Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Frige is warm but freezer is fine! Kenmore Stainless 596.72913200
There have been a few posts on this problem. I'm having the same problem where the fresh food is warm, but the freezer is fine. I removed the rear wall in the freezer and there's ice buildup all around the coils and the hearting unit, which makes me believe the defrost heater is bad. Maybe the timer or a combination of both?? Can I check the heater tube for continuity and expect resistance if it's bad? Any other ways to check these to components? Any ideas would be helpful.
  • shayes012900 Dec 31, 2008
    Thank you for your response. I checked the parts diagram online and it is indeed a timer. I will run through the testing process tonite and let you know how it goes.
  • 242 Answers
Hello , I can help. You can ohm the heater out to ensure its ok it should read very low res. less than 20 probably , you would be lucky to have a defrost timer in this unit most of these now have electronic defrost control boards that fail often , to find out which one you have take the control cover in the upper/fresh food settings area at top off and there should be a 3" by 4" small control board or a def. timer that's white or black with a harness connected to it that has 4 wires.
If you have a def. timer there is a dial you can turn until it clicks once and set it to defrost to test the cycle , if the defrost is working at this point this means the timer has quit and is not timing any longer you will need to replace the defrost timer.
If you have a control board this is most commonly the problem , replace the defrost board and you should be good to go. If you have any problems let me know , good luck. Phil
Posted on Dec 31, 2008
Refrigerator is warm but freezer is fine - what is the problem and can it be fixed?
It sounds like its a stuck baffle, yes it can be fixed. The air from the freezer cant get into the fresh food section when the baffle is stuck.
Nov 09, 2010 | Kenmore 73503 Stainless Steel Bottom...
REFER IS WARM FREEZER IS FINE
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 11, 2010 | Kenmore 73503 Stainless Steel Bottom...
Thermostat problem
is the refrigerator section is freezing up
Apr 04, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
In my side by side samsung RS2534WW the rerigerator is warm
I read elsewhere that if you hold the power cool and power freeze buttons down for 12 seconds it will restart the system. I did it the other day (because we were having the same issues) and it has seemed to work for the last few weeks. Frige temp stays at 34F and freezer temp stays at -2F
Mar 13, 2009 | Samsung RS2534 Side by Side Refrigerator
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Warm frigerator
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jun 14, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
KENMORE SIDE BY SIDE NOT COOLING
You should hear a fan running inside the freezer. It also blows cold air into the refrigerator side.
Jun 09, 2008 | Kenmore 50522 / 50524 Side by Side...
Fridge not cold, freezer fine...
look at the back inside wall of the freezer. you might need to put your hand on it to feel it. if you see or feel frost the you have a defrost problem. if its not defrosting the frost builds up and blocks air flow from the freezer to the frige so the frige cant cool. it will either be the defrost element, defrost thermostat or the defrost timer causing the problem
Nov 25, 2007 | Kenmore 71279 Bottom Freezer Refrigerator
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
122 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
