Honeywell Programmable Thermostat Heater
Problem for Honeywell Programmable Thermostat Heater
Honeywell - cm61ng- Keeps going on and off all night
By limafoxtrot on Dec 31, 2008
I have tried to set it, so it comes on and off at certain times of the day but it still goes on and off all through the night. Not sure what to do?
Same Problem
Feb 10, 2009
-   Does anyone know how to turn this off?-   gillbart
Feb 05, 2009
-   Our new honeywell controller also comes on at weird times - does anyone know have to overcome this ?-   Guest
Jan 22, 2009
-   Have exactly same prob. Turns off when its meant to but turns on at 4 in the morning and sometime early afternoon. Have tried reprogramming but to no avail. -   peelplant
Jan 22, 2009
-   Exactly the same problem except it is turning off when it should but turns itself on at about 4 in the morning and sometime early afternoon. Have tried re-programming on many occasions and am about to give up on it and buy another one.-   Guest
Jan 21, 2009
-   My Honeywell cm61ng keeps randomly turning on and off durin 'off' periods -   neilduckett8
Best Solution
posted on Feb 12, 2009
Very Helpful)
jon_garnett8
Rank: Apprentice
Rating: 79%, 14 votes
Instructions on how to turn off your optimum start:-
Turn off ‘Optimum Start’
Step 1 Put the thermostat in the OFF position.
Step 2 Press 3 buttons together (at the same time) which are the INFORMATION BUTTON (i) and PROGRAM BUTTONS 3 & 4.
This will show a code of ICL 1 – now let go of the buttons.
Step 3 Press PROGRAM BUTTON 2.
This will now show a code of 30t 1
Step 4 Press the + BUTTON (on the left of the display), tap through until you reach 15 OP 1
Step 5 With the TEMPERATURE DOWN BUTTON; change the 01 to a FLASHING 0. Confirm the FLASHING 0 with the INFORMATION BUTTON ( i ). The 0 will now be static.
Step 6 Put the Thermostat back in the ‘AUTO’ position.
‘OPTIMUM START’ is now switched off.
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #2
posted on Jan 28, 2009
Very Helpful)
Technoodle
Rank: Apprentice
Rating: 98%, 3 votes
Mine does the same and displays a little symbol "OPT". I found the instruction manual online and it says
"Optimum Start means that the CM61NG will switch on your heating system so that your desired comfort temperature is reached at the programmed time, thus avoiding unnecessary boiler
firing"
So it may be that you've set your times for when you want the boiler to start heating up the house, not in fact when you want the house to be at that temperature.
Instructions
content.honeywell.com/UK/homes/Technical/CM60NG/CM61%20user.pdf
I'm trying setting the times a bit later and will report back if it doesn't fix my problems.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Mar 03, 2009
Very Helpful)
zznoodle
Rank: Master
Rating: 88%, 9 votes
This is a programmable room thermostat, with timed on and off temperatures. E.g on at 08:00 to give temperature of 22oC, now when you set it to go off, you also need to put in an off temperature e.g 10:00 at 10oC. If this is too high, and i think they are preset to 15oC, it will come one if it drops below this temperature, regardless of what your times are.
Was this helpful?
Yes
No
Popular Solutions for Honeywell Programmable
Questions and Unsolved Problems for Honeywell Programmable
Do you recommend Honeywell Programmable Thermostat Heater?
Answer
Answer
fi and f4 keep come on my honeywell heating control
Answer
Replaced the batteries and now the heater will not come on.
Answer
I have a Honeywell AM! Thermostatice mixing valve installed on my boiler to control the hot water... (More)
Answer
9109 valve fault- no hot water. Where can I buy a new one?
6 Other Users Have The Same Problem - Continued
Comment by sarah botts, posted on Jan 19, 2009
mine does exactly the same i think its something to do with 12 oclock it does the same in the day, it follows my settings all morning then at 12 oclock it gets a mind of its own
Describe your Heaters problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Heater Experts
Top Heater Repairmen
in , NY
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Your name:
Your email:
Your friends email addresses: (e.g. Julie@email.com)
(Separate email adresses with commas)
Message:
Cancel
