Question about Cooper Lighting Lighted Switch
How to connect light switch
I am replacing light switch and need help. the old has red, white and black wires. the new cooper switch has a green and two brass screws with a red painted area at the top. does the white go to the green screw and the red and black go to the brass screws?
  • bigarm Dec 31, 2008
    Thanks Dan
  • Anonymous Mar 27, 2014
    I don't have two brass on right side one brass one black the left side says lighted and has a brass screw
  • 4,234 Answers
Nope, you have the wrong type of switch. The old one is what is called a 3-way switch. You need to purchase a replacement 3-way. The switch you currently have is a standard on/off switch and can not be used in that situation.
Dan
Posted on Dec 31, 2008
I have an old easyset E-600VA dimmer connected on single pole to a ceiling light. I want to replace that with a new Leviton toggle switch with dimming slide.
red never connects to black as that is power to neutral if wired correctly
get in a qualified electrician to check the wiring and help you install the unit
Apr 30, 2018 | Leviton Electrical Supplies
Motion sensor light wiring
problem could be sensor, not light, black is power, white is neutral, green is ground, sensor may have a red wire, black wire and a white wire, hook black wire to power from sensor, red to black wire on light,
white wires will connect together, then wire black to power on home, white to white on home and green to ground, if you need help call an electrician and they will wire it for you
Feb 03, 2012 | Home
I have a Cooper 4 way switch, 7504v, and I no onger have the box with the schematic of how everything should be wired. I've searched online for too long and can not find a reprint of the interior of the...
4-way switch has 2 dark screws and 2 brass screws and 1 green screw.
Bare ground wire connects to green screw.
As general rule, 2 cables enter box.
Each cable has black and white wire, or black and red.
Black and white from one cable connect to dark and brass screw on side of switch, with either wire to either screw.
Other cable connects to screws on other side of switch, with either wire to either screw.
http://waterheatertimer.org/ST01C-program.html#4-way
Apr 17, 2011 | Cooper Industries Cooper Wiring 4way Ivry...
Cooper Industries Cooper Wiring 274W Switch and Outlet I need help installing this switch/outlet combo...I have 3 wires...a black, a red, & a copper. I hooked the copper to the green terminal, the...
Switch-plug combo:
bare ground goes to green screw
dark screw goes to hot from breaker
silver screw to neutral
brass screw goes to load (light)
Add a comment any time
You are replacing single pole light switch?
Single pole switch has 3 wires: black and red and bare copper
New device has 4 different colored screws: green, dark, brass, silver
Bare copper goes to green screw.
Black wire goes to dark screw
Red wire to brass screw
Nothing on silver screw for a moment. Test circuit and make sure light turns on-off.
If lights works, then good so far.
Now let look at silver screw. Neutral wire has to connect to silver screw.
In back of your electrical box are white wires twisted together and covered with wire nut.
These are neutral wires.
You must connect another short piece of insulated wire to these neutral wires and run that wire to silver screw.
The neutral wire will complete circuit to receptacle.
If you do not have neutral wire, then receptacle will not work in that box without additional wiring.
Hook up neutral wire to silver screw.
Now turn on power and click switch again.
If circuit breaker trips, then reverse your red and black wires.
Otherwise this should be correct wiring.
Dec 08, 2010 | Cooper Industries Cooper Wiring 274W...
I would like to use the 1301 switch but my house circuit has 2 black wires and 1 red wire which terminals do I connect the wires to on the switch?
I don't know the copper-brand 1301 switch
Internet photos of the 1301 show that it has two screw terminals, and a green ground screw
Switch with 2 screws is a single-pole switch. (plug green ground screw)
Sounds like you are replacing 3-way switch with 3 screws. (plus green ground screw)
3-way switches control hallway lights, with switch at each end of hallway.
I think you need to buy a 3-way switch.
How to wire 3-way switch:
Bare ground always goes to green screw
The key is the dark-colored screw.
Old switch has dark-colored screw >> mark this wire.
Attach this wire to dark-colored screw on new switch.
Other two wires go to either screw.
Nov 19, 2010 | Cooper Wiring Devices "COOPER WIRING"...
Am replacing an old wall timer with a GE Smart Digital Timer. The old timer had two black wires connected to two black wires from the wall. The new timer however has red, black, white and green wires. I...
I've tested these timers.
Here's what to do:
1) Connect green to bare copper
2) Switch has 2 wires. For now, connect these two wires to timer-black and timer-red. Choose either one.
3) In back of wall box are white neutral wires twisted together and covered with wire nut. Timer-white wire connects to these white neutral wires. This action gives power to time clock.
4) If wall box does not have white neutrals described above, then connect timer-white to bare ground wire. Bare ground connects to neutral busbar in breaker box.
5) Turn on power and click manual override button or switch. If lights turn on, timer is wired correctly. If lights do not turn on, then reverse timer-red and timer-black wires.
Nov 16, 2010 | GE 60minute Automatic ShutOff Timer Switch...
New switch GE model 15265 ... to light up 2 lightbulbs outside. Old switch all cables are black. Those who light up the tester are the hot=Red/black?? Those which do not light up are white?? Green I know...
Manual for GE 15265
http://waterheatertimer.org/pdf/GE-15265-manual.pdf
15A timer works fine on two bulbs, up to 1440 total watts.
If old switch has 2 screws plus green ground screw, then timer is right.
If old switch has 3 screws plus green ground screw, 15265 doesn't replace 3-way switch.
Timer-green wire connects to bare ground wire
Old switch has 2 screws with wires on each.
One wire is Hot-from breaker and this connects to timer-black wire.
One wire Goes-to-lights and this connects to timer-red wire.
If you get these two wires reversed, timer will not work, so reverse them.
It will not blow circuit if the timer-red and timer-black wires are reversed.
Timer-White wire is the confusing wire for everybody:
Timer-white wire runs clock motor located inside timer.
In back of electric box are neutral white wires that are twisted together and covered with wire nut.
Connect timer-white to these neutral wires.
If box does not have neutral white wires, connect timer-white to bare ground wire.
Nov 13, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Trying to replace Intermatic with Utilitech inwall timers. Have 2 black wires in wall box with other switches for other lights. Which of the Utilitech 4 wires- black, red, white & green get conected to...
The wires on your new switch are intended for black = power .. white = neutral . and red = lights .. with two black wires on the old switch I am assuming that there is a bundle of white wires in that wall box, the white timer needs to join that bundle ... then you need to determine which black wire is the power from the electrical panel ( voltage tester) and connect to the black timer wire .. the red timer wire connects to the other black wire in the wall..
Please Vote !!
Apr 08, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
The 3-way dimmer switch has 4 wires; 1-red, 1-yellow, 1 green and 1 black. Hot wire coming in is black, ground is bare and neutral is white. Wires going out are red,black,bare and white. What does each of...
Incoming white - outgoing white This is the neutral, which just passes through without connecting to the switch
incoming black - switch black the hot wire provides power to the switch
switch red - outgoing red a traveler, will have power when toggle is one position
switch yellow - outgoing black
the other traveler, will have power when toggle is in the other position
incoming bare - switch green - outgoing bare the switch is grounded and it passes through
If this was helpful, please vote.
Mar 21, 2010 | Cooper Wiring Devices Three Way Grounded...
Cooper Lighting Lighted Switch Logo
946 people viewed this question
Top Cooper Lighting Electrical Supplies Experts
Craig Butler
Craig Butler
john h
Gene Haynes
Are you a Cooper Lighting Electrical Supply Expert? Answer questions, earn points and help others
