Question about Asrock K7VM4 Motherboard
Will run with windows 98, but will not load or reload windows xp
Had been running xp pro, will start to load xp but then resets in both reg & safe mode. replaced ram, replace video card, useing a different hard drive used windows 98 and computer ran fine. tried to reload windows xp, locked up when loading xp. updated the bios.. no gain..
  • 2 more comments
  • Stephen Hall Dec 31, 2008
    When I attempt to enter safe mode the computer resets
    at the current time there are no pci cards in computer, and is running on built in video, problem is with motherboard or cpu.! Question is Why would a computer run win98, but no longer run win xp ?
    As to the computer over heating, if that were true the computer would stop, but it will run windows 98 with out a problem, and it was never overclocked.
  • Stephen Hall Jan 02, 2009
    There are no cards on the mother board, same action
  • 679 Answers
What does it say when yu attempt to install it should boot from cd/dvd drive are you getting the menu that asks you what you want to do repair, install or quit, if you aren't getting to that point then it's a hardware issue, or the disk is flawed. you should clear the cmos as mentioned ans pop out the battery to make sure the old settings aren't fouling up your install, and you should enable booting from the dvd drive not the floppy or hard drive, but that's it really.
Posted on Dec 31, 2008
  • George Bill
    George Bill Jan 02, 2009
    U have to format the drive do a quick format, NTFS, if u had a virus then u have to fdisk or you are just dragging you problem along with u . Wipe the drive first
  • 916 Answers
Please restore the BIOS to factory settings and run the recovery console from your xp cd when the text based part of the setup starts press R. Select the xp installation that you want to access from the Recovery Console. When you are prompted, type the Administrator password if you have not set one by default it is blank. Then type chkdsk in the command prompt /(windows xp drive letter), do not type a drive letter if you want to check the current disk. Please let me know the results once you have done this.
  • 6,487 Answers
Try to reset your CMOS ,and then after that try again to reload XP to your computer.....
    President:
  • 2,110 Answers
Remove all PCI CARDS IF u have inserted any .....then boot into safe mode...
Hello. I recently bought a new motherboard, fmb-0703; and windows will not load. It starts, but does not fully load. I'm running windows 7 pro 32 bit. Bios boots, every works except windows
I could be a couple of things. If it is not loading correctly More than likely something to do with memory either motherboard ram or video ram. try a live boot cd and see if it loads like hirams boot cd with live windows. it is free. also you can the motherboard and ram and hard drive the the live cd to pinpoint hardware problems. just a thought. good luck.
Jun 01, 2015 | Intel Computers & Internet
PC HANGS ON BOOT
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Feb 18, 2012 | Computers & Internet
Boot sequence ok , xp pro starts ok and crash with no warning. Then the system starts again without succes
Please restart the computer and repeatedly tap the F8 key (you need to press F8 before windows starts to load)
A menu should appear. Select Safe Mode and press Enter
Let me know if it able to start in safe mode
Thanks
Feb 22, 2010 | ASUS A7V8X Motherboard
Dell c400 upgraded to xp now it won't boot up
you have toboot xp in the dell they are not interchangable you have load xp withit inthe dell or the dell wont work
sorry to be the bearer of bad news
Dec 21, 2008 | Dell AMD 386/33 Desktop Computer 333S/L...
Unable to boot up after windows xp
If you can get into the BIOS, try setting with default settings.
Dec 19, 2007 | MSI K8MM-V Motherboard
No shutoff
Go to start>control panel>power options>advanced tab, then at bottom it should say shutdown when i press power off button.
Feb 19, 2007 | Jetway P400MTwin Motherboard
Continuous restarting with winxp
On computers that contain Windows 98 and Windows XP: ? Windows 98 must be installed on a basic disk on a partition formatted with FAT or FAT32. If Windows 98 or Windows Me is not installed on the system partition, which is almost always the first partition on the disk, the system partition must also be formatted with FAT or FAT32. ? Compressed DriveSpace or DoubleSpace volumes won't be available while you are running Windows XP. It is not necessary to uncompress DriveSpace or DoubleSpace volumes that you will access only with Windows 98. ? Windows XP must be installed last. Otherwise important files needed for starting Windows XP could be overwritten
Jan 28, 2006 | Intel D850MV Motherboard
Asrock K7VM4 Motherboard Logo
22 people viewed this question
Top Asrock Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
David
David
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
