Question about HP iPAQ hx2495
HP IPAQ HX2495 won't connect to WIFI
Can see the router, but won't connect
  • 148 Answers
Check your security settings. Disable the security then try to connect again, if it connects then you will need to tweak your security.
Posted on Dec 31, 2008
Just bought hp hx2495 dont know how to set setting
Posted on Jan 27, 2009
Internet access problem: I have a wireless router. The IPAQ internet works fine when attached to my pc. When I remove the IPAQ from the cradle, the internet no longer responds. But, the green light and...
ask on the HP forum yet, (we are not HP here)
sounds to me (seems) like weak battery
or it programmed to not use WIFI when running on wifi. on bat.
as wifi can suck such at tiny battery dry in minutes.
why not get and old CELL phone and use it and dump this old relic.
https://h30434.www3.hp.com/
Sep 28, 2017 | HP iPAQ H5455 Pocket PC
I cant get wireless on my handheld hp ipaq 2200
change the security settings if any in the wireless router.... use 64bitWEP password for the router and if it is a BELKIN wireless router then WiFi protected setup should be disabled in the roter....
contact router's technical support to do settings in it....
Apr 28, 2010 | HP Computers & Internet
IPAQ dosen't connect to Wi-Fi
how far away are you ? from the router? (11b hates noise)
IPAQ are obsolete
why not ask at HP, since its there old device.
ask here.
i cant see your router
its name, or its model number nor the wifi pages inside.
obviously wpa is not working in the IPAQ or is not compatible.
there are sub modes of WPA, and many old devices like this IPAQ do not support, back long ago that was COMMON.
here is its complance spec.
Compliant to 802.1b (EAP-TLS, PEAP)
WPa
one poster said
HP-IPAQ-rx3115 is only 802.11b 11mbit (ONLY) so does the book
that means do NOT TURN OFF 11b in the router !
hp seems to have deleted all support, only asking in there forum works now, zero files books.
13 years old this, is.
i had to google for you, for the book. why not yOU?
http://www.mikechannon.net/PDF%20Manuals/Ipaq/IPAQ_RX3115.pdf
so your router has broadcast SSID name.
like ROVER
and a password,?
then set to WPA, (try all submodes in the router)???????
page 8-4 covers manual settings if wifi.
my router a top brand, DIR655
has , mixed mode set, then
WPA and WAP2 both on....
then wpa-personal mode
then TKIP and AES both (my guess is you have this wrong)
see how that allows older hardware work on a modern router?
make sure AUTO channels is on, for up to 14 possible.
i read your manual and it clearly fails to mention sub modes
that tells me 2 thing,s its an old relic, and 2, has no submode choices only fixed mode and NOT STATED what it is,
bad that.
most old laptops do this same bad act, most.
seen many, do that, infact some only do WPA and only 1 submode
or only old insecure WEP. only
lived that era, dont miss it at all. why use this old thing at all>?
as street value of what $5 pack of cigs , as we used to say?
11b is 1999 spec (OLD) 18 years old now.
run 1 band, e same 2.4GHz band
802.11b devices suffer interference from other products operating in the 2.4 GHz band. Devices operating in the 2.4 GHz range include: microwave ovens, Bluetooth devices, baby monitors and cordless telephones. Interference issues and user density problems within the 2.4 GHz band have become a major concern and frustration for users.
Jul 03, 2017 | HP iPAQ RX3115 Pocket PC
Will not connect to the wifi conecction point
try to check the web key of the wifi if it will match on your hp.
Jun 09, 2009 | HP iPAQ rx1950 Pocket PC
Ipaq 2495
I figured oout how to do the installation. but now I have another problem. The alignment screen does not come up on the Ipaq 2495 and I have to tap about 2 or 3 lines lower than what is showing on the screen.
thanks, Calvin
May 19, 2008 | HP iPAQ hx2495
HP IPAQ 2495
Try and reinstall the sync software in your PC. Check your cable if it is properly hooked.
Feb 12, 2008 | HP iPAQ hx2495
IPAQ wireless connectivity
always start with the simplest answer first so make sure you have WiFi turned on. Think back, have you changed the wireless security on your router? If so you may need to re-enter the network details or add your iPAQ's MAC address to the access control list on the router. In the bottom right-hand corner of the home screen you should have a small HP Wireless symbol, if you tap it you should get your HP Wireless control panel on screen and can 1: turn WiFi on and off, 2: manually enter the WiFi network details and 3: search for WiFi networks in range.
Aug 16, 2007 | HP iPAQ H5555 Pocket PC
Hx2410 general wi-fi questions
Have you been able to connect through your router at home? I'd get that set up and running first. Then doing it on the road will merely be variations on a familiar theme. If you've tried at home but it hasn't worked, let us know something about your home network (what kind of router? using security/encryption?), and about what you've already tried so we can try to help.
Sep 08, 2005 | HP iPAQ hx2410 Pocket PC
Connecting RX3115 to Laptop w/ WiFi
you have to configure an ad-hoc connection between ipaq and pc if no router. otherwise, simply connect to the router and run activesynch
Sep 07, 2005 | HP iPAQ RX3115 Pocket PC
Computers & Internet Logo
980 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
