Question about ASUS P4P800SE Motherboard
File P4P800SE.ROM not found
I have a problem while finding the file P4P800SE.ROM what can i do?
  • 52 Answers
Hi!
Insert the floppy disk that came with the motherboard to recover the bios. Make sure that the BIOS file in the floppy disk is renamed as P4P800SE.ROM.
Have fun!
*Your vote is highly appreciated. Thanks in advance!
Posted on Dec 31, 2008
  • 827 Answers
Sounds like you're trying to flash the bios..
Using ASUS EZ Flash to update the BIOS: The ASUS EZ Flash feature allows you to easily update the BIOS without having to go through the long process of booting from a diskette and using a DOS-based utility. The EZ Flash is built-in the BIOS firmware so it is accessible by simply pressing <Alt + F2> during the Power-On Self Tests (POST). To update the BIOS using ASUS EZ Flash: 1. Visit the ASUS website (www.asus.com) to download the latest BIOS file for your motherboard and rename the downloaded file as P4P800SE.ROM. Save the BIOS file to a floppy disk. 2. Reboot the system. 3. To launch EZ Flash, press <Alt+F2> during POST
Hope this helps
Chris (ziraffa)
2 Suggested Answers
acdr
  • 1913 Answers
SOURCE: my computer restarted automatically and
okay
when upower up the compter pressF8 key then enter in safe mode.
then logon wndoes then type in run "chkdsk /r"
then press "y"
then restart the computer.then it recovers error on harddisk.
P4p800se.rom I need dhis file
the file you search for is a bios fil.Go there-
http://support.asus.com/download/download.aspx?SLanguage=en-us
Select - Motherboard
Select - Socket 478
Select - p4p 800se
Select operating system(xp,2000....)
Than download the bios....ectract it.
you got the rom fil
Jun 29, 2010 | ASUS P4P800SE Motherboard
I need sound driver for my p4p800se mobo ty n advance melts92@gmail.com
Please download these drivers from
http://support.asus.com/download/download.aspx?model=P4P800%20SE&SLanguage=en-us
Regards
Ashly
Feb 02, 2010 | ASUS P4P800SE Motherboard
How do I find the sound unc path to file download
I don't know what 'Sound' unc path you are referring to, but if you want to find the UNC path to a networked share, it is \\computername\sharename
So if your computer is named say Johndoe and you have already mapped a drive to the folder you are wanting to access called itunes share then your UNC path is going to be \\Johndoe\itunes share
Good Luck!
Oct 22, 2009 | ASUS P4P800SE Motherboard
Won't start up
when your computer it should say f1 to stup if you go into to the setup menu and scroll around untill you find bios and if you are going to use it dont turn it off if you are not going to use the bios it will help your computer if you turn that off rate me thanx
Apr 19, 2009 | ASUS P4P800SE Motherboard
Startup stops ---P4P800SE
Hi turn off an unplug the PC open the right side cover of the computer, remove the memory card and clean the contact cotton w/alcohol and wipe it dry and re install it back. This might solve the problem.
HH
Apr 18, 2009 | ASUS P4P800 SE (890552603657) Motherboard
I am trying to find out if my motherboard will support 64 bit OS
Hi there
have a look here to find out which intel processors the board supports.
http://www.cpu-upgrade.com/mb-ASUS/P4P800_SE.html
Thanks for using Fixya!!!
Feb 09, 2009 | ASUS P4P800SE Motherboard
Bad bios checksum
You need to go to the website of whoever made the motherboard and get the BIOS flash utility and the BIOS binary file to update your BIOS. Make sure you get the right one, as using the wrong one can render your motherboard worthless. The BIOS file has to be the exact match. There is no such thing as close in this situation.
If you are not sure of the exact make and model, get te free Belarc Advisor from http://www.belarc.com
The BIOS chip holds information about your motherboard hardware. It is reprogrammable. It uses what is known electrically erasable read only memory. This is also called Flash memory. Reprogramming is called flashing. When you flash the BIOS, all data is erased, then the new data is written. The flash utility will most likely allow you to save the old contents, but you might have an extremely tough time recovering from an improper flash. You'll also probably need a couple of floppy disks, one of which may have to be bootable. If you need a bootable floppy disk, you can get an image file from http://www.bootdisk.com.
Jan 23, 2009 | Intel Motherboard
My computer restarted automatically and then there was a message on screen that Checking for floppy... Floppy not found! Checking for CD-ROM CD-ROM found, file P4P800SE.ROM not found. please tell me...
okay
then press "y"
Dec 31, 2008 | ASUS P4P800SE Motherboard
LaCie silverscreen Utilities CD-ROM
The OS is hidden in memory, you can clear all files off the machine and it will still work.
The only requirements are the 4 folders:
Firmware
Movies
Music
Pictures
That's it!
New firmware can be found at www.lacie.com
Dec 24, 2007 | LaCie Silverscreen 80GB USB 2.0 - Portable...
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
ASUS P4P800SE Motherboard Logo
1,573 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
