SOURCE: Kenmore Elite front loading washing machine
My machine just died. No codes, no nothing. I thought it had blew a fuse. But the outlet is fine. There is no power to the unit. There is a load in the machine and I can't get it out. Help
SOURCE: Frigidaire Affinity ATF7000E Front Load
The control is most likely bad. If lights flash on front let me know which ones and how many as it will sometimes tell me what the failure is. Thanks, please leave feedback or contact me again for more info if you need it.
SOURCE: Frigidaire affinity atf6000es1 - control panel locked
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines hope it may for you..............And please rate me if helped
SOURCE: My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
SOURCE: Mymachine's light is fixed at 'control locked'
If the model number is correct, press the END OF CYCLE SIGNAL button for 3 seconds. These instructions are listed on page 10 of the owner's manual. If you no longer have a manual, you can obtain a FREE copy at managemylife.com.
This is a designed safety feature that enables the comsumer to lock the control panel to prevent small children from accidentally locking a playmate inside the washer and starting it. This usually is not an indication of a washer malfunction.
If you need further assistance, please let me know. I hope this helps you.
Testimonial: "Wow! Thank you! The solution worked perfectly!"
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
