Question about Thumper Mini Pro 2 Massager
Disassemble to repair
All visable screws are out but the two piece casing still feels screwed together at the motor . the handle at the cord inlet pulls apart enough to see the switch but no futher.i don't want to pry and break casing, hope you can help. thanks chris
  • Anonymous Feb 04, 2009
    High density foam under pivoting arm disintegrated. Where can I get the foam part to replace it.
  • shu246 Mar 26, 2009
    yes, you must get all five screws and two plastic plugs out:
    ..three screws under the lavender/purple pad at back of head;
    ..two screws in the handle under plastic caps (the caps are about 3/8 inch long, hollow, but sturdy enough to just drive a small wood screw into the cap and pull out screw and cap together - if you dont mind defacing the caps;
    ..two plastic plugs (head about 1/4 inch accross) on the top of the massager head (weasle these out with a pair of flat blade screw drivers, trying not to damage them).
    The switch is sturdy enough, but the 'box' in the slider on the handle has weak sides which break off. You might be able to drive a small screw into the slider to regain control of the switch. I'm just going to leave my switch set at low speed and reassemble; plug/unplug from power outlet to turn device on/off.
    -shu
I just decided to try to fix mine. There are all together 5 screws. The two on the handle are covered with plastic caps which can be pulled out by sticking a duct tape and pulling it up. The other three screws are in the thumper head and are covered with the purple violet rubber piece. I removed it with my fingers. There are also two plastic bolts in the head of the thumper opposite to the handle. I removed them by using a sharp knife to loosen them and pulled with pliers.
I purchased two thumpers over time and in both the switch failed. I see that the switch in the handle is linked with the underlying mechanical switch by a very thin plastic piece. What a miserable design. That piece broke off in both thumpers rendering them unusable.
Good luck. Artur
Posted on Jan 03, 2009
  • Vijay
    Vijay Sep 01, 2014
    Fantastic Great and can you let me know where I can get the circuit board
  • Vijay
    Vijay Sep 01, 2014
    I am in Bangalore India, my email id is vid_vijay@rediffmail.com
I had a problem with switch and called Thumper. The girl on Phone told me to pry off the switch cover with a butter knife. I did so it was hard and went flying across the room but got it off still not working so she said clean the contact with cuetip and alcohol. Worked like a charm - you can operate the unit with the switch cover off. She is sending me a new cover and said when it comes to call and she will help put back on. Mine unit was stuck in high speed and had to unplug to shut off. Working good now just waiting on cover.
Posted on Apr 24, 2012
    New Friend:
  • 14 Answers
Just a note for others: had to fix thumper, and, indeed it turned out to be broken switch cover, that did not engage the 'real' switch.
However, no matter how hard I tried, could not pry off the switch cover. Had to take whole assembly apart, and then was finally able to remove switch cover.
I then cut away the trim around the switch cover plate, and was then able to put the remaining plastic "button" over the switch, which makes sliding the switch much easier, and prevents potential shock.
Posted on Aug 24, 2013
Thumper mini-pro repair: making lots of chattering noise
After eight years of constant nightly use, my thumper mini pro started making a lot of chattering noise. Before spending $200 for a new one, I decided to see if it was something simple, the result of stupid design as before. I had repaired the incredibly badly designed slider switch a few years before, and that had only cost the price of a small screw. I had not removed the entire case that time, it’s not obvious or easy. There are five screws and two plastic push pins that have to be removed. The three screws under the purple rubber pad are easy. The two screws in the handle are hidden, covered with plastic plugs that have to be first removed destructively with a drill bit or wood screw to expose the screw heads. The two push pins in the head have to be pried out with a thin blade.
