Question about Western Digital WD1600AB 160 GB EIDE Hard Drive
I have a emachines and i want to install a new hard
Hello people i have a emachines and i just got a new western digital 160 GB hard drive and every time i put my windows 98SE in it lock up i need some help thank you
  • 148 Answers
Windows 98 uses the FAT 32 file system and will only read up to 127GB. You could format the drive and divide it into smaller sections and windows should be able to read it fine. Either 2 sections of 80GB each, or multiple smaller sections.
-Download and use the updated FDISK.EXE utility program from Microsoft.
-Keep your partiton size for the Primary partiton that is to be used for drive C: to 127GB or less.
-Use the Windows 98 FORMAT.COM utility program. Note that while the prgram is running it will display an incorrect size for your partition. After it has finished, the summary screen will show the correct size that was formatted.
Formatting large hard drives is extremely slow. If you have a disk setup utility that came with your new hard drive, use it instead of FORMAT.COM. This can save you HOURS of waiting.
Posted on Dec 31, 2008
  • TERRI RODDEN
    TERRI RODDEN Dec 31, 2008
    DO NOT NAME YOUR EXTERNAL DRIVES THE SAME AS ANY OF THE INTERNAL DRIVES ON YOUR SYSTEM. Your internal drive will be C:, floppy A: and any cdrom or cdrw will be D:, E:, etc.. Go to My computer and check your drive letters before you begin. You may need to rename the drive letters.
  • TERRI RODDEN
Windows7 wont read wd1600 caviar as a external drive ???
Did you install the western digital drive softare? There should have been a disk with the drive, which you run when you have installed the drive. It tells the computer there is a new hdd in town. If you don't have the disk, google Western Digital, find their website, and search for HDD driver software, with the model number of your drive. You should be able to download the drivers to your computer, and install them that way.
Nov 05, 2012 | Western Digital Caviar WD1600BB 160 GB...
Hello! I have a new hard drive WD1600BEVS, problem is that, when I`ll try to install windows 7, all stop at stage where I have to choose place where to install this program...and there ask for drivers for...
had same/similiar problem
if your computer is asking for a driver when you insert the windows 7 disc your motherboard might not support windows 7 if its older than 5 yrs also you need a minimum of 2 GB of ram to support windows 7
hope this helps
Sep 01, 2011 | Western Digital Scorpio WD1600BEVS 160 GB...
I have a Toshiaba laptop which had a hard drive failure , so I installed a new Western Digital Scorpio WD1600BEVS 160 GB hard-drive. When I tried to install Windows OS, the installation failed to detect...
You can install the windows to follow this step.
Make sure that the CD drive is on first boot. When you turn on your laptop you need to press the delete key fast, to access the BIOS. Once you have change the BIOS settings you need to save it. After you save once the laptop detecting the windows CD press the enter key fast also to boot from CD.
Jul 27, 2010 | Western Digital Scorpio WD1600BEVS 160 GB...
My Western digital divice is mulfunctined as displayed on screen
do you use windows 98? because win 98 cannot support wd 160.
2) the mother board bios may not support this drive, or the interphase of the ext usb drive is faulty. lastly try to remove the raw drive from the casing and use it directly with the pc . i feel it will start working well
Sep 18, 2009 | Western Digital Passport WDXML800UE...
When installed in Vista it shows up with only 34 GB
Is this a new Hard Drive ?
Was it previously used with some other OS ?
If it was used with some other OS previously than run a debug on the HDD from DOS Prompt by using a DOS Bootable CD / DVD. Than try installing Vista.
Jul 30, 2009 | Western Digital Caviar WD1600 (1600YD) 160...
Format harddrvies western digital wd1600
try using the dynamic drive overlay supplied with the drive? Your MB may not be able to handle it.
Aug 12, 2008 | Western Digital Caviar WD1600 (1600YD) 160...
Just buyed Western Digital Caviar SE WD1600AAJS 160 GB SATA
you have to enable the raid controller in the bios to see sata hdd nad have you pluged the power connector to hdd which is by the sata cable port then to your sata port in the motherboard, then install sata card drivers for your motherboard then reboot and after you have rebooted goto devise manager and see if it is reconised the driver if you have a yellow question mark then select it then right click then uninstall then click yes when removed driver goto the icon with spyglass and computer on and doubleclick on to search for new hardware once done reboot then your new hdd will be in the my computer icon.
hope this will help
Jul 08, 2008 | Western Digital Caviar SE WD1600AAJS 160...
Installing SATA WD 160 GB Hard Drive
You may not have a SATA system - Western Digital has the other type of hard disk drive available.
Apr 07, 2008 | Western Digital Caviar SE WD1600AAJS 160...
Western Digital WD1600AB 160 GB EIDE Hard Drive Logo
128 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
