Question about Philips 55PW9383 55" Rear Projection Television
Picture issues I have an intermitten problem with my picture on my Philips 55PW9383 TV...On the top 8 to 10 inches of the screen, I have lines going straight across and at the bottom, I've got a blue streak that almost looks like a paint brush stroke. If it happens when I turn it on, I cycle power and it will go away. Any help would be appreciated!! Thanks!
  • Michael Metric May 25, 2007
    Thanks Bill, I have a buddy who used to work on TV's, so I'll have him give me a hand. I'll let you know how it works out!!
    Mike
  • 934 Answers
It sounds like a convergence issue and possibly the amps themselves going out.. Cycling the unit off/on has me suspecting convergence amps first and possibly poor solder connections in the vert or convergence circuit. However, it could be one other thing, Vertical misadjusted. There is a methid for checking that in the service menu and I'll get to that in a second. The symptoms correcting themselves when you cycle on/off is very significant. I would first check for poor solder connections on the vert IC, and conv. amps. Then test the convergence amps themselves. If all else fails check the vertical adjustment. To adjust vertical enter service alignment mode by using 06-25-96 status, after entering service alignment mode it will be necessary to use the A/V button to get back to A/V4. When in the service alignment mode cursor down to GDE SAM. Cursor right and then cursor down to Geometry. Cursor right and then cursor down to VER. AMPL. then while watching the DVD in A/V4 cursor right or left to adjust the vertical amplitude until the white lines just disappear. Turn the set off to save the change. NOTE: Convergence may need to be touched up slightly after this adjustment has been made. Footnote: mnyce, this is one repair that I would not attempt unless you are fairly skilled at trace testing and knowing what to look for in a given circuit. As always, there are voltages in these areas that could harm you or further damage the unit. I would suggest contacting an honest qualified repair facility and explain your problem to them. Most will have no problem telling you exactly what I have here.. Goodluck. Bill
Posted on May 25, 2007
Have a model 55pw9383/17f that had convergence issues for a while. The reds, blues and greens were all seperated. Now I turn it on and have no picture.
Your convergence has failed and needs to be repaired.You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jun 17, 2011 | Philips 55PW9383 55" Rear Projection...
Visual transparent lines at top of picture
You have a vertical output circuit problem. This was common for Philips' sets. Have a repair shop check it out. Should not be too expensive to repair.
Oct 15, 2009 | Philips 27PT6441 27" TV
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Horizontal lines on top of phillips tv
bad feedback electrolytic in vertical circuit. need tech.
Nov 23, 2008 | Philips TP2797B 27" TV
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Lines at top of screen
I have seen issues with complaints of raster with vertical retrace lines at the top of the picture and capacitor 2494 needs to be removed.
Jul 23, 2008 | Philips 27MT3305 27" TV
32Inch Flat Screen SDTV - with picture distortion
If you have a TV shop at all any more in your area, any tech working on them will know where to look. This is a pretty common problem although you are getting it too early.
Since it will require a certain type of instrument (capacitance meter) to verify the problem part, I don't want to go into detail concerning a 'do-it-yourself' repair since it may be a little difficult to order these in single quantities and a decent shop should have the right value on hand.
It shouldn't cost too much.
Jun 28, 2008 | Philips 30PW633R 32" TV
Picture size is shrinking within screen
hi there, you have vertical section prob., repalce imeditely the electrolytic capacitor at the vertical section. do some test and check up. ty
Feb 18, 2008 | Philips 27MT3305 27" TV
Side shadows on picture
it sounds as if there are speakers to close to the tv or the built in speakers are not magnetically sheilded properly (maufacturer defect) if u have or have ever had speakers on the left and right side of your tv then the magnets in them will discolor and distort the screen. sometimes even long after the speakers have been moved away from the tv it will still look that way. you may try going to the library( or online )and looking in tv repair books on how to build a homade degauser unless your tv has that feature built into it in the menu somewhere like some computer monitors do. I had placed the front speaker of a 5.1 surround sound system on top my tv and it cuased that same problem, but i found out that by placing a small round magnet with a hole in the center on top of the tv (after removing the speaker for good) right where the discoloration was.. had to flip it one side or the other to get proper effect...it immediatly took away most of the discoloration and over time it disappeared. I hope this helps. Please email me at agclay777@comcast.net as to your conclusion in case it will help others. thanks, Adam
Oct 10, 2007 | Philips 51PW9303 51" Rear Projection...
Philips 55PW9383 55" Rear Projection Television Logo
113 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
