Question about Fujitsu ScanPartner 93GX Flatbed Scanner
Fujitsu Scan partner 93GX - power
I am trying to repair a Fujitsu Scan Partner 93GX, the motor that moves the lens back and forth was jaming, took it apart and fix it by puting the wheel back on track but now it does not move at all, the green LED light comes on but there is no movement when it is turned on. I made sure all the wires were connected and everything was back in the same place- HELP
4 Suggested Answers
  • 15 Answers
SOURCE: fi=5120c conflict with another scanner
Check in the order as i had written.
1. Is both the scanners are connected in usb, then this problem will arise. Connect fujistu in scsi and check it. And connect only the cannon and check. because there is a chance of usb port or usb cable problem.
2. Then it depends up on the driver you are selecting. whether you may be selecting fujitsu and giving scan .
3. Check is the driver for cannon is properly installed and also have a check in the device manager is there is any question mark is showing in the driver for particular scanner.
4. If you are using any certain application like scandall application you can select the scanner whichyou want it to scan by selecting the SELECT SCANNER.
5. Is your driver is a new version. If new version is available then update the driver and check it out.
If you have any other problem you can contact me .Regd. the fujistu i can help you.
My mail id is : ramanathanr@integramicro.com.
Posted on Nov 11, 2008
fanaudi
  • 1381 Answers
SOURCE: I had the Fujitsu 93GX
Hi cynthia
It's a driver issue .
Go to http://www.nodevice.com/driver/ScanPartner_93GX/get25551.html and carefully select the correct download .
Regards ,
fanaudi .
Posted on Mar 02, 2011
TechSatya
  • 104 Answers
SOURCE: I have a Jujitsu Scan Partner 3091DC and would like to know how to use it with a Mac Version 10.7.2
Hi Dwight,
To use your Fujitsu Scan Partner 3091DC scanner with Mac v10.7.2, you need theMac driver for the scanner. Please be informed that this model is discontinuedand no longer available with Fujitsu. Also, the manufacturer has not yetpublished the Mac driver for Scan Partner series scanners. For moreinformation, please visit the following link:http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/drivers-downloads_index.html#Hope the above information is helpful.Thanks & regards,ScanCare
Posted on Dec 08, 2011
Hi Dwight,
Dec 03, 2011 | Fujitsu ScanPartner 3091DC Path-Through...
My computer is having slow responce
have you scanned it using the anitvirus? try that, and check for infected files. usually, viruses cause slow performance.
Jul 18, 2010 | Toshiba Satellite A135-S2276 Notebook
My tahoe is vibraiting every time i hit the gas pedal and keep doing it until i took my feed out the gas what do you think
With acceleration vibrations, you should check all your Motor Mounts. Check for rips, tears or worn rubber.
To check the "play" of these mounts:
1. With a partner behind the wheel, vehicle on, in park and them accelerating; and you watching the motor, check to see if the engine is moving (canting) forward, or left or right.
2. Jack-up and properly support the entire vehicle.
Have your partner now place the vehicle in Drive, no brake and accelerate. Check the engine for movement.
3. Have your partner now place the vehicle in Reverse, no brake and accelerate. Check the engine for movement.
Any substantial movement should have the motor mount(s) replaced.
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.Com!
Mar 02, 2010 | 1998 Chevrolet Tahoe
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Password is lost
Bob, we need to know which voicemail you have. Is this a user mailbox or the system manager password?
Jul 30, 2009 | Avaya Lucent Partner 616 Phone
No power
Try unplugging the key system for a minute, the replug. This should reset your system.
Apr 14, 2009 | Avaya Lucent / Partner Phone system with 5...
My lucent partner system will not turn on
The power supply on the main unit might be bad . what kind of partner is it . exam.partner ACS , partner plus , or a partner .
Feb 26, 2009 | Lucent PARTNER18 Corded Phone
Whirlpool Quiet Partner II
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 26, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Fujitsu ScanPartner 93GX Flatbed Scanner Logo
Top Fujitsu Office Equipment & Supplies Experts
Smidler
Level 1 Expert
Norman Al-Anbar
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
