Question about ASUS P4P800SE Motherboard
My computer restarted automatically and then there was a message on screen that Checking for floppy... Floppy not found! Checking for CD-ROM CD-ROM found, file P4P800SE.ROM not found. please tell me where to find that file or tell me the other way
  • 1,913 Answers
when upower up the compter pressF8 key then enter in safe mode.
then logon wndoes then type in run "chkdsk /r"
then press "y"
then restart the computer.then it recovers error on harddisk.
Posted on Dec 31, 2008
Bad Locksum BIOS CD_Rom not found when I try to
it's not locksum ,its Check SUM or CRC errors.
what OP, are you running,? windows what. i guess.
the CMOS battery just died.
install a new one.
all puters this old do that, the battery is good for 7-10 years,
and all fail.
DO NOT FLASH your BIOS, fix the real problem first
when the battery dies, all our bios setting were lost
including boot device, and order
fix battery
then go into BIOS and put back boot order.
Mar 22, 2017 | HP Pavilion a815n (PS512AA) PC Desktop
How do you flash the BIOS
What happens when you turn the computer on?
If the bios is working enough to enable you to boot from a CD download the new bios from asus along with there AFUDOS.exe flash utility and make a bootable CD and copy both to it.
If the bios is completly none functional you should be getting this msg when you turn the computer on,
Boot Block Compatible Version Ver .010
Bad BIOS checksum. Starting BIOS Recovery
Checking for floppy . .
Floppy not found
Checking for CD rom . . .
CD not found
Floppy not found
CD not found
Repeat adinfinitum.
If this is the case you need download the most recent BIOS from compaq and either copy it to a bootable CD if you have this capability or buy a floppy drive for $5 and make a bootable floppy on a working computer and copy this BIOS file to it. Then rename the bios file to A8N32SLI.ROM.
You may not even need make the floppy bootable but I would just in case.
Stick the floppy in the drive turn the computer on and you will see
Checking for floppy . . .
Floppy found.
Reading file "A8N32SLI.ROM" . Completed.
Start Erasing...
Start programing . . ./
Please turn off your system and power on again to get system back.
and happy days will be here.
Jun 29, 2012 | Compaq Presario CQ61-310US Laptop
Bad bios cd rom could not detect or read the p4v8x-x enev i rename them and it's still the same, then i try to put the .rom file into floppy,,it detected ! But keep restart. (Checking for...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
make sure that the cd rom is getting enough power test all leads that are attached to the cd drive including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if your computer came with a motherboard disc the sound drivers could be on it
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Apr 13, 2011 | ASUS P4V8X-X Motherboard
iat the time of boot a message as follows is displayed
"boot block compatible version .005"
bad bios cheksum. starting bios recovery
checking for floppy. floppy not found
checking for cd rom. cd rom not found"
.. using asus motherboard
Sep 06, 2010 | ASUS A8V-VM Motherboard
P4S800D.ROM not found
check the the bios battery, it should be 3volt not less,and press dell to in the bios page setup set and set everything you need to do.and don't forget to save it,. good luck
May 10, 2009 | ASUS P4S800D Motherboard
Bad bios checksum
You need to go to the website of whoever made the motherboard and get the BIOS flash utility and the BIOS binary file to update your BIOS. Make sure you get the right one, as using the wrong one can render your motherboard worthless. The BIOS file has to be the exact match. There is no such thing as close in this situation.
If you are not sure of the exact make and model, get te free Belarc Advisor from
The BIOS chip holds information about your motherboard hardware. It is reprogrammable. It uses what is known electrically erasable read only memory. This is also called Flash memory. Reprogramming is called flashing. When you flash the BIOS, all data is erased, then the new data is written. The flash utility will most likely allow you to save the old contents, but you might have an extremely tough time recovering from an improper flash. You'll also probably need a couple of floppy disks, one of which may have to be bootable. If you need a bootable floppy disk, you can get an image file from
Jan 23, 2009 | Intel Motherboard
Bad BIOS checksum.... CMOS bad checksum errors
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
Bios failure
you may have a flat cmos battery, but first try reseting the bios by the cmos reset terminals, refer to the manual
Sep 14, 2007 | ASUS A8V-VM Motherboard
Acer Aspire 3610 laptop - Windows XP error
on a friend's Windows 98 SE or Windows ME computer, create a floppy "Startup disk". Insert in your pc floppy drive and turn on. If floppy drive was not accessed, then get to BIOS and ensure "Boot from floppy drive" is set prior to "boot from hard drive". Once at first screen, select "Boot with CD-ROM driver". Insert CD-ROM and initiate entire re-install of Windows. Windows may do some self-restarting. At first restart do this: get to BIOS and ensure "Boot from hard drive" is set prior to "boot from floppy drive".
Jun 05, 2007 | Acer Aspire 3610 Notebook
ASUS P4P800SE Motherboard Logo
144 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
