Back to:
Tags:
Toshiba MD13P3 13 in. TV/DVD Combo
TV wont turn off
posted by Jshu on May 04, 2007
When I push the POWER button to turn the TV/DVD off, I lose the audio and the set doesnt turn off. Further more when I lose audio I cant turn it back up. But when I unplug the set and push the POWER button it all works again. So to turn my power off, and reset my audio I have to unplug the set. Any ideas of what might be wronge? thnx J
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Sep 14, 2007
Not Rated (0)
ilragazzo78
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
IT COULD BE THAT THERE IS SOME METAL DEBRI IN BETWEEN THE TWO BUTTONS ON THE MOTHER - CIRCUIT - BOARD
YOU CAN UNPLUG THE TV
OPEN IT UP
THERE IS I BELIEVE 4 SCREWS THAT HOLD THE BLACK COVER ON THE BACK
THEN THERE SHOULD BE TWO BUTTONS THAT HOLD THE CIRCUIT BOARD
PULL IT OUT VERY CAREFULLY AND LOOK OUT FOR DEBRI.
YOU COULD CLEAN IT WITH DISTILLED ALCOHOL AND A SOFT BRUSH
YOU WILL HAVE TO UNPLUG THE SPEAKER CONNECTOR ON THE LEFT SIDE
ALSO ANOTHER CONNECTOR THAT COME FROM THE TUBE
HOPE THIS HELPS
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on TV wont turn off:
I don't want to Accept this solution
Can you Help with these TV Combos problems?
TV Combos
my tv comes on the only thing that it will do is samsung...
The TV does not display a picture nor is there any sound....
control remoto is original but not work. the pulse enter...
The codes given by direct tv don't work on my model MD13P3...
Hi, You know that the codes given by direct tv don't work...
Loading problems.
Repair Service
Find TV Combo Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
