I have a Zenith R60v26 with a convergence problem. so I replaced the IC's and now the problem isn't as bad. the red and green seem to have fixed, but the blue is still out of wack. After revisiting the convergence board I found one resistor to be discolored and looks burnt. I removed the resistor and took a reading of (145k ohms) the bands are: brown, black, gold, gold (Which is a 1 Ohm resistor) from what I can tell but they are discolored a bit.
Can anybody tell me what resistor is supposed to be at RK54?
Model: Zenith R60V26
Board :DP1X CONVERGENCE PWB
JK07132 A
Comments:
Jan 14, 2009
- I found the resistor was indeed a 1 Ohm resistor on this particular convergence board at location RK54. I replaced the resistor and now the blue convergence setting is fixed.
Hello, I have the exact same issue with my R49W36, I replaced the convergence chips but there are also two 1 ohm resistors with the same color pattern as yours that are bad. I have looked all over and cannot find a 1 ohm resistor anywhere. Where did you find it?
will not power up ............hit the on switch nothing happens.........hear a click...
(More)
will not power up ............hit the on switch nothing happens.........hear a click sound............42 projection 6 years old
the lower left hand corner shows some yellow and I want to know how to restore the tv to the...
(More)
the lower left hand corner shows some yellow and I want to know how to restore the tv to the manufacturers original settings.
