Sony STR- DE315 No power after line in.
Sony surround and fm receiver was experiencing shut down problems before this. Any suggs and where can I get a schematic.
Bill
  • 3 Answers
SOURCE: sony HDMI receiver STR-DG510
On Page 54/55 of user man. has a step by step instructions.
Posted on Jun 02, 2008
nuwan chinth
  • 111 Answers
SOURCE: Sony STR- DE315 Transformer Voltages
yes primary smoothing capacitors it place just after the rectifires.
Posted on Jan 08, 2009
SOURCE: sony str-de97 fm/am receiver
you need to change the audio amplifier iC´s damaged
Posted on Dec 24, 2009
dunnbiker
  • 8546 Answers
SOURCE: HELLO HOW TO CONNECT SUBWOOFER TO SONY
It would depend a lot on what type of subwoofer you have and it wouldn't be pretty.
According to the manual I found it doesn't have a Woofer Output so it isn't designed to route Low Frequencies anywhere.
Even if you rigged an Active Subwoofer to it using the Tape Output you wouldn't have central volume control for it unless the (unnamed) Sub was driven by speaker-level outputs from the Front A or B Speaker posts on the receiver.
Your question would be better framed and answered if we knew the details of the Sub and referred to ITS manual.
Posted on Apr 10, 2010
Testimonial: "Thank you for your advice. This is exactly what I needed to know . Jerry"
dunnbiker
  • 8546 Answers
SOURCE: My Sony Receiver Model No
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Aug 31, 2011
Why do speakers crackle and flash protect
Check your speaker wires. Make sure they are not touching each outher or back of the unit. This will overload your output transistors and shut down your amp.
Aug 13, 2012 | Sony Str-d565 Digital Audio Video Control...
My Sony Receiver Model No STR- DE315 Stuck on standby soon as switches on ,Anyway can assist...
Aug 31, 2011 | Sony STR-DE315 Receiver
If the reciever gets real hot would that cause it to go in protect mode? Sony str-de315
It could! Most of the newer receivers these days need alot of ventaltion!
Unless its being played to loud with to many speakers connected!
Apr 13, 2010 | Sony STR-DE315 Receiver
Apr 10, 2010 | Sony STR-DE315 Receiver
STR de315 shows 'protection' after 10 minutes. Is this a common issue?
Does it still do this if the speaker wires are disconnected? The amp is protecting itself from a short on the output. maybe yo have a dead or distorted driver in one of the speakers. Also there could be a defect in on of the amp circuits.
Mar 25, 2010 | Sony STR-DE315 Receiver
Sony str-de97 fm/am receiver
Dec 24, 2009 | Sony STR-DE597 Receiver
Where is the "woofer"?
its on your front speakers there suposed to be a towers
Dec 24, 2008 | Sony STR-DE315 Receiver
Sony STR-DE315 will not power up
Do you have its service manual to go further in unit? let me know as schematic is necessary to rectify its problem of no power.
Regards,
Sep 10, 2008 | Sony STR-DE315 Receiver
19 people viewed this question
 Grubhead
Grubhead
