Question about Aiwa XR-DV700 System
I can play cd's ok, but not dvd's.
The dvd spins as if it is going to start playing, then just gradually stops and I get a disc error message on screen.
CD's are playing absolutley fine though.
  • 4,234 Answers
This is a classic sign that either the lens is dirty or that the optics are starting to fail. If you can get access to the optics assembly, try carefully cleaning the lens using a coton swab and alcohol. If that does not resolve the problem, the optics will need to be replaced.
Posted on Dec 31, 2008
At your own risk obviously... I have two of these units and have the same problem on both. Just tried to source a replacement optical block to no avail. While I was looking for a solution, I tried just cleaning the dust off the optical lens with a cotton bud. While I wiped around the lens I had a hair drier pointed at the area. Then used the other end of the bud to remove the dust from all of the area surrounding including the bits of exposed metal. Didn't go back to the block with the same end of the cotton bud as the area surrounding the lens has electronic grease/oil on it. Popped a DVD in and problem solved. Hope this helps. David
Posted on Sep 21, 2009
Technics SL-MC60 error message: "Take out"
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
Feb 03, 2012 | Audio Players & Recorders
DVD Player stops reading disc Error message :
usually this happens when lens cannot read the the disc. Due to few reason 1 Your disk is scratched 2 Your DVD lens is covered with dust 3 You need to replace DVD lens
Try another few CD/DVD to rectify whether there is any problem with dvd you are trying to play
if this error occurs on all the dvd you played then the most likely proble is with your DVD lens either its coverd with dust use Disk cleaner if not you got to replace a new DVD lense as per model
Feb 18, 2010 | Samsung DVD-V9800 DVD Player/VCR
Disc spins, then " Type of disc can not be played" message
it means the format of the type of cd u put in cannot be played by the system.
try playing the disc it on another player, if it does the same, it means the disc cannot be played. some players dont play mp3 format, blu ray, and some others, so you can check the kind of disc you want to play on it.
Feb 03, 2010 | Panasonic DVD-S25
Disc Error when I try to play a dvd LG DP781
Sounds like either a dirty or weak laser/lens. Pls try cleaning with a CD disc cleaner or manually using cotton buds (if the eye is accessible).
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 17, 2008 | LG Televison & Video
CD/DVD drive stopped working gradually
  1. Ensure the Drive is seen in MY Computer
  2. Try removing the upper and lower filters per this article:
If the drive is seen in BIOS and in MY COMPUTER, but will not read any media after running the microsoft fix and rebooting, then replace the drive.
Jul 06, 2008 | Dell Inspiron 4000 Notebook
DVR 120 Disc/Screen freezes half way through
CD does not run
Clean lens and adjust the disk level
Not spinning disc
If it spins with a little help from yourself replace the spindle motor with improved motor, part number: RXQ0749A
This fault would only occur on c.d play back. The sound would gradually start to distort, until all that could be heard was complete distortion. This fault was intermittent and would occur whenever it felt like
Believe it or not,this fault was cured by replacing the optical unit
Nov 24, 2007 | Samsung DVDR120 DVD Recorder
Dvd player not working
buy new one then replace it with the old one and take it back for refund
Oct 30, 2007 | Durabrand DVD-1002 DVD Player
Disc error message
Computer Burned discs are a grey area for some players[different firmware/chipsets] There is a list on the web of players and what they will play a Google/Yahoo will reveal. Also checkout the manual that came with the player.
Jul 01, 2007 | Sony RDR-GX300 DVD Recorder
Check disc
Change your DVD player
May 23, 2007 | LG DE9523P DVD Player
Aiwa XR-DV700 System Logo
141 people viewed this question
Top Aiwa Audio Players & Recorders Experts
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