When the case is open, you can see the motor and a cam shaft assembly leading to one side of the rocker arm. The chattering noise is caused by slippage in the wheel that joins the aluminum cam to the plastic driver shaft. There are two axes of motion in this joint, it moves both up and down and in and out. The wheel tends to slip a few millimeters out of its wheel socket when the cam is at bottom dead center, go back in at top dead center. Originally, the wheel was held into the cam with a few slot channels in the rim but they apparently wore down with use. Another example of a tiny design flaw ruining a $200 machine. I first tried putting rubber bands around the whole assembly but this didn’t hold the wheel into its socket. Here is what did work. Set the mini pro down and turn the cam so that you can work the wheel entirely out of its socket in the cast aluminum cam. It’s actually not hard to do. Clean it up a bit, as necessary, and then wind a couple thickness of aluminum foil around the little wheel and wedge-push it back into its socket in the cast aluminum cam. You might have to do this a couple of times before you get it just right. Remove any excess foil and try running the motor. Chattering vibration gone, just as quiet as new. A brutal and ugly fix, but effective, and almost no cost. Note, this area gets very hot, so don’t use tape or plastic instead of foil.
Posted on Aug 07, 2010
  • 2 more comments
  • susan_eno Feb 07, 2011
    sure going to try this! Thanks!
  • Surrattdaddy Jun 22, 2011
    can u please tell me how to take off the switch or send me a pic doing it. I'm afraid I'll break it. I would really appreciate ur help. Thanks! Surrattdaddy@yahoo.com
  • Terry Proveau
    Terry Proveau Jan 21, 2016
    to take off the switch cover you use a flat head screwdriver and just try it up, doesn't come off easily.alternatively you can take the whole unit apart as explained earlier in this blog.
  • Terry Proveau
    I also had the noisy problem after using this machine pretty much daily for 7 years. I took it apart however there was no problem with the wheel the cam and plastic shaft excetera. The problem with mine was simply loose screws as there's about a dozen screws attaching the motor to the plastic handle excetera and after tightening them all up voila it's quiet again. I can see what rdjansen says though as it tends to be an area that would wear before most other parts. Mine has had a lot of use and I'm surprised it's still holding together.
Pry off the handle switch and you'll be able to work the real switch inside with your thumb.
Posted on Jul 02, 2010
HOW TO TIGHTEN DOOR HANDLE ON A DOUBLE OVEN NO VISABLE SCREWS
Door will have to disassembled to locate handle screws.
Nov 17, 2017 | Ovens
How do I disassemble the drill to get to the battery so I can replace it?
Just unscrew all the screws holding the case together, not just the handle part.
Gently split the case in half to get to the battery in the handle part.
Be careful pulling the spade connectors off the battery leads and remove battery.
Swap over the new one, making sure the polarity is correct and slot back in.
Line up the case and snap back together, replacing all the screws.
Oct 12, 2016 | Black & Decker Black And Decker Pivot...
How do i replace electrical cord on dremel4000
Open the case, locate the two AC wires and detach. Get new cord and replace as per the previous wire attachments.
Dec 26, 2014 | Dremel Tools & Hardware - Others
How to replace the power switch on a Kirby G4
This repair requires extensive disassembly. First remove the handle, bag assembly, and switch "scuff" plate. To remove the switch plate, remove the screw at the bottom, and the upper screw that secures the cord. Insert a screwdriver into the rectangular slot in the plastic and pop it off. The cord must also be removed. One screw holds the cord cover to the lower motor shell. Remove the screw and push with a flat screwdriver on the back of the cover to unlatch it. Next remove the upper motor shell ( 4 screws ). The next piece to come off is the switch button. Pry upward on it's attaching lugs to free it, pull it upward far enough to disconnect it from the switch rod. The power drive assembly is next to go. Three screws on the bottom of the motor unit hold it in. DO NOT remove the center screw beneath the shift lever. The drive pedal must be in DRIVE for removal. The transmission drops down to get it out ( you may have to wiggle and pull on it to free it). Next the headlight frame assembly must be removed. You will see 2 screws at the rear, and 2 long screws in front which also secure the fan housing. After removing the screws, the headlight frame can be removed. Be careful to note the proper location of all wires! The right carbon brush assembly must be removed to allow the switch to slide back for removal. It is held in place by 1 screw and a tab on it's holder. Two screws hold the switch itself in place. One is on a tab on top of the switch, and the other is on the right bottom of the lower motor shell. The lower screw also serves as a motor mount screw. The switch can now be removed by inserting a small screwdriver along it's front edge and prying it backwards. It is wise to clear dust and lint from the motor contacts prior to re-assembly. Be sure the terminals on the field coil have not gotten bent before putting the new switch in place. Snap the new switch in place and replace the screws. It is easiest to replace the wires in this order:
1- Holding the headlight assembly off to the right, install the lower headlight wire.
