Question about Panasonic NN-H965 Microwave Oven
Turntable motor How do you change a turntable motor ina panasonic microwave oven model NNS960
  • Panasonic Master
  • 9,086 Answers
You can find a helpful exploded view here.
The best place to order parts for this brand is Tritronics. Or you can call them toll-free at 866-779-5835. Their Web site will be down until Jan. 2nd.
You remove the bottom cover, then there are two screws holding the motor in place.
Here's my generic help file:
NOTES ON REPLACING TURNTABLES & COUPLERS
Copyright 2007 by William E. Miller - MicrowaveDisplay.com
UNPLUG THE OVEN FROM THE WALL FIRST OR YOU WILL EXPOSE YOURSELF TO LETHAL VOLTAGES!
Note that I am not encouraging you to work on electrical items if you are not qualified, and I assume no liability for any consequences of your decision to do so.
When replacing the turntable coupler on most models, it is necessary to loosen or remove the screws that mount the turntable motor to the bottom of the chassis.
It is usually easier to do this with the microwave oven on its right (heaviest) side because you will need two hands for alignment.
Be sure to put a towel or similar cushion on the work surface to avoid scratching the oven wrapper (oven cover) or the work surface.
It is not necessary to remove the wrapper or the wires from the turntable motor itself, but you may need to remove a small metal duct covering the turntable motor if your oven has one.
It should only be held on by one or two screws.
Although a broken coupler may come out easily or even fall out, the new coupler will not go in without at least loosening the turntable motor.
Look at the hole in the new coupler. You'll notice it has (most do have) a flat side to it. That flat side will line up with the flat side on the motor shaft.
When the old coupler is out and the motor is loose, you can ease the new coupler in the hole with one hand while turning the coupler very slightly back and forth as you gently push the motor toward it. Do not force the part in.
When the coupler has mated properly with the motor, you should feel it go in.
Be sure it's right, or you may break the new coupler or bend the mounting ears of the motor when you attempt to tighten the screws.
Reassemble in reverse order.
Posted on Jan 01, 2009
Turntable for microwave model#nnt945sfx
The cooking tray and roller for the NNT945SFX are available from Panasonic on the microwave's product page under the accessories tab. See http://shop.panasonic.com/support-only/NN-T945SF.html .
The parts list from Partstore.com is fairly complete: https://www.partstore.com/Model/Matsushita/Panasonic/NNT945SFX.aspx . The cooking tray for the NNT945SFX is part number F06014M00AP. It is available here: https://www.partstore.com/Part/Matsushita/Panasonic/NNT945SFX/Matsushita/Panasonic/F06014M00AP/New.aspx . The roller that goes under the glass tray is part F290D9330AP. That is available here: https://www.partstore.com/Part/Matsushita/Panasonic/NNT945SFX/Matsushita/Panasonic/F290D9330AP/New.aspx . The motor to run the turntable is available as well.
I hope this helps. Other vendors will have the tray and roller as well.
Nov 30, 2016 | Panasonic Microwave Ovens
How do i change the turntable motor on my sears microwave
Most microwave ovens have a door on the bottom of the oven to access the turntable motor - I am not familiar with a Sears in particular, but if the door is not already cut free and held with a screw, it could be like a Panasonic Microwave whereby you have to cut through side-by-side holes to create your own door on the bottom - then you should be able to access the motor and remove it's screw(s) and wires - It the door is one you had to make, then they will have it created so you have tabs to line up, but you need a screw to hold it in place
May 10, 2014 | Panasonic NN-H965 Microwave Oven
How do i change the turntable motor on a sears 72163259301
Go to the bottom of the oven - they have several side-by-side holes that when you cut through the little bit of material between the holes, allows you to create your own door - inside should be your turntable motor - Again this is a standard type location - Commercial units may not have turntables, but the 'stirrer' is instead located below the plain table on which you rest your food
Panasonic NNA873SB, turntable is no more turning
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can order Panasonic parts from Encompass here or you can call them toll-free at 866-779-5835.
Dec 04, 2013 | Panasonic NN-A811A Convection/Microwave...
Panasonic microwave plate not rotating
Hi and Welcome to FixYa, I am Kelly.
Your microwave turntable motor is either stuck or has failed. These motors are quite frail internally. Without a model number I can not give you the correct replacement part number. There are 7 different turntable motor part numbers for Panasonic Microwaves. Note that 5 of the 7 part numbers are NOT available and the other 2 are out of stock with a 7 - 14 day back order using my resources to search for the parts. There maybe universal turntable motor I could point you to but again it depends on your model number.
Thanks for choosing FixYa,
Kelly
Mar 11, 2011 | Microwave Ovens
The turntable on my NN-A554 microwave won't rotate, could it be the belt?
You require a new turntable motor. Easy enough to fit from underneath the cavity.
Ask a dealer for the turntable motor, they are relatively inexpensive.
Dec 27, 2010 | Panasonic NNA554 Convection/Microwave Oven
Microwave oven
Check first the motor coupling under the turntable, if that is not the problem , then test and eventually replace the turntable motor.
Click here and select model to get parts and diagrams.
Nov 01, 2008 | Emerson MW8777W Microwave Oven
Panasonic NN-H965 Microwave Oven Logo
303 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
