Question about Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune froze on boot up this morning. Reset buttons won't work nor will any others. Tried charging battery to no avail.
  • 9 more comments
  • RAGHU Dec 31, 2008
  • Anonymous Dec 31, 2008
  • tmulticam Dec 31, 2008
    my 30gb zune is also frozen at the boot up screen. nothing is working. Microsoft please help.............
    my zune froze on the boot up screen. it shows the zune logo and the bar at the bottom is full but the screen is stuck like this. can't turn it off & the reset buttons aren't working.
  • bravo3do Dec 31, 2008
    my froze on boot up to so i tried to let the battery run out, the next day i charged it and it did the same thing.
    i left mine in my jeep and it is on the same screen
    Zune **** on the bootup screen.
    It is microsoft firmware problem.
  • musicO1 Dec 31, 2008
    I unplugged the battery and reconnected it. . . the zune still doesn't work
  • Anonymous Jan 02, 2009
    Ive tried both hard reset and letting the battery drain but as soon as i plug it back in it freezes after about 20 min
  • bhupenpati Jan 05, 2009
    I still have same problem. My 30GB zune not started again. When I pluged in zune with charger, as soon as zune get enough charge, it restarts and remain hanged untill bettarry completely drained. No idea what to do with it now.
  • 4 Answers
There's a fix:
Your Zune will need a "hard reset."
To do this, use a small screwdriver to pop off the plastic shielding where the Zune cable plugs into and remove the two screws on either side of the plug. Next pop the cover off and locate the battery plug at the top left corner of the Zune, using your screw driver, pop the cable connection half way off, and do this to the other plug on the right side. Wait 3 seconds, then push down the right connector and then the left battery connector. Your Zune should start up immediately. Press the backing of the Zune down (make sure headphone jack is aligned) and put the screws and cover back in place.
It's an easy process but if you're unsure don't attempt it.
Posted on Dec 31, 2008
I just checked the official Microsoft Zune web site. This problem has to do with 2008 being a leap year. The official solution is to unplug the Zune and allow the battery to drain. The screen will go black. Wait until 7:00AM Eastern time (6:00AM Central, 5:00AM Mountain, 4:00AM Pacific) before plugging back in.
Allow the battery to recharge and you should be good. They advise against taking apart the Zune.
There is a thread at the Zune Boards that says to allow your battery to drain then plug into a wall charger if you have one. Don't plug back in to a PC until after the times mentioned above. I have done this and it does work.
Posted on Jan 01, 2009
Mine did same thing. Take apart and unplug battery is the only thing that would fix mine.
This definately worked!
Zune frozen with logo
Let the battery drain completely and then plug into computer. There was a leap year glitch from Microsoft and the fix is working today. Ours froze yesterday and it's OK this morning. This only fixes those that froze Dec. 31st.
Jan 01, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My Zune froze from using the wrong charger
Reset Zune: Press and hold the back button while pressing up on the control pad.
Connect Zune to a power source: If the Zune device is in sleep mode, this action will wake the Zune device and turn it on. If the battery does not have a charge, you may have to wait several minutes for the Zune device to turn on.
Also, make sure that the hold button on top of your zune is turned to the off position.
Hope this helps!
If this helps Rate this a FIX-YA.
How to unfreeze my zune???
Microsoft is aware of the problem. Everyone has the same problem. It is a bug in Zune firmware. One option that works is to disconnect the internal battery and that will reset the system. Here is a link to the problem
http://www.tomsguide.com/us/Zune-Media-Player-Bug,news-3236.html
Dec 31, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune froze won't reset tried back button in unlock and held top of zune button but did nothing.
Followed explanation on Yuotube on how to disconnect battery. Rebooted Zune and all works normally?????
This is the first time I have had any problem with Zune in 12 months and very grateful to Fixya in helping me find the solution.
Zune 30GB froze
pull the case apart, unplug the battery pack for about 30 seconds, then put it all back together. it's not near as hard as it looks.
http://www.rapidrepair.com/guides/zune/zuneassemblyguide.htm
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My zune froze when I turned it on. It is frozen on the Zune welcome screen with the loading bar at the bottom. I have tried the back and up button and it has not worked. I have also tried the back, up and...
There's a fix:
Mirosoft zune froze up
To restart the Zune device, follow these steps: 1. Set the Hold switch to the unlocked position. Note To make sure that the Hold switch is in the unlocked position, you may have to move the switch back and forth until the switch is in the correct position. 2. Press and hold the Back button zune_button_back.gif while you press the top of the Zune pad
Dec 26, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My Zune Won´t turn on
my son's just did this and the reset method worked (press the back button and up and hold both for about 10 seconds until the zune screen appears)
Nov 08, 2007 | Microsoft Zune JS8-00001 Digital Media...
Microsoft ZUNE JS8BRPBDLUG MP3 Player Logo
431 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
