Question about MidiLand MLi 698 Computer Speakers
No sound I have the MLi-698 speakers and at work i have a neoware device and i plugged the speakers in where there supposed to go and i turned the computer on and off then turned it on again and went to use them on any music and video website and it wont work at all, all im hearing is like a buzzing sound
2 Suggested Answers
preachw996
  • 1179 Answers
SOURCE: MLI-699 Computer Speakers Power supply Please and
You could try CabletoGo.com. They usually have just about every replacement power supply available for sale or can guide you on where to purchase. Hope this helps.
Posted on Oct 16, 2009
Is the 12 volts power AC or DC for the MLi-480 unit?
Very rare if it is AC----look where the plug goes and if see a tiny + and - it is dc.
Apr 24, 2012 | MidiLand MLi 480 Computer Speakers
Sound from one speaker
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Apr 03, 2011 | MidiLand MLi 691P Computer Speakers
MLi-698 speaker: what voltage/wattage for the power supply?
Whatever is the voltage or MLi 698 Hi-Fi Sound Monitor ?
Mar 07, 2011 | MidiLand MLi 698 Computer Speakers
The speakers will turn on but no sound will come out.
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or
control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 20, 2010 | MidiLand MLi 691PA Computer Speakers
My mli 699 speakers are not working . And I dont have the driver
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 12, 2010 | MidiLand MLI-699 Computer Speakers
I simply have no sound. my speakers are hooked up but it says there not detected
control panel sounds and audio,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
good luck
Sep 09, 2010 | MidiLand MLi 170 Computer Speakers
I have this set of speakers hooked to a Dell 3000 running under Windows XP Pro. I recently had to change offices and when I hooked up the speakers, the subwoofer wouldn't work. I've tried reinstalling the...
Please check the cable using a multimeter. Check if the cable is broken.
Just by shifting the system, I fear if you could have an issue like this. Also check the Subwoofer box if its working or not. Good Luck.
Jun 04, 2010 | MidiLand MLi SW190 Computer Speakers
I recently got a new computer & it has windows
If there is not a dedicated port for the sub, you are out of luck. Unless - the MLI sub can serve as the splitter
Jul 24, 2009 | MidiLand MLi 450 Computer Speakers
4.1 speakers on vista!!
Hi,Can you tell me the power supply (AC adapter) requirements for Midiland MLI 747 - 4.1 speaker system?
Apr 26, 2008 | MidiLand MLi 747 Computer Speakers
Speaker power supply
Found power supply for MLI-691 H speakers
Output is 9vdc, 600 ma. center of plug +.
SUN 9
Jun 10, 2007 | MidiLand MLi 691H Computer Speakers
MidiLand MLi 698 Computer Speakers Logo
27 people viewed this question
Top MidiLand Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MidiLand Audio Player and Recorder Expert? Answer questions, earn points and help others
