Question about Toshiba 57H81 57" Rear Projection Television
Toshiba 42H81 - Screen flicker
I have a Toshiba 42H81 rear projection TV that flickers. It started intermittently and would go away after warming up. It gradually took longer and longer to warm up and go away. Now it flickers constantly w/ some vertical flashing lines that show up on the right hand side. There is also a blurry section towards the top of the screen stretching horizontally all the way across. These all seem to happen all the time now. It does get better after warming up but it still flickering enough that it really is annoying to watch any more.
It'd be great if there was something to be able to fix on my own. Money is tight these days and I can't really afford a high repair bill or to buy a new one.
Thanks for any help you can give me.
Derrek
  • derrek355 Dec 31, 2008
    Dan,
    I just saw some other posts discussing flickering issues and referencing the Hyper Module. Is that a problem too?
    Thanks,
    Derrek
Hyper module going bad I spent $500 to have mine repaired
Posted on Jan 09, 2009
  • 4,234 Answers
Since the problem initially would correct itself, it suggests a poor connection somewhere that "heat" would resolve. If you can solder, try resoldering any joints that appear to be grainy or have rings. Please note that these sets will retain high voltages that can be dangerous even when unplugged. If the resoldering fails to resolve the problem, let us know and we'll look further.
Thanks,
Dan
Posted on Dec 31, 2008
  • ABRsvcs Dec 31, 2008
    It can be, but I usually like to look at the "cheap" solutions first. Most of the problems that involve hte Hyper module do not correct themselves like yours did.
    Dan
57in Toshiba projection tv flicker all the time,what the problem?
Toshiba 56HM195 DLP Flickering Problem - YouTube
? 0:08
www.youtube.com/watch?v=SxnUYXkaLr4
Nov 21, 2009 - Uploaded by Brian Baute
Flickering & green boxes appearing all over my Toshiba56HM195 screen. This behavior is consistent all the time, with multiple lamps, and across multiple inp... ... Up next. Stay Away From Toshiba DLP Projection Television!
Oct 29, 2015 | Toshiba Televison & Video
Toshiba/ 42H81 / hyper board
You can either yrplace your Hyper board, or replace all the serfice mount capacitors in it. The cap replacement fixes this 90% of the time.
May 09, 2012 | Toshiba 42H81 42" Rear Projection...
TV Flickering, Wave, and Warming Up Problem
The capicators in the hyperboard have failed. An esy fix if your patient. Otherwise I offer a repair service. Let me know.
Feb 03, 2010 | Toshiba 50H81 50" Rear Projection...
When turned on, the screen has waves in it across the top and flickers. It is unreadable. When the TV warms up it seems to be better but is starting to flicker or flash all the time now.
Your Toshiba TV has hyperboard inside and there are few electrolytic capacitors (may be 10) that need to be replaced.
If you are comfortable with soldering parts in PCB then go ahead or ask help to any friend that knows electronics stuff repair.
Let me know further query.
Thanks.
Jul 01, 2009 | Toshiba 57H82 57" Rear Projection...
Toshiba 57H82- Distortions on the picture screen
You have leky caps in your regulated power
supply they are typ 220 uf 200v and are large
and round next to flyback
Jun 23, 2009 | Toshiba 57H82 57" Rear Projection...
Bad picturre on toshiba tv
Good Day, pieps57;
Corrective Action: Remove the MVUP13 Hyper Module from the TV chassis, remove the top shield and replace the 10uf, 16v capacitors using Part Number 24619040. It’s recommended that all of the capacitors identified be replaced (Note: These capacitors are low impedance surface mounted aluminum electrolytic capacitors. Care should be taken to avoid damaging the PCB while replacing these capacitors.) CAPS: cx178, cx221, cx230, cx241, cx250, cx261, cx270, cx541, cx670 & c514, c5030.
Good Luck, Big Irish.
Jul 07, 2008 | Toshiba 42H81 42" Rear Projection...
TV Flickers up and down and screen is shifted to the right w/ red color dominating the screen.
Hi
The most likely problem is the auto focus module.
A costly repair.
If you are going to fix it ask for a rebuilt one.
Part# CS00022 R
Feb 29, 2008 | Hitachi 50UX58B 50" Rear Projection...
Toshiba 42H81
i had a similar trouble not long ago.. it was the digital conv. board .... it'S was rather expensive at about 345$ canadian w/o the job... it's your call, but my last customer didnt want to shell out the money for this kind of tv..... sorry fir the bad news
Aug 06, 2007 | Toshiba 42H81 42" Rear Projection...
Update to flickering screen on Toshiba 42H81
How did the repairman prove the blue CRT is bad ? Did he cover
the CRT leaving a good red & green video with no flickering or did
he cover the red & green and observe the flickering in blue...?
Did he discuss the hyper module with you ?.........T.
Oct 24, 2006 | Toshiba 42H81 42" Rear Projection...
Flickering on black screen or dark areas of a screen
The moving might have created a loose conection,the sets age tell me there are possible other overheated areas that need to be resoldered to prevent other symptoms,If you are familiar with tv service you can check the conections in the output transformer area,he is responsible for generating the high voltage that lights up the 3 picture tubes,before the Hight volatege gets to the pix tubes there is a High volage distribution box that separetes the voltage for each tube,check it and make sure is not degraded,you need to be very careful when dealing with these parts,there is a lot of volatge in that areas,If you are not familiar with tv service be safe and call for assistance froma servicer.
Oct 11, 2006 | Toshiba 42H81 42" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
286 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
