Troubleshooting keyboard issues ThinkPad Lenovo Support US
Internal ThinkPad Keyboard
Power on your computer. At the BIOS splash screen, press F1 on your internal keyboard. You should see a message "Entering System Setup." If you are able to enter BIOS, make sure that you can navigate through the menus to ensure basic functionality. While there, press the CapsLk key and ensure that the indicator light turns on or off.
If you are not able to enter BIOS, try pressing the blue ThinkVantage button or press the Enter key.
Boot into your operating system. Click Start, point to All Programs, point to Accessories, and then click Notepad. Using your internal keyboard, press each letter key and each number key to determine if your keystrokes are being recorded properly. If certain keys do not work, make note of these.
Check to see if you have installed any keyboard mapping software that would be interfering with normal keyboard functions.
Boot into Windows Safe Mode and test keyboard functionality with notepad. Please refer to step "B" above.
Windows XP Safe Mode instructions:
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/boot_failsafe.mspx
Windows 7 Safe Mode instructions:
http://windows.microsoft.com/en-US/windows7/Start-your-computer-in-safe-mode
Verify that the latest BIOS for the ThinkPad system is installed.
Click here to view the latest BIOS files for all ThinkPad systems.
Reseat the internal ThinkPad keyboard, if applicable.
If the keyboard is a customer replaceable unit (CRU), then reseat the keyboard connector. Please verify this in your system's Hardware Maintenance Manual.
If these steps have not solved your problem:
Refer to "Need more help?"
External USB Keyboard
Ensure that the keyboard's USB cable is securely installed into your ThinkPad.
Remove the keyboard's USB cable from your ThinkPad and install it into a different USB Port.
Power on your computer. At the BIOS splash screen, press F1 on your External keyboard. You should see a message "Entering System Setup." If you are able to enter BIOS, make sure that you can navigate through the menus to ensure basic functionality. While there, press the CapsLk key and ensure that the indicator light turns on or off.
Try entering BIOS with your Internal Keyboard.
Boot into your operating system. Click Start, point to All Programs, point to Accessories, and then click Notepad. Using your External keyboard, press each letter key and each number key to determine if your keystrokes are being recorded properly. If certain keys do not work, make note of these.
