Question about Nokia N95 Cellular Phone
Big problem with my Nokia N95 !
I have a original N95 and the it keeps reseting if i watn to listent to a song it resets , if i want to see some picturers it resetes . sometimes it works ok for a couple of hours and then it's starts again! I'v done some resofting and reseting but it still dosen't work! What should i doo can u tell me plss
Have you tried updating your phone through the internet? you will need the disc that came with it and an external pc. hook up to the net and follow the instructions to update it.
Posted on Dec 31, 2008
Ive forgot my lock code for my n95 8gb, how can i reset it? also im from the uk. thanks
Here are a couple of codes to soft/hard reset/format a Nokia N95 mobile device:
Soft reset code *#7370#
Hard reset code *#7780#
If the hard format code mentioned aboive does not work, try the following manual method to hard reset/format Nokia N95:
+ Turn off the mobile device.
+ Press and Hold the following three buttons: the green Call Answer button, the “*” button, and the number “3′ button.
+ While holding these buttons, turn on the phone and keep holding the keys untill the mobile phone restarts and prompts you to enter details.
Jun 24, 2010 | Nokia N95 Cellular Phone
My nokia n95 would not turn on, placed it on a dry surface over night a, next morning would not turn on even when on the charger
Here are a couple of codes to soft/hard reset/format a Nokia N95 mobile device:Soft reset code *#7370#Hard reset code *#7780#If the hard format code mentioned above does not work, try the following manual method to hard reset/format Nokia N95:*Turn off the mobile device. Then press and hold "3", the "Green button" and "*" - Turn on and keep holding the keys until the mobile phone restarts and prompts you to enter detail
May 11, 2010 | Nokia N95 Cellular Phone
Unlock security code nokia n95 8Gb
If you have forgot your Nokia N95 8GB's security code then i will recommend you to do following:
  • Enter 00000 or 12345 as pass code first.
  • If above codes wont work then you will have to RESET your phone.Resetting your phone will end up in loss of all DATA that you have on your cell.Every thing will be restored to factory configurations no Security code will be their.
  • Soft reset code *#7370#
You shall check following link too:
NOKIA N95 Tips and Tricks
Dec 06, 2009 | Nokia N95 Cellular Phone
Nokia n95 will receive texts but will not send them
You should update your phone firmware software by Nokia Software Updater or do a factory reset of your phone.Reset code is *#7370#.This code will reset your phone to original settings
Nov 26, 2009 | Nokia N95 Cellular Phone
How to reseta nokia n95 memory
you can do a soft reset that will reset the memory for your nokia n95 . Here are a couple of codes to soft/hard reset/format a Nokia N95 mobile device: Soft reset code *#7370# Hard reset code *#7780# If the hard format code mentioned aboive does not work, try the following manual method to hard reset/format Nokia N95: + Turn off the mobile device. + Press and Hold the following three buttons: the green Call Answer button, the ?*? button, and the number ?3′ button. + While holding these buttons, turn on the phone and keep holding the keys untill the mobile phone restarts and prompts you to enter details. (note a hard reset will erase all data that is not saved to a sim or card) a soft reset only resets the memory and the phone. it will not erase your data that you saved
Nov 11, 2009 | Nokia N95 Cellular Phone
N95 RESTART AND RESTART AND STOP FUNCTION
Try the following manual method to hard reset/format Nokia N95:
1) Turn off the mobile device.
2) Turn on the phone and quickly Press and Hold the following three buttons: the green Call Answer button, the “*” button, and the number “3′ button. keep holding the keys untill the mobile phone restarts and prompts you to enter details time and country.
Warning: Make sure the battery is at least 25% capacity so the phone will not power down during hard reset. ( Hard reset normally takes about 2 minutes only).
Warning: Hard reset will format everythings in your phone ( Your contact, calender, photos, installed Apps, Etc.) and the phone will be returned to its original state as if it was purchaced new.
( Mini memory card MMC) will not be effected :)
Dec 06, 2008 | Nokia N95 Cellular Phone
NOKIA N95 openingand closing sound clips automatically
You can try to have your battery out for over 1 minute.
Reset factory settings.
Then there is an option for soft format which will erase all info stored on phone and reset phone to it's original settings.
If no go, Nokia might have a new SW for this issue, probably you are not the only one who experience this.
Oct 17, 2008 | Nokia N95 Cellular Phone
Nokia N95 8GB
format your phone by typing *#7370# and your phone will be reset.
next time, it would be beter to transfer your music from folders. create a folder with the music you want and transfer them to your phone
May 25, 2008 | Cell Phones
Nokia n95 8gb master reset
Try this. Turn off your phone, then turn it back.
While its turning press and hold the following buttons:
Call, 3, *
This should be a hard reset button that will restore your n95 to its original settings.
Mar 15, 2008 | Nokia N95 Cellular Phone
N95 made in china CRAZY System!
Everyone listen,
CHInese NOKIA N95 is just a chinese mobile not a NOKIA branded mobile. All the PC suites, themes, apps and games are not designed for these chinese mobiles. All are designed only for NOKIA branded cell phones only. So i m sorry to say that u r wasting ur time and money to install these apps,themes,etc. They r only able to transfer mp3s,videos and pics. not other than that.
U need to have original branded mobile phones. SOrry gUys.
Sajan
Dec 15, 2007 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
