Question about GE DBSR453EBWW Electric Dryer
Strange clicking noise
GE dryer makes strange continual clicking noise when set only on timer, and does not run. The light still comes on when you open the door. Wife says it wasn't heating like it should prior to this recent situation.
  • old_school_9 Dec 31, 2008
    Thanks!! That was indeed the case. Have a Happy New Year, and thanks again!!!
    Guru:
  • 449 Answers
Before you even open the dryer, use your voltmeter to measure for 240v at the dryer wall outlet. You can’t just look at it and think it’s fine (I actually get people telling me that!) And just because the dryer motor runs, this doesn’t mean you’re getting 240v at the outlet, either. The motors runs on 120v but the heating elements require 240v and a common problem is for one leg, L1 or L2, of the 240v supply to open. If you’re not getting 240v at the dryer outlet, you’ll never get the elements to heat up. Plain n’ simple. Whether you have a four-prong outlet or a three-prong outlet, you gotta check the voltage at the outlet with a meter!
Ok, so you checked the voltage at the outlet and you actually measured 240v on your meter. Now, and only now, we turn our keen, laser-like attention inside the dryer. Let’s look at an example wiring diagram for an electric dryer. This one happens to be for a Whirlpool/Kenmore electric dryer and is probably very similar to yours. In the diagram, the heating element is shown in the lower right hand side. L1 and L2 are drawn on the either side of the diagram. The heating element connects to L1 and L2 through several different components. L1 connects to the heating element through the timer, a thermal cutoff, the operating thermostat, and the hi-limit thermostat. The heating element then connects to L2 through the motor centrifugal switch. All it takes is for any one of these components to fail open and this would prevent the heating element from receiving the needed 240v to get hot. Again, even though the example diagram is for a Whirlpool/Kenmore electric dryer, this is a typical configuration for any electric dryer.
Although any one of these components can kill the voltage to the heating element, there are a couple that tend to fail more commonly and can be easily checked. A quick and easy test to do is to measure the continuity of the thermal cutoff, the operating thermostat, and the hi-limit thermostat. Do this with the dryer unplugged and your meter set on the Rx1 scale. Disconnect at least one wire from the component being tested to isolate it from the rest of the circuit. If you find one that’s open, replace it and problem solved!
While you’re checking the continuity of these things, check the wiring for burnt or loose connections–this is another common cause for no-heat in electric dryers. If all those check out, then that leaves the the timer and the motor centrifugal switch.
Easiest way to test the timer is to run the dryer and measure for 120v out of the timer pin that powers the heating element circuit–in our example, it’s pin R. Measure for this voltage by setting your meter to the 150vac scale and placing one probe on timer pin R and the other on any metal point on the dryer frame. Oh, I know what you’re asking, “But if the heating element needs 240v, why are we only measuring for 120v at the timer?” The heating element gets its 240v in two halves: 120v from L1 and 120v from L2. We’re only looking for the L1 half at the timer so we’re looking for 120v.
Finally, if the timer voltage checks good, then that only leaves the motor centrifugal switch which, if you’ve made it this far in your checks, you can safely assume is bad. Since the centrifugal switch is an integral part of the motor, this means you have to buy a new motor. A manufacturer’s repair manual and an AllenBar take a lot of the frustration out of this job.
Posted on Dec 31, 2008
  • 52 Answers
Hi!
There is a high probability that your timer is defective. Please try to replace it with a new one.
Have fun!
*Your vote is highly appreciated. Thanks in advance!
    Sergeant:
    Champion:
  • 304 Answers
If your washing machine selector knob (dial) clicks round continuously and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. With basic Indesit washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause for a second and flash another 7 times in a constant cycle.
  • GE Master
  • 19,396 Answers
Check the thermal fuse, the clicking noise usually indicates a faulty control timer board.
You will probably need to replace the control timer assembly.
The part must be tested before replacement.
You find diagrams and replacements here.
Kenmore elite dryer runs when door closes
I have seen the heating element blow and short out. Causing very strange problems. If you have a model number we can look farther.http://www.on-timeappliance.com/dryerrepair.html
Mar 27, 2012 | Kenmore Elite HE4 Electric Dryer
Our GE DCLR333ET1ww dryer is making a strange noise when it is spinning. It is also starting to smell like something is burning (rubber possibly?). What could this be? If it is the belt, is this...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Apr 01, 2011 | Dryers
My dryer is making a strange noise (normally it is very quiet) and it smells like it is overheating. There does not seem to be anything coming out of the exhaust vent while it is on.
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Mar 17, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer will not turn on...could be the timer? Makes a strange noice when the timer is turned to any position.
I would lean towards the motor, may have a reset button, but here is a website that will help. You can also click on the virtual repairman:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Dec 23, 2010 | Amana DLE330RAW Electric Dryer
Dryer is not working makes loud noise
heatman101
Jun 18, 2010 | Fisher and Paykel DEGX1 Electric Dryer
My 1987 GE Dryer, Model # DDE5300GALWH,will not run all the time.
sounds like you need a new timer you can actually take the timer apart to check for a burnt connection
Jan 07, 2010 | GE Dryers
My GE 48 inch built in fridge began making a strange noise.
fan motor problem ge has the solucion replacement fan motor around $350 plus mine still makes the noise
Jun 19, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Convection works but Microwave does not heat
try using a voltage stabiliser .it may just solve ur problem..
May 17, 2009 | GE Monogram® ZMC1095BFBB /...
GE Microwave
sounds like either a powerboard or control board is sending erratic voltage or no voltage to the table motor and possibly the light.
May 29, 2008 | Microwave Ovens
GE DBSR453EBWW Electric Dryer Logo
53 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
