Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Have to hold button down to close door in cold weather
I have the Chamberlain HBW0777 made 9/94 and as soon as the weather gets a little cold the garage door doesn’t want to close. It acts as if there is something blocking the sensors. I have to hold the button in until the door is down. My suspicion is that the sensor that keeps the door from closing on an object is bad and does not like the cold.
I’m pretty savvy with electronics, Is this something that can be repaired or Not worth it?
  • 4 more comments
  • matt wilson Jan 04, 2009
    Thanks for the response. I have checked that and they are in working condition and aligned. I think it has to do with the sensor that if the door hits something, it goes back up, so it wont crush whatever was in the way. In the summer time (Sunny or dark) it works without a hitch, but when it gets a little cold out, It will go part of the way down and in the winter, you can forget it! It starts to move and returns immediately. You have to hold the button in the garage or the button on the keypad out side until the door hits the floor. And once in a while it still tries to return I guess until it realizes that I ain't giving up!
  • matt wilson Jan 05, 2009
    You da man! Thanks for stickin in there with me. One of the sensors were off a bit. I thought I had checked them. Problem solved. You truley are the "Door Tech"!
  • Anonymous Jan 05, 2009
    this is the second winter that my garage door doesn't go down. It starts the desent and then goes back. Sometimes when I hold the bottom down in the garage or the remote, it will complete the desent. Why does cold weather contribute to this problem?
  • wontletme Jan 05, 2009
    I have the same problem. The door doesn't go down most of the time in the winter unless I hold down the remote or inside button.
  • imspb Jan 06, 2009
    I have the very same problem - but the lights on the sensors both seem to be on - so I actually disconnected the sensors and gave it a shot. It still doesn't work in the cold weather with the sensors disconnected and the door jerks like crazy and reverses - and the light still flashes.
  • Anonymous Mar 20, 2009
    have to hold the button down to close but opens fine.
    Sniper:
  • 98 Answers
You have a photo eye (sensor) issue as you suspected. Be sure both green lights are on.  If one is flashing or is off, the photo eyes need to be realigned or there may be a wire shorting out (check for staples in the wire) to the photo eyes.  Sunlight can also be an issue.  The photo eyes might have to be moved away from the opening to be out of the sunlight.
Posted on Jan 01, 2009
  • Joseph Chapman
    Joseph Chapman Jan 04, 2009
    The away that Chamberlain is designed holding either the wall
    button or the keypad will only override the photo eyes. If you run the
    door and watch the photo eyes closely I believe you will notice one of
    them flicker (this might take three people).
I had the same problem. I checked the photo sensors and noticed one was bent. I strightened it out. Problem fixed. Thank You.
Bluebill
Posted on Jan 17, 2009
On down door reverses in cold weather
A garage door guy says that in colder weather the weather stripping can become stiffer, less pliable, causing more drag or friction on the door. You may need to increase the down pressure a bit. If it's set in the normal range, try increasing it a little bit at a time, but don't max it out.
Dec 26, 2012 | liftmaster Chamberlain Garage Door Opener...
Garage door will not close from remote or car. Garage door will open from remote or car; however, it will not close using these controls. The only way I can close the garage door is to press on the manual...
Try reprograming the opener to each remote, if this doesn't work then the command/radio module in the opener is damaged and needs to be replaced. Hopefully you can find one or you will have to replace the whole garage door opener. Good luck.
Jan 21, 2012 | liftmaster Chamberlain Garage Door Opener...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: My craftsman 1/2 hp garage dood does not close whe...
If the main light flashes 10 times when you try to close the door it is a sensor problem. Make sure they are not flickering ever so slightly and that they are not loose on their brackets. Tweak them a little bit.
May 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Chamberlain garage door wont stay closed. It
well the there are lots of possabilities but the most likly one is that there are shadows or pieces of debris that are on a laser detector or the chain that pulls the garage door is being heated while it is frozen which could change the signal on the closer. or you need a theremal cover on ur opperator system for the opening and closing on the door.... google always helps
Dec 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Cold weather came in and now the garage door closes about 6 inches then goes back up. I have sprayed penetrant on all moving parts and the door closes fine manually. It is minus 30 degrees celcius outside...
Try increasing the 'down force'. You will find the control on the rear of the motor unit near where all those white wires go. Increase it about 1/4 turn and try.
Dec 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Have to hold down keypad on wall to get door to
You may have a relay faulty or the wiring is connected wrong.
Dec 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
During the Winter: I have a garage door that will not close unless I stand inside and hold the button. The door closes but then reveres as if something is underneath it. this happens only in cold weather....
I'd guess that the lights that sensse that something is in the way are dirty or not aligned properly and the cold makes it worse. Also make sure to get some WD40 on the door track and wheels and then the chain on the opener if it's a chain type.
Dec 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't close by remote in cold weather
There are ususally two adjustments on garage door openers...
One is for the pressure and the other is for the travel. Assuming that the travel adjustment is properly adjusted...
On a cold day things are a little tighter and it "wants" a little more downwards pressure to complete its cycle. Sorta like me in the morning -- I need a little coffee to get going on a cold morning.
Adjust the down pressure/force just enough to make the unit close properly. Do not over adjust the down pressure or you will find it won't stay closed. Sometimes the manufacturer doesn't make it too clear where this adjustment is, but you should be able to find it if you look around.
I have seen units that were installed for years all of a sudden need a little tweak of this adjustment.
Good luck
Mar 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
2,008 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
