DOESN'T PRINT RED/NEGATIVE NUMBERS ANY MORE
I CHECKED THE INK ROLLERS & THAT'S NOT THE PROBLEM. I HAVE TWO CALCULATORS WITH THE SAME PROBLEM. OTHERWISE THEY WORK.
  • bernicev Jan 27, 2009
    When printing negative or subtracting, the calculater doesn't print in red. I have a re/black ribbon in.
    Problem Solver:
  • 5 Answers
Did you buy a red/black inker or all black?
Posted on Jan 04, 2009
Sharp EL 1197p will only print red ink not black??
If I am not mistaken the EL1197 is the ink roller type. It has the red/black and it's the IR40T. If that's the one replace the ink roller. If it's a ribbon type then replace the ribbon. It's about $5. Email me if there is any problem
Apr 05, 2015 | Sharp Office Equipment & Supplies
Only prints in red
may have print ribbon installed upside down. what happens if you try printing a negative number? if that number prints in black, try turning ink ribbon over
Jan 02, 2014 | Canon MP49D Calculator
Casio hr-100tm ink roller
Check to see whether a fragile plastic roller pin or retainer has broken off. Also, a piece may have fallen out when the old roller was removed.
Aug 30, 2012 | Casio "HR-100TM Two-Color Portable...
How do you change the ribbon
Hi mkline519,
The new ink roller types are EA-781R-BK (Black) and, EA-781R-RD (Red).
To change the ink rollers.
1). Set the power switch to off.
2). Remove the printer cover. The little paper guard or, flap on top.
3). Remove ink rollers by turning each one counterclockwise and, pulling upwards. With the calculator facing you. Red is on the left and, black is on the right.
4). Install the new ink rollers in there correct position's. Simply press them in one at a time and, make sure they are secure.
5).Put the print cover back on.
If calculator prints blurry, the rollers may not be not secure. If you have any questions about this calculator simply post a comment and, I'll respond quickly.
Jan 13, 2011 | Sharp EL-2192Rll Calculator
Won't Print in Red
needed a ink roller. I found it at Office Max.
Apr 10, 2009 | Basix BX-PC102 Calculator
How to ink Casio FR 1211 Printing Calculator
I have a Casio FR-1211 Printing Calculator and I have the same problem. I removed the roller and tried inking the roller with "Sanford's Roll-On Stamp Pad Inker". It works beautifully ! I don't know how long it will last, but for now the print is dark and clear.
John
Apr 05, 2009 | Casio Office Equipment & Supplies
Replacing inking roller/ribbon?
i had a problem with this as well and found a user manual online. I thought the whole thing came out but it doesn't. If you pull up on the little red thing on right and then the black one on the right you have it. Imagine that! That's all that you change. Then just put some new ones in and your good to go.
Jan 14, 2009 | Sharp EL-2192Rll Calculator
Changing Ink in the Canon P170-DH Printing Desk Top Calculator?
The manual for the Canon P170-DH calculator is found on the canon usa web site. It is 22 mg in size, but prints out to 4 pages in English, Spanish and French.
According to the manual: Use only Ink Roller CP-13.
There are four figures showing the steps, so you'll have to imagine it.
1. Turn power switch off.
2. Remove the printer cover (Figure1).
3. Hold the tab of the ink roller. Lift the ink roller out of the base (Figure2).
4. Insert the new ink roller into position. Push down on the center of the ink roller until it locks into place (Figure3).
5. Replace the printer cover (Figure4).
Print out the manual for yourself and put it in a safe place.
Nov 20, 2008 | Canon P170-DH Calculator
Ink rollers
Unless the ink roller that you installed was dried out, usually, the replacement rollers just snap in place and are good to go. Check to make sure there is ink on the roller by either pulling the ink roller out again, and touching it with your finger. If no ink on your finger, you might have received a dried out replacement roller. Also the roller should be somewhat like a sponge. If you push against the sponge and it doesnt spring back and it stays indented, then the roller might also be bad. If you happen to have a bottle of ink for an ink pad, you can try soaking the roller with the ink so the roller is wet, (but not DRIPPING WET) and try it again in the calculator. IF you get some image for a little while, then I would say try a new fresh ink roller.
Hope this helps.
Feb 04, 2008 | Sharp EL-2192Rll Calculator
Canon p170-dh
if you calculkator does not print at all try to move a switch to p or print, and you have a ink roller on the printer
Dec 08, 2007 | Canon P170-DH Calculator
239 people viewed this question
k24674
jasbo
jasbo
