Question about Frigidaire 14 Cycle Tumble Action Washer
Black marks washing machine is leaving black streaks, smudges and dots on laundry. black stains and smudges and dots on clothes
  • 1 more comment
  • Anonymous Jan 21, 2009
    I have a Zanussi ZWF 1437W that is leaving dirty streaks on my laundry too. I know I have grime build up in the machine but low on the door seal where I couldn't reach it. Had been doing a maintenance wash, with little result, but on the same cool cycle I always use! Now realise the temperature is crucial. DOH!
    Thanks!
  • lindakb1 Jan 30, 2009
    I did 3 cleaning washes and wiped out the machine, but the very next load of clothes I did had the same black stains. the weird part is that my husband never gets these stains on his clothes. the only difference in our washing style is he takes his out as soon as the wash stops and I do wash while I do other things and don't take them out right away.
  • dianepollard May 11, 2010
    EVERY NOW AGAIN I GET BLACK MARKS ON WASHING IT IS JUST HERE AND THERE
    BEEN GETTING IT WITH OTHER MACHINE HAD IN THE PAST HAVE U GOT ANSWER
  • Frigidaire Master
  • 3,463 Answers
To eliminate possible bearing failure, spin the drum by hand and see if u can detect any rumbling noise or strange nioses coming from the drum, if u can then it is probably grease that is coming from the bearings. The other possible cause is an effect called ****, this is a result of washing at too low a temp, this causes a build up of dirt and grease,leading to the sort of prob that u are experiencing The thing u should do is to put the washer on at a high temp with powder in but no washing and do a full wash . This is called a maintenance wash, and should be done at least three or times a year depending on how often u wash more frequently if u do a lot of washing. Clean the door glass and rubber seal as thoroughly as u can ,and remove as much sludge and dirt as poss. This should help with your prob. Plz rate my solution. Thanks.
Posted on Dec 31, 2008
My LG Front Load washing machine is leaving black streaks and smudges on my clothing. These streaks and smudges are ruining my clothes!
There can be several things that can cause this problem. The most common are:
1. Fabric softener - did you switch brands lately?
2. Chlorine bleach - if added at the wrong time
3. A mechanical problem with the washer, like a leaky transmission leaking oil.
4. Rust staining, sometimes caused by the water being used in the machine.
Here is a link to a site that discusses this issue more in depth:
http://www.stain-removal-101.com/washing-machine-stains.html
Jul 26, 2015 | LG Washing Machines
Lg washer leaving black greasy marks on clothes
This is usually to do with fabric softener. Dilute it with more water. The fabric softener makes clots, and these make the marks on your clothing.
Hope it helps
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | LG WM2077CW XL Front Load Stackable Washer...
2002 Kenmore front load washer 42042 is leaving large black smudges 3-4 square inches each and streaks, and dot patterned stuff of the same on my clothes. This unit is stacked . Is it repairable for...
Two possibilities come to mind. Too much fabric softener, or
the black rubber door seal. Try rubbing the seal with a paper
towel to see it it smudges. Try cleaning with bleach or alcohol,
then rinse it thoroughly with water.
Feb 04, 2011 | Washing Machines
I'm getting small orange spots/stains on my clothing after washing them in my Maytag washing machine. it is a 2010 machine too. Any thoughts as to what could be causing the stains?
Unless there is a child's crayon or something similar causing it, then suspect that the agitator shaft seal, or the drum seal is leaking oil into the drum. Hopefully, there is still warranty on the machine. Good luck!
Jan 10, 2011 | Maytag Centennial MTW5800TW Top Load...
Brown streaks and smudges on occasional loads of laundry. Sometimes on a load of towels, there will be dots corresponding with the holes on the inner drum.
You did not indicate whether this is a top or front load machine. But if it is a front, then the problem is due to a seal and bearing failure. Our machine did exactly as you discribed. When the machine is in the spin cycle, it would be extremely loud, due to the bearings failing and the grease would seep into the wash water and staining the clothes and towels. It can be fixed, but it requires that the machine to be taken completely apart, to remove the drum from the tub and the seal and bearings replaced.
Aug 13, 2010 | Frigidaire Washing Machines
Leaving brown/black smudges
This is most likely caused by laundry getting stuck in the front seal of the washer.
Jul 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Calypso grey/dirt streaks
THIS SERVICE POINTER APPLIES TO THE FOLLOWING BRANDS:
LAUNDRY PRODUCTS REFRIGERATION PRODUCTS KITCHEN PRODUCTS
COMMERICAL LAUNDRY
OEM BRANDS
ALL SERVICE POINTERS ONLINE: http://www.servicematters.com/tech_ref/tech_ref_main.htm, SERVICE POINTERS
COMMERCIAL LAUNDRY ONLY: www.whirlpoolcorp.com/cltpsc, TECHNICAL INFORMATION, SERVICE POINTERS
To receive pointers by email or FAX, or to edit or delete a current email or Fax from our distribution, see
http://www.whirlpoolcorp.com/cltpsc/feedback/feedbacksubscribe_all.html, or FAX changes to 269-923-5342.
CALYPSO WASHER
Model: GVW9959K
Serial Code Date: Prior to CP44
GRAY MARKS OR SMUDGES ON CLOTHING
L8178406
October 2003
Gray marks, streaks or smudges on clothing after a wash
cycle.
CONDITION:
CAUSE:
At the end of the cycle, the wash plate nutates for
approximately 30 seconds to fluff the clothing after the
final spin. The action of fluffing causes the outer wash
plate seal to rub against the stainless steel basket while
they are both relatively dry. This condition causes the gray
discoloration.
RESOLUTION:
An updated machine control, part number 8542693, is
now available. The updated control reduces the fluff time
from 30 seconds to 8 seconds, allowing the clothing to be
fluffed, without causing discoloration.
Gray marks or smudges can be washed out of clothing
after wiping down the basket. The consumer should use
the recommended amount of HE detergent and the hottest
water safe for the fabric or hand wash the garment under
running water. In either case, the fabric must be cleaned
prior to running through the dryer.
Jul 09, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Black streaks, smudges and dots from drum
take a rag and wipe around front door boot first does any thing come off on rag if this ckd ok does it keep a roaring noise when spinning? if so suspect rear bearing or corrision on spider this is tub support behind basket..ask for estimate before repair as this could result in major expense to repair good luck
May 28, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Black marks
sounds like a bad rear bearing.causing grease to get into laundry.
May 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Brown smudges on clothes
Take a look and see if the drum near the door moves up vertically. It shouldn't move more than 3/16ths of an inch. If it does, replace the upper felt seal/plastic slide. The upper seal that supports the front of the drum on the front of the dryer is worn out to the point that clothes can get stuck in the gap between the drum and the front of the machine. This leaves brown wedge marks on clothes. While it's apart, replace the lower felt seal as well.
Apr 20, 2007 | Frigidaire FullFGX831C Size Stack Gas...
Frigidaire 14 Cycle Tumble Action Washer Logo
628 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
