10, 2009
    Same problem as "amdonnelly20" noise when draining only.
  • Hotpoint Master
  • 3,463 Answers
U will find the filter by removing the lower rear panel of the m/c.
Locate the large black hose at the right side, and remove clip securing hose. Get some thing ready to catch any water that will be in there, and remove hose.
There u will see the filter, remove and clean, refit filter and hose,making sure that u get the hose on properly, test for leaks before u put the panel back on.
U will find this much easier to do if u tilt the m/c forward, and support it with something underneath.. Check inside the pump as well.
Plz rate my solution.
Thanks.
Posted on Dec 31, 2008
  • Amanda Goldup
    Amanda Goldup Dec 04, 2010
    You are A genius!!!!!!!!!!!!! Machine broke down. All your tips made me believe it was the filter. Yes you cured it.THANK-YOU.THANK-YOU. Could not afford repair bills or new machine this near to christmas. Hubby is not mechanically minder so left it me. But thank- once again your a star.
    Amanda
Hotpoint Aquarius WMA58 washes, spins but won't drain water away !
I would check the filter assembly and the drain line to see if there is an obstruction visible or twist in the line that you could smooth out. The drain solenoid valve could be faulty and just isn't opening any longer. It's an electrically operated valve that makes a rather loud "click" when it energizes to open the drain and let the water flow out.
Dec 28, 2016 | Hotpoint Washing Machines
My hotpoint washer wont agitate spin or drain. it makes a clunking noise when you try to change the cycles manually
The draining problem could be something stuck in the pump. A easy fix just take it apart and get whatever is in it out of there. The agitator sits atop an agitator drive block. The spline on these tends to strip out. Yank off the agitator (it just snaps on) and replace the drive block.
SERVICE MANUAL
My page shows more HERE
Sep 24, 2012 | Hotpoint VVSR1070D Top Load Washer
Where is the water filter kept on the hotpoint aquarius wma50
Remove lower rear panel of washer, locate and remove large black hose fastened to bottom of drum, filter is located inside the hose.
Sep 19, 2010 | Hotpoint WMA50 Front Load Washer
I have a Hotpoint Aquarius WF541 that has started making ean extremely loud noise when on spin. The machine remains still, but sounds like a jet engine. The drum makes an awful noise when I turn it...
maybe it the pulley tensioner came lose.....open up the back of the machine and check if the belt is tight...if not get the spanner out retention the pulley arm and retighten.
Jul 20, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Aquarius WF745 Front Load Washer.Full of water won't drain.
The filter is located at the bottom front of washer.
Remove the kickstrip at the bottom, by levering off.
Unscrew filter anti-clockwise to remove and clean..
Be careful when removing filter, as there will be water come out.Lay the drain hose down into a bowl or similar to drain off excess water.
Please rate my solution.
Thankyou
Jan 30, 2010 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint Aquarius WF325 won't pump out water
Item stuck in pump,open back and take out,unless u r in nottingham i can do 4 u
Oct 06, 2009 | Washing Machines
Drum makes loud noise as rotates clockwise
put few clothes in it drum to switch on its ball in there
Oct 06, 2009 | Hotpoint Aquarius WD63 Front Load...
Hi, i have a hotpoint aquarius 6kg wma50, my
Have you checked for blockage in the pump. Or the have been some problems with a ball that sits in the hose between pump and the drum. This can block the water. Check this berfore purchase new pump.
Jul 26, 2009 | Washing Machines
Indesit wil 113 washing machine
try to put more clothes but not to much it wont banging.
must change door lock switch.
Feb 14, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WMA50 Front Load Washer Logo
300 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
