Question about Frigidaire 30" Self-Cleaning Slide-In Electric Range - Black
Where is the fuse panel located in Frigidaire Professional Series Slide in Cooktop range?
  • theresa_gibs Dec 31, 2008
    Thank you
  • spartandiese May 11, 2010
    how do you remove the front panel once the screws are out, as I can get the panel off?
  • 242 Answers
I can help , The fuse panel/control board is located behind the digital display in the front of the unit. Some drop in ranges are tricky getting into so be carefull when removing the face , there are screws under the display when opening the oven door look up and there may be a few more on the top side corners reveled when you pull the unit out 12" or so. there is a small glass fuse in the board some of these are not removable so if there is no digital display on your oven and your sure you have 240V to control board you will need to replace the entire control board. Hope this gets you there. Good luck let me know if you have anymore problems.
Phil
Posted on Dec 31, 2008
What's the fuse for on the top panel of my Frigidaire/Electrolux glass top range
Good Afternoon Debra Gallagher, thank you for your inquiry!
I see that you are searching for the fuse within your Electrolux cooktop. If you could provide me with your model number I can verify any further information for your cooktop. You should be able to locate the serial tag along the bottom of your cooktop. With that information I would be able to assist you further. -Matt
Feb 15, 2015 | Electrolux Kitchen Ranges
I have frigidaire electric range FES367DQA. I cracked the cooktop and would like to replace it. I found that there is no glass cooktop for my range but there is for FES367DBA and DCA. The difference i
Thank you for your post, isaak goldman!
I understand that you are seeking instructions in order to replace the cooktop on your Frigidaire range. However, this is not a simple DIY job. I would recommend having a professional technician come out to ensure that the range is properly disassembled and the cooktop installed correctly to prevent any future issues. Hope this information is helpful. -Matt
Jan 31, 2015 | Frigidaire Kitchen Ranges
Fix the eyes on the glass top
Hello jackie wakefield, thank you for your post! Based off the information you have provided you would like to fix the burners located under your Frigidaire range glass top. In order to replace the burner you would need to remove the cooktop. Regrettably this is not a simple DIY job. I would recommend having professional technician come out to your home for proper disassembly of the cooktop and replacement of any electrical components. Hopefully this information is helpful. -Matt
Jan 01, 2015 | Frigidaire Kitchen Ranges
Frigidaire PLES389DCC MODEL Electrolux Professional Series My glass cooktop is cracked, where is the cheapest site to find a replacement glass
318223626 - MAIN TOP
found it listed from 230.68 at prosupplyco.com
up to 281.85 at Repairclinic.com
hope this helps,
best of luck,
ttfn
Oct 27, 2009 | Frigidaire FEF366 Electric Kitchen Range
Location of Thermal Circuit Breaker, actually two
located inside the back cover then remove rear access panel to oven cavity and they are there
Sep 28, 2009 | Frigidaire 30" Self-Cleaning Slide-In...
Oven door locked and fan going frigidaire professional range
Did you solve your problem? I just got stuck in the same situation! How did you stop it?
Jul 09, 2009 | Electrolux Frigidaire Professional Series...
F93 code door locked
have door open and hold door switch
Jun 22, 2009 | Frigidaire 30" Self-Cleaning Slide-In...
Replacing the ceramic cooktop on my frigidaire slide in stove
there is no need of any instruction booklet for your problem, but a cooking range repair man.
He will replace it for you.
Mar 20, 2009 | Frigidaire 30" Self-Cleaning Slide-In...
Burner will not turn off
You'll need to replace the burner switch. This happens when the contacts become fused together.
Mar 24, 2008 | Frigidaire FEF366DC Electric Kitchen Range
Frigidaire 30" Self-Cleaning Slide-In Electric Range - Black Logo
1,005 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