2- Next connect the wire from the left carbon brush to the upper switch terminal.
3- Connect the upper headlight wire.
4- Gently replace the right carbon brush assembly, secure it with it's screw ( do not overtighten ) , and connect it's wire to the lower switch terminal.
After the switch is in, install the headlight frame screws, transmission and belt, and switch button in reverse order. Be sure the shift arm on the left side of the drive unit engages the slot or pin on the handle pivot assembly. The cover and trim pieces can now be re-installed.
Feb 16, 2011 | Kirby G4 Bagged Upright Vacuum
HOW DO I DISASSEMBLE ACME JUICER TO REPLACE CORD? (CLEAR TOP)
Remove 4 screws on bottom, leave center locking nut and screw
alone, and separate housing to expose wiring. Housing may be
juicy stuck together and be mindful of where everything belongs.
When reassembling you may feel resistance since you will be
raising the spring loaded motor shaft.
Dec 03, 2010 | Acme 6001 Juice Extractor
How do I disassemble the housing to get to replace the starter rope?
Hi.
Disassembly procedure depends on the make and model. Please provide model info for the unit.
Thanks.
Sep 04, 2010 | Garden
Have a small ball caught in between the handle and the hose and was wondering if the handle comes off
Depending on which style hose you have:
Dolphin Handle: There is a small retaining clip on the hose that can be removed by a flat head screw driver. Make sure your hose is not connected to the inlet and the power cord is disconnected from the inlet valve. If not you will receive an electric shock
Non Dolphin Handle: There are two screws under the handle. One at the back and one by the suction control. Remove those two screws, and pull the wire cover off by the suction control and when the piece is removed the hose should slide right out of the handle.
Aug 14, 2010 | Electrolux Centralux Vacuum
Bosch electric hedge trimmer PHS 46G - stops when cord bends, have purchased a new power cord. Have removed all the screws in the body case, and the front handle and sheild, but does not want to break...
The proceedings are as follows: 1. on the PHS 46 G release all Phillips screws. 2. On the underside of the trimmer, remove the metal cover.(4 screws). 3. Slide the scissors form as far as possible to the front , then we see two more small Phillips screws . Loosen these screws too. Now, the entire blade detaches from the ex-center gear. 4. The housing can well be apart!
Jul 23, 2010 | Garden
Lawnmower Starting Pull Cord Replaement
There will be a piece of casing that holds the starter mechanism in. Usually held by 4 screws (probably torx screws unless it's an old machine).
Undo these screws and you will find the cord carrier inside.
Observe how the starter dogs are located, and how it all goes together.
You may be able to remove & replace the cord without taking the carrier off the casing, but it is probably easier if you do.
Then you simply remove the old cord, thread a new cord through the hole & tie it. Reassemble the carrier onto the casing. Thread the cord out of the casing & through the handle, tie that end.
Then wind the cord around the cord carrier until there is a slight tension on the spring.
Screw the casing back on the mower and you're away.
Sep 20, 2008 | Garden
Strimmer Case Removal
there are 2 small screw under the black plasic part. If you've taken all the "visable" screws out the molded plasic part snaps off. Also there is 1 screw under the label. Use your finger to locate the hole and just poke your screwdriver thru it label to remove it.
I hope that helps a little.........
May 22, 2008 | Black & Decker String Trimmer Cordless 12"...
Thumper Mini Pro 2 Massager Logo
4,480 people viewed this question
Top Thumper Health & Beauty Experts
john h
Mai Lor
Are you a Thumper Health and Beauty Expert? Answer questions, earn points and help others
