Question about Sharp AL 1631 Copier
Paper jam there is a reb blinking light that does not go away. There was a peper jam i took the paper out and checked the printer there is no more paper but the light does not go away and printer does not print.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 96 Answers
IS IT THE PAPER JAM LIGHT? LOOK IN THE PART WHERE THE PAPER COMES OUT OF THE MACHINE IN THE CAVITY ON THE LEFT SIDE FIND THE EXIT ROLLERS IS THERE ANY PAPER THERE? PULL OUT YOUR PAPER CASSETTE ALL THE WAY LOOK IN THAT CAVITY. OPEN THE RIGHT HAND DOOR THERE IS A GREEN ARROW THAT MOVES THE GATE LOOKIN THAT AREA. HOPE THIS HELPS IF THESE DO NOT FIX YOUR PROBLEM YOU NEED A TECH TO LOOK AT IT.
Posted on Dec 31, 2008
Without paper jam, the system is showing paper jam ? why ?
try to run Maintenance from windows control panel, also open all compartments on teh printer and look to see if there is a fragment of paper stuck there.
Jul 22, 2014 | Canon LASER SHOT LBP-2900 Printer
HP LJ 4L paper jam light flashes indicating a peper jam after printer makes a grinding noise. What can be the problem?
You may be right about the worn gear as a factor but I used to have a LJ 4 and whenever it indicated a paper jam it was always right. In some cases, the jam was a tiny scrap of paper deep inside. It took a flashlight and examination of every bit of the paper path to find it
Nov 02, 2012 | HP Black Toner for LJ4L & 4P
Paper jams
when on my pinter not accept peper
Oct 20, 2012 | Toshiba DP80F Printer
How to fix paper jam in toshiba dp80f
peper not accept cancon lpb2900 not peper not accept
Sir My Printer hp5600all in one is showing paper jam . peper is turned by right side only .Please Help me as soon as possiblle .
Check the official HP site for a solution in paper jam:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00441807&jumpid=reg_R1002_USEN
Jul 28, 2011 | Office Equipment & Supplies
Printer canon mf 5750 thankyou verymuch
please chack your paper feed sensor i guss it was broken
Aug 04, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Canon MF3240 Paper Jam - No Real Jam
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Dec 18, 2008 | Canon imageCLASS MF3240 All-In-One Laser...
Paper Jammed Message
try turning you printer off and unpluging it from Electrecity.
after that cancell all the printing jobs at your computer.
and last do a double check on the printer to make sure that there are no more paper left-overs into the printer.
try turning the printer on (after pluging to Electricity) and see what happen.
Mar 21, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Printer will not catch paper in tray
The rollers need to be clean or replaced.
Feb 04, 2008 | Dell M5200n Laser Printer
My dell 1700n Laser Printer Paper Jam Light stays on
The sensor is stuck open or closed. It needs to move back and forth between the sensor. Check the paper path for the sensors.
Aug 29, 2007 | Dell 1700n Laser Printer
Sharp AL 1631 Copier Logo
106 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
