Question about Toaster Ovens
T-Fal Combination Oven Elite Beeping with H:HH in the LCD display
My T-Fal Avente Elite Combination Elite Oven started beeping this morning with the display of H:HH in the LCD. I am unable to press any buttons to activate the machine.
Any thoughts on what the next steps are?
2 Suggested Answers
  • 333 Answers
SOURCE: lost manual for T-Fal Avante Elite convection oven 028085002
Follow this link and it will have what you need. I hope this helps you.
Posted on Nov 30, 2008
Frigidaire gallery error code f9
How do I reset an F9 on Frigidaire oven? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Oct 26, 2009 - My Frigidaire oven, model feb24s5asb, door is locked and says f9. The door locked is beeping, I need code to know what the code means and how to unlock it.How do I reset an f9, door ... F-9 Error Possible causes: Door motor failure/jammed. Latch motor switch failure. ... Frigidaire Ovens Gallery 30 in.
F9 Error Code - Can't get it to stop beeping - Appliance Repair Forum
forum.appliancepartspros.com/.../400915-f9-error-code-cant-get-stop-be...
Jan 9, 2012 - 6 posts - ‎5 authors After that it flashed betwed F9 and dr and won't stop beeping. ... say that the last time I used the self clean, the dorr would not unlock and I got similar error codes. ...Frigidaire BFEF374EB1 Frigidaire Canada/electric Range Frigidaire Door Lock F9 error code and now F1
1 post
Dec 6, 2010
Frigidaire Door Lock and F9 error code
Jul 10, 2010
Frigidaire Error Code F20 - Upon Cleaning
Dec 3, 2008
Frigidaire error F-9
Feb 18, 2008
More results from forum.appliancepartspros.com
Oct 29, 2015 | Toaster Ovens
My tefal avanti stopped working
something had been gone short due to the power socket.let the socket be ok but sometimes due to heavy voltage this could possibly happen.just check if somme parts is burnt ,turned black or smelling foul oudor,or when you on the machine now it passes burning fumes from some where.
Aug 11, 2008 | Tefal OT806000 Avante Elite 1600 Watts...
Breville beeping too loud
The beeping sound is annoying and mostly unnecessary. Unfortunately it can't be turned off. The only way to "fix it" would be to remove or disable the Piezo buzzer. I tried doing this, but disassembling the oven to reach the pcb control board ,where the buzzer is located, is complicated. You can take the top cover off using a Philips screw drive. But reaching the pcb board is tedious. So I gave uP and reassemble it. If someone has a better idea or method , please share. This is a great oven except for the annoying beeping. Even my dogs are afraid because it is the same sound that my invisible fence has and they think that they are being warned.
Mar 28, 2013 | Breville BOV800XL 1800 Watts Toaster Oven...
Waring TCO650 toaster oven - how to turn off or down the beeping
I found it! In the manual that came with the toaster (and not the one online), I found the following instructions:
1. To turn the indicator beep OFF: Press both [TOAST] and [BAGEL] keys and hold for 5 seconds.
2. to turn the indicator beep ON: Repeat the above process.
Note - if you lose power or unplug the unit, the beep comes back, so keep these instructions handy. :)
Dec 01, 2012 | Waring Tco650 Professional Toaster Oven
Problem with the T-Fal Avant Elite OT806552/4YA-4804 Toaster Oven. Oven won't come on at all, how do I get the cover off to check it out? Is there a fuse or breaker that I can replace. Thx. -mahen
I have the same toaster and the fuse burnt out a couple of days ago. Its a 10 Amp fuse behind the control panel under a white cover. You will need to remove the right side of the oven to see it. I've not found a replacement fuse yet. Let me know if you find one.
Mar 20, 2011 | T-Fal Avant Elite OT8085002 Toaster Oven...
Heating element no longer works. is there a fuse or is it the coil that's the problem?
I had the same problem and discovered it was the plug on the heating element was loose. I'd check continuity with a ohm meter across the coil. If it shows a closed circuit there isn't anything wrong with the element itself and could be as simple and cheap as tightening up the connector.
Dec 28, 2009 | T-Fal Avant Elite OT8085002 Toaster Oven...
Lost manual for T-Fal Avante Elite convection oven 028085002
Nov 30, 2008 | T-Fal Avant Elite OT8085002 Toaster Oven...
Tefal Oven faulty LCD DISPLAY
Hi babypom,
No, the LCD display is a whole piece and need to purchase from the agent.You've to confirm there is LCD voltage, but no display light, to justify is LCD faulty.
Rdgs
alan
Feb 18, 2008 | Tefal OT806000 Avante Elite 1600 Watts...
"Err"or message with beeping
Same message here. Did anyone buy it a costco? I'm hoping they'll take it back. Andrew Victoria BC
Oct 14, 2007 | Oster 6239 Toaster Oven with Convection...
Toaster Ovens Logo
Top Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Toaster Oven Expert? Answer questions, earn points and help others
