Question about Microwave Ovens
The microwave does not turn on when pushing start.
The unit is a Panasonic 1110W high power counter top microwave oven. I do not have the owners manual to the unit. I beleive it may be on child lock for safety. How do I un lock the child lock? DK
  • Microwave Ovens Master
  • 9,086 Answers
You can download your Panasonic owner's manual here.
Posted on Jan 01, 2009
Panasonic microwave works but have to lightly tap the top of the door to make it work. Sometimes it works normally, but sometimes after the time is set, and the start button is pushed, it waits for about...
Troubleshooting your Panasonic microwave oven requires removal of the cover. There may be a loose or broken connection inside. Be sure to read and heed the dangerous voltage warning. As for the repair or replace issue, that depends on age (in appliance years) and whether parts cost and labor are reasonable.
Dec 12, 2013 | Microwave Ovens
Loud hum,louder than normal, when start is pushed and then high heat smell like it might start fire so I turned off. Would it be the transformer or the magnetron?
Hard to say. Usually the Magnetron and transformer are all one unit. More likely a short in the control board. If the oven is a built in and more than a few years old, it probably ode not pay to fix. If it is a counter top or over the range model it will be far cheaper to by a new.
Feb 07, 2011 | Whirlpool Microwave Ovens
Panasonic Counter top Microwave model # NNT695SF Often when I push the start button, the microwave will go for a few seconds and then cut out. I then open the door and then shut the door and push the...
Issue with your Main Panel Power Fail to innitiate ..Du to Component mal-functioning inside the unit ...Possibility Magnetron defect, Or main Transformer Over heat, Also check for safety swich on the door for bad connection...
Sep 30, 2010 | Panasonic NN-T695SF Microwave Oven
Just blew up no lights no nothing it is set into the wall
if there are not light there are usually two fuses in the unit one where the power cord comes into the unit and one that goes when the unit gets to hot. if the unit if a counter top unit you will need to go buy some safety star bits for the hardware store to get the cabinet off. just check the fuses with a ohm meter.
Jun 02, 2010 | Panasonic NN-S963BF Microwave Oven
Micro wave made a popping noise now does not heat up food as hot
The popping noise was probably the capacitor or high voltage diode blowing.
Test the high voltage capacitor, the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Apr 08, 2009 | Panasonic NN-C980 Convection/Microwave...
When microwave wss turned on, there was no heat but smoke
Test the high voltage capacitor, the rectifier diode.or the magnetron. If all this are fine, test the control board.
If it additionally does not spin and no light, then check also the door switch and fuse.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Mar 01, 2009 | Panasonic NN-S541 Microwave Oven
Microwave not working but oven and grill do
Dec 17, 2008 | Panasonic NN-C980 Convection/Microwave...
Microwave Ovens Logo
194 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
